Like Tree3Likes
LinkBack Thread Tools Rating: Thread Rating: 4 votes, 4.00 average. Display Modes
  #101 (permalink)
Old 03-02-2012, 04:31 PM
400TT's Avatar
Steve, I have used a press stud right at the front/bottom to attach to chassis, you might need a strap to get enough length to reach the chassis.
Then just velcro to inside of the guard to secure the rear edge. Recommend using contact cement etc to adhere velcro to inside the guard as I have found the adhesive on the velcro to not be reliable enough long term.
DSOS likes this.
www.absolutepace.com
  #102 (permalink)
Old 03-02-2012, 04:47 PM
Merv and Sharon's Avatar
That is pretty much it Steve. I have a lift-a-dot (double height post at the top for the tonneau also) and another at the bottom on the inside end of the chassis rail. The spat clips on those and folds under on to a wide (not the narrow stuff) velcro strip (which is glued on as Craig describes). The edge of the spat is sewn where it folds over the edge of the wheel arch, to reduce the pressure on the velcro. We experimented with a sprung steel strip to clip in the spat, inside the wheel arch, but it didn't work out. The leading edge of the spat has stretch elastic sewn in to keep it in place. I have taken them off many times to test them out and all is good.
Merv
Ford Cobra
Harrison #80.
Peregian Beach
Sunshine Coast Qld.
  #103 (permalink)
Old 01-21-2016, 10:58 PM
Merv and Sharon did you use velcro under the fender to hold the spat on? What about the bottom is there a peg?
  #104 (permalink)
Old 01-21-2016, 11:34 PM
Wazza's Avatar
That's not bad...
Last post almost 4 years ago....and now a question.
Gotta be a record !!
  #105 (permalink)
Old 01-22-2016, 03:43 AM
renovationinnov's Avatar
Cobra Make, Engine: venom motorsports /ls1 auto
gees i was hoping someone was remaking the stainlees steel ones agian as i was to put in my order for a pair BUT i see not so be to hibation for this thread again
4 years
deano59 likes this.
not all your babies are your children
  #106 (permalink)
Old 01-22-2016, 01:19 PM
07cob's Avatar
Originally Posted by Wazza View Post
That's not bad...
Warren
I think it is fair enough. Steve actually originally asked the question in March 2012 and has patiently been awaiting an answer.
Originally Posted by Steve Gallegos View Post
Merv, how do you attach it to the underside of the wheelwell?
Now that is patience!
Steve, Merv doesn't hang around here much although i looks like he last logged on on 31 October last year. Try sending him an eMail - you can do this through his user profile.
Geof
boxhead likes this.
Rate This Thread:
