November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
  #21 (permalink)
Old 07-22-2009, 06:51 AM
Mando's Avatar
Gregg, I looked through your gallery and the rear stay seems to have quite a bit of angle to it. It looks like the round bezel wouldnt sit right, but that must be from the photo only.
Regards.
Mando
  #22 (permalink)
Old 07-22-2009, 03:56 PM
gjkrv8's Avatar
Regards.
Hi Mando,
Its probably the angle form the photo I think. I actually tried one of my round ones (that are for the front) and they do sit ok. Probably a very slight filing on the edge at the front, but a dremel would fix that.
Mando, if you've got a spare that would be fantastic, saves me have to order one from US. No dramas if you havent, I can order a single one form the US with some other goodies if I need to.
Rgds
Gregg
  #23 (permalink)
Old 07-22-2009, 04:09 PM
gjkrv8's Avatar
Originally Posted by Tenrocca View Post
I just left em as is - I think they look ok the way they were, and I would have stuffed it up trying to trim them no doubt. I can take a shot tomorrow for you (possibly after the first test drive - weather permitting)
Yeah I was thinking the same (regarding the trimming), I wasnt sure as I hadnt seen any photos of any.
Hey, good luck with the first test drive. You must be getting close now, you have a lot of patience. (More than me).
I am trying to get mine off to the painter and painted prior to Summer.
Thanks for the tip
Rgds
Gregg
  #24 (permalink)
Old 07-23-2009, 05:59 AM
Mando's Avatar
Gregg, found one, send details and Ill put it in the post.
Regards.
Mando
  #25 (permalink)
Old 07-23-2009, 08:39 PM
gjkrv8's Avatar
Regards.
your a legend Mando.
sending PM now.
  #26 (permalink)
Old 07-23-2009, 09:42 PM
Mando's Avatar
Gregg, I couldnt work out how to reply to your message on the PM site so.............
Ill put the ring in the mail early next week, you should see it by Wednesday.
Regards.
Mando
  #27 (permalink)
Old 07-23-2009, 09:55 PM
gjkrv8's Avatar
Regards.
Yeah I got a reply from you without any text.
Thanks for that.
Rgds
Gregg
  #28 (permalink)
Old 07-25-2009, 01:39 AM
Mando's Avatar
Gregg/Tenrocca, have you guys cut the rollbar rubbers at an angle so they sit on the body without the need of the ally rings on top to keep them in position? If so, what did you use and when in position is the join between the the rubber and metal constant? I used a stanley knife and its pretty good but can I improve the join using a dremel for example? The rubber doesnt like having thin amounts, say less than 1/2mm removed using an extremely sharp knife.
Regards.
Regards.
Mando
  #29 (permalink)
Old 07-25-2009, 01:42 AM
Tenrocca's Avatar
Yeah Mando I used a dremel held on the same angle as the bar. Lots of shaving a bit off, testing, shaving, a bit more testing etc
  #30 (permalink)
Old 07-25-2009, 05:20 PM
gjkrv8's Avatar
Regards.
Regards.
Hi Mando,
Am going to be doing some work on mine this aro. I found that on the rear stay I am able to use the rear stay "Oval" rubber with the "Circular" Bezel. Although in my case I will need to file/sand the Metal Bezel a fraction - I think I will use the Dremel for this.
Will post some Pics once I get this sorted.
One of the challenges I face is that one of my front circular Bezel fitting locations (the one closest to the edge of the body), the surfce is not flat. I might need to bend the bezel slightly - I am not looking forward to that as I dont know how pliable the bezel is. Gently gently will be my approach.
Rgds
Gregg
  #31 (permalink)
Old 07-28-2009, 06:52 AM
gjkrv8's Avatar
Originally Posted by gjkrv8 View Post
Hi Mando,
Rgds
Gregg
Hi Mando,
I received the Bezel from you in the post today, thanks for that.
Regarding trimming the grommet, I had to trim the edge of the oval grommet and I used scrissors and then the dremel and then hand sandpapered the rest.
Might not be able to post photos as painter is coming tomorrow night for an inspection before I rip everything off the car for sanding/filling/painting - getting excited now.
Rgds
Gregg
Rate This Thread:
