questions
- » Blogs
- » Image Gallery
million posts!
January 2026
| S |
1 |
| 4 |
5 |
8 |
| 11 |
12 |
15 |
| 18 |
19 |
22 |
| 25 |
26 |
29 |
30 |
31 |
07-22-2008, 05:08 AM
universal wiring kits
just like to know if pre made wiring kits are a way to go, instead off paying someone big dollars to make one. I'm looking a the E-Z wiring kits, are they any good.
Anyone used these kits ?
Advertising
07-22-2008, 06:17 AM
Qld
depends what u can do yrself
all these pre made looms are just fusebox and wires
i did phills cobra the other day and that was with a pre made loom
i still had to add 10 relays and afew extra fuses
so all the pre made looms mean u dont have to make the fusebox section
and none of these premadelooms are made to suit an efi engine
i always modify these kits to suit an efi application
one bit of warning
make sur eu know how to solder
its amazing how many cars i fix and the solder joins are horrendous
solder joins twice as thick as the wires themselves
07-22-2008, 06:55 AM
Vic
Troyboy welcome to the mad house.
I used the EZ wiring kit in my car but used the services of a sparky so I had someone who knew what they were doing, and my build time was limited - the arcs and sparks is a field I'd like to understand a good deal more about in the future.
Anyway as sideshow says, a heap of relays are needed plus you need the correct diagrams to link into the ecu and whatever else your running. The cabling is labelled and coloured so tracing would be easy down the track with a good build diagram.
I think my sparky did have to remodel wiring to suit our key positions eg accessories and other ancillaries on at the right key rotation locations.. Seems the US set up might be a tad different. At least that what I think was happening.
I'm sure I have a few pics in my gallery of the wiring.
If you have the time and knowledge go for it!!
slowy
07-22-2008, 07:52 AM
Troyboy,
I used the E-Z wiring kit same as Slowy and had an Auto Electrican do the work. Theres a pic in my gallery showing some of the wiring. I still cant believe there are so many wires for a car without windows, air cond, radio,central lock and electric seats.
Regards.
Mando
07-22-2008, 04:07 PM
Vic
TroyBoy,
I just had my Daytona wired from scratch in Victoria.
The sparky/engineer is up to his 20th Cobra/Daytona. If you want his details
give me a PM and I will send them on.
STIFFY
07-27-2008, 08:43 PM
QLD
I bought a Painless universal harness and while everything is labelled very well, there are lots of things you don't need and some that you do need (like reversing lights) are missing. It is quite complex but now I understand a lot more than I did before. You have buy lots of relays, as Sideshow says, and connectors as the ones supplied are pretty average. In hindsight I would probably mkae my own if there was a good template. Geof Hemphill has a very helpfull pair of wiring diagrams on his gallery. Really with that and using the right wires and connectors would get you there.
The "Painless" Harness is not so painless and at least twice I have been ready to rip it out and throw it away. Hours spent with a test light and battery charger to find out things for my self. Still.... almost there!
Merv
Merv
Ford Cobra
Harrison #80.
Peregian Beach
Sunshine Coast Qld.
07-27-2008, 09:09 PM
QLD
Unlike Merv, I found the painless harness pretty painless. All wires are labeled every 300mm or so.
The column switches took some thinking but that wasn't too bad once I got a sigma wiring diagram.
I got it all working without relays initially then just added the relays for the high draw stuff to take the load off the switches. (cooling fan, headlights, fuel pumps etc.)
Took only a weekend to run the harness and get it to work without the relays.....was just a matter of then hiding the harness out of sight and running circuits for the relays.
07-28-2008, 03:55 AM
WA
Cobra Make, Engine: G-Force, Ford 5.4 SOHC 3v
Rebel 1,
I am currently helping a friend with his wiring and we were wondering where we could get a Sigma column wiring diagram, with out buying a manual.
Would you be able to help us out with a copy of yours?
Thank's,
Harry.
07-28-2008, 04:29 AM
QLD
Sure can Harry..send me an email to:
rebel3@tpg dot com dot au and I'll send you back pages from the manual.
07-28-2008, 05:35 AM
QLD
Good that someone found the Painless harness so effective. I probably will say the same when the glow of completion hits me. Warwick said he also found it more complex than needed and wires that needed to be added. Anyway, I think I may have the Sigma column mount so I would like a copy of that as well if possible just to check if all my work with the test lite was correct. Any chance of a PM on that?
