November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Old 02-21-2012, 10:28 PM
Default Re:
Sorry to say, but I did not install the HID conversion when it was done a few years back, and my knowledge of how it was wired up is a bit fuzzy.
I am sure that the wire gauge is fine, as it worked for over a year. Then all of a sudden, the lows started going off an on every few minutes, and now then go on for a second and then immediately off.
I would like to start with the easy stuff, like the fuse. I know how to open the fusebox and I found the lows sticker, but I cannot actually find the fuse to remove and replace it. Can anyone tell me how to remove the fuse from the fuse block? If that does not solve it, then I think I would need to check the ground next.
Also I do not know if the headlights are connected directly to the battery, but they do not work when I turn off the kill switch, so I guess that means that it is not connected directly to the battery.
Jason
