questions
- » Blogs
- » Image Gallery
million posts!
January 2026
| S |
1 |
| 4 |
5 |
8 |
| 11 |
12 |
15 |
| 18 |
19 |
22 |
| 25 |
26 |
29 |
30 |
31 |
4Likes
3
Post By PeterAllen
Post By cg514
03-17-2016, 07:20 PM
Vic
Side Window build
Guys
Despite having a fair scour of the forum I didn't find much guidance as to how one goes about building the sliding side windows for the cobras.
Does anyone have a lovely set of how to pictures?
Or can anybody nicely describe how I go about setting up the windows?
Or is there a set being made in Melbourne I can come have a look at?
To start with what material and thickness should I be using?
I want to progress my soft top and so will need to finish off the frames already made by Marty.
Looking forward to some good feedback.
Cheers and thanks
Steve
slowy
Advertising
03-17-2016, 08:25 PM
NSW
Cobra Make, Engine: Puckett 250 GTO - LS1
Horizontal or vertical slide?
03-17-2016, 10:00 PM
Vic
Horizontal sliding mate!
slowy
03-17-2016, 11:38 PM
NSW
Originally Posted by stephen low
Guys
... I want to progress my soft top and so will need to finish off the frames already made by Marty...
I'm not sure what information will assist as I had to make the frames and as such mine might be a completely different design concept from those you have.
I folded sheet aluminium to suit Bailey channel I purchased from a rubber supplier to suit 6mm thick perspex.
I either cut or notched the frame sections and then welded them to the shape of the window. I made the bottom section detachable to facilitate installation and removal of the perspex.
The most difficult task was creating the mounting points to the door in the limited space available. It was exhaustive trial and error.
It all seemed to come together okay.
03-18-2016, 03:39 AM
i made a set for my cobra about ten years ago Stephen they attach to the doors by allen bolts that screw in to inserts in top of doors the window needs an angle on the bottom to follow contour of door have a couple of photo but not very good you are welcome to borrow them to see if that sort of thing can work on yours
chris
03-18-2016, 05:53 AM
AL
I made a pair of side curtains for a B&B hardtop. No welding required. Just need a table saw and drill.
If you need more pictures and details please let me know.
Dwight
03-18-2016, 05:57 AM
AL
picture of another side curtain on a friend's Hurricane
The black edge is paint. This side curtain was made by Ape Tops and modified to fit the Hurricane by adding a larger gasket to the bottom. Both the Hurricane and B&B are hung from the top but it's easy to mount them on the door with ferrules like the original Cobras.
03-18-2016, 06:04 AM
AL
FFR with Ape top
03-18-2016, 07:06 AM
GB
Cobra Make, Engine: Dax -fuel inj 383 chevy
not sliders but my take on side screens, Sam
03-18-2016, 03:44 PM
Vic
Query is about the window pane construction
Thanks for the commentary so far guys.
I tried to post last night but my systems didn't work, as I was going to focus the request for feedback on how to actually put together the sliding window pane components.
As you can see below, I've got all the main hardware developed, hood bows and the side frames into mounting positions.
It is just the construction method around mounting the window panes that I am trying to understand.
Peter's first post was closest to issue but does anyone else have details on the actual window system used?
Cheers and thanks
slowy
03-18-2016, 05:03 PM
VIC
Cobra Make, Engine: AP Pace427 (AP4033) GM L77 6.0L TR6060
It might be the pic but are the top and bottom of the window frame parallel Stephen? If not, you'd probably be best installing one large piece of Perspex on the whole thing, then making a smaller sliding panel.
Rob Hamiton would be another good source. He's made a few like this (with full sliding panels I mean).
Guy
Cobra Progress guye-cobra.blogspot.com
03-18-2016, 09:23 PM
Vic
Guy
To be honest I hadn't measured but would like to think that is something Marty wouldn't have got wrong. But I will check.
And I did know Rob was another source of advice but hadn't taken that route yet and don't need to now.
Anyway after seeing the trimmer this morning fellas, it is all sorted as he does this installation job as part of the soft top trimming exercise - lol
He showed me the felt they use in the channel to set up the sliding panel and in fact helped me get an understanding of the side window frame set up he needs anyway. One frame fitted flush to the rear of the windscreen and he needs a gap.
So Marty now has that frame and knows how much needs to come off, so the process is now in train.
Thanks again lads
slowy
03-19-2016, 06:34 PM
VIC
To be honest I hadn't measured but would like to think that is something Marty wouldn't have got wrong. But I will check....
Oh if Marty made it I'm sure it's parallel, if it's meant to be!
Anyway, sounds like you've got it all sorted!
I still have to go down the soft top path so will be interested in seeing your end result!
Guy
03-21-2016, 04:34 AM
Vic
Guy
Blackwoods fully trim the window frames so you see no metal as the end result.
Not sure what others do but that saves some effort in terms of anodising I thought I'd have to arrange.
I've no doubt the end result will be pretty good, if the initial work is anything to go on.
But then they have had tons of experience and was even discussing construction items from photos Peter had of work done on a Robnell and an original cobra way back when.
Sadly this work wont happen before the Fest so I might be in a quandary as to whether to commit to the weekend. Can handle light showers and drizzle, as I've already experienced but exposure in a downpour isn't needed at this stage of the build.
Will see what Marty and a recommended alignment shop have to say in terms of timing and availability to properly align the car.
slowy
03-22-2016, 07:04 AM
VIC
C'mon slowy - I just took a tarp and when it got too heavy I pulled over and made camp!
Nothing to worry about!
Guy
03-22-2016, 07:18 PM
Vic
If you're worried about weather, tow it. The pits are covered, and the parking at accommodation is an underground concrete garage.
Ben in AU
03-22-2016, 08:16 PM
Vic
All falling into place, arms ready, arranged alignment care of Rob Tucker and I'll need to brave the weather early Saturday morning as am unlikely to be able to drive up Friday.
I'll dress accordingly and take a brolly - lol
slowy