Many thanks
Merv
Merv
Ford Cobra
Harrison #80.
Peregian Beach
Sunshine Coast Qld.
07-28-2008, 05:45 AM
Qld
they all do the same purpose
its basically a fusebox with wires and u do the rest
they originally were for carbied cars and still really are
they are not really made for efi cars thats y i modify these fuseboxes on customers cars
to suit the 7 to 10 relays needed for todays cars
ill be starting my own body loom for a cobras and kit cars soon
will be more expensive than painless and others but will have relays for everything even the efi stuff
if i had the money i would make my own design fuseboxes and stuff and would **** on anyhting out there but i dont have a spare million heheheh
but for now ill stick to what i can afford to make and what people are willing to pay
painless is just to expensive these days or it might be rocket industries just rip people off too much
unless u know someone there u pay double the price
i went there once and didnt buy anything and will prob never go back
these days i have enough contacts elsewhere in the world to buy stuff
07-28-2008, 06:43 AM
VIC
Yes I agree re Rocket. When pricing Borgeson u-joints it was minimum 50% markup and that's against the US price after conversion and freight. Most other things I looked at were similar. And the two blokes I spoke to barely had the time of day to spare.
Back to the wiring... I don't see why pre-made kits are such a hassle. For $350 or so you get colour coded wiring, nicely labelled, with a decent fusebox and schematics. The trick to me is getting what I will call "automatic" accessories such as fuel pumps, thermo fans, injectors and 02 sensors running correctly with the factory ECU. That's the mystery to me.
07-28-2008, 10:04 AM
AZ.
Cobra Make, Engine: Cobray-C3, The 60's body lines on todays chassis technology
Painless is more expensive than EZ wire but Painless has very good documentation. The step by step approach makes for a good manual and info is correct. EZ did not have as good of a manual and found conflicts in wire numbers and color specified at least on the kit part # I checked out. The overall component quality of each was good.
If you are comfortable with electrical installs EZ is less $$ and all the circuits are there but maybe a different color/number. Painless is easier for the guy who needs good documentation with point to point charts IMHO anyway. I found the 20 circuit kits a better buy than the 12 circuit kits as far as bang for the buck. The larger kit allows you to add the relays and extras that make things a cleaner install. It is nice to have a spare fused circuit and easy to tuck way for latter if not used today.
07-28-2008, 04:06 PM
QLD
For what it worth for the Aussie guys using the Mitsubishi column. I scoured the wreckers to find the plug that matches the mitsubishi column plug. I then spliced this onto the painless harness.
As said I used the Painless harness but ran another power circuit (heavy wire) to the front of the car from the fusable link. This wire then provided the full power for the lights, radiator fan and horn via relays and fuses.
My battery is in the boot so a circuit for the fuel pump relays are right where you want it.
The painless wires then just become a trigger wire for the relays.
It does mean you have relays at each end of the car as well as under the dash but frankly the relays at the front and rear are much easier to get to then climbing under the dash.
07-28-2008, 10:02 PM
VIC
Les, did you run a dedicated ground circuit? I'm planning to do this, along with a few disconnects in various places to earth the relays and other accessories as required.
07-28-2008, 10:22 PM
QLD
Sambo, I'm using the chassis as the neg buss. I then have three ground circuits....one at the front,one to the dash, and one at the back. The engine and the gearbox also have straps to the chassis.
07-29-2008, 12:17 AM
VIC
Sounds like the best of both worlds Les - might steal that idea from you!
07-29-2008, 12:49 AM
QLD
Sambo I think where I differ from most is that my battery cable exits the tunnel to a heavy duty junction box behind the dash. From this junction box a lighter (as supplied by holden) starter wire goes to the starter.
The alternator connects directly to the battery cable in the junction box. All other power comes from this same junction box via a fusable link then to the fuse box. as detailed here:
http://www.madelectrical.com/electri...esensing.shtml
I sorta followed all the advice from this site. Go to the electrical tech link. http://www.madelectrical.com/electrical-tech.shtml
07-29-2008, 01:33 AM
VIC
Mate, we've been studying the same website! Do you think the remote solenoid is overkill?
07-29-2008, 01:40 AM
QLD
Yep.. I think so.
