Like Tree4Likes
  • 1 Post By eschaider
  • 1 Post By bobcowan
  • 1 Post By spdbrake
Old 05-13-2017, 05:13 PM
bobcowan's Avatar
Default Fuel System
Finally got some time to start working on the roller. The "assembly manual" leaves a lot to be desired. So, I'll be asking a lot of questions.
There's no fuel pump in the car. Since the car will be fuel injected, with a blower, I need something sorta hefty, but nothing outrageous. Edelbrock doesn't really recommend anything more than the stock Mustang pump. But a little extra never hurts.
Anything too big will require some additional wiring, which I really don't want to mess with. But, the car seems to be set up for a carb and distributor, so I'll probably have to re-wire the fuel pump circuit anyway.
First Question: Any recommendations for a good fuel pump that will drop in without a lot of fabrication? I'm not really concerned about cost, I want the best quality available.
Might also need a matching pump controller.
Second question: There is only one fuel line from front to back. Not a big deal, as the stock late model Mustang only uses one line. What kind of fitting is that on the end of the line in the engine bay? It's a flared fitting, but doesn't look like AN.
.boB "Iron Man"
NASA Rocky Mountain TTU #42
www.RacingtheExocet.com
