Like Tree1Likes
  #781 (permalink)
Old 04-06-2009, 03:30 PM
capteddie's Avatar
Send a message via AIM to capteddie
DV...
Check the PM I sent you about the bender pump. I need some info.
"the other ed"
  #782 (permalink)
Old 04-08-2009, 03:32 PM
Double Venom's Avatar
Did, isn't going to help much!
DV
  #783 (permalink)
Old 04-08-2009, 07:23 PM
Cobra Make, Engine: 91, 65 CR 427 289 or 302
Default To CAPTEDDIE
CAPTEDDIE:
From where did you order your hood and trunk prop rods?
Jim Hurtt
  #784 (permalink)
Old 04-08-2009, 07:26 PM
capteddie's Avatar
Originally Posted by jimhurtt View Post
CAPTEDDIE:
Jim Hurtt
Finishline. Here's the link to the rods
http://www.finishlineaccessories.com...ba5d12ef23f855
"the other ed"
  #785 (permalink)
Old 04-09-2009, 08:27 AM
And finally, the saga of the heli-coil inserts end. Coils inserted on the screws....
  #786 (permalink)
Old 04-09-2009, 08:30 AM
Finally, the end of the sage for the heli-coil inserts, (Lemans Cap base) Coils are now loaded up with Marglass. Remember to drill out the body one size over the coil size for the Marglass fill the holes also with Marglass and shove it all together while the Marglass is wet..
DV
  #787 (permalink)
Old 04-09-2009, 08:44 AM
Default OK, Cpt.... Have a seat :)
My way of striping-this is a sealer coat ;
Front and back of a 'too be' white stripe with an intermedaite coat of HOK clear
DV
  #788 (permalink)
Old 04-09-2009, 09:20 AM
capteddie's Avatar
HOLY SH!T!!! I SAT DOWN, BUT THEN I FELL OFF MY CHAIR
And then I actually got teary eyed We have paint on the car!!!!
That's awesome DV!!!! Your on a roll
"the other ed"
  #789 (permalink)
Old 04-09-2009, 11:34 AM
James Stern's Avatar
Cobra Make, Engine: Classic Roadster, 302, roller cam, Holley 650
Hot Damn. Hooray for your guys
The one line never heard in heaven; "Gee, I wish I had spent more time in the office."
  #790 (permalink)
Old 04-09-2009, 02:13 PM
capteddie's Avatar
DV
DV... The wayward pump has been found and should by repaired and back to you in the next couple of days. I have the contact that is tracking the repair, so as soon as anything changes. I'll get you updated.
Now back to painting
"the other ed"
  #791 (permalink)
Old 04-09-2009, 03:45 PM
Me thinks my spray booth needs a new coat of paint! Doesn't look that bad in person!
Pump is good news!
Two weeks huh? We'll see
DV
  #792 (permalink)
Old 04-09-2009, 04:57 PM
capteddie's Avatar
Hey DV
Do we need any kind of trim rings for where the shoulder straps come through the body? I've seen some somewhere, but not sure if we need them or not.
Finishline has these http://www.finishlineaccessories.com...f8620a4579245e
Let me know what you think...
"the other ed"
  #793 (permalink)
Old 04-09-2009, 07:23 PM
Cpt...
Not used in a CR's. Seatbelts are all connected from the frame to the driver instead of bolting to fiberglass like a lot of Cobras!
Pretty cool talking about hooking seat belts up huh?
DV
  #794 (permalink)
Old 04-10-2009, 05:50 AM
capteddie's Avatar
DV
Ya!!! Now seeing paint going on. My mind is spinning with all the little details that still need to get done. Just trying to stay ahead of the game, if we need to source something coming into the home stretch
"the other ed"
  #795 (permalink)
Old 04-12-2009, 01:31 PM
Default Def-CON 2.5
FASTEN SEAT BELTS------
DV
  #796 (permalink)
Old 04-12-2009, 03:44 PM
capteddie's Avatar
Looking good DV!!!
Can't wait to see the blue go on!!
(I'll get a update on the bender pump tomorrow)
"the other ed"
  #797 (permalink)
Old 04-13-2009, 09:28 PM
Default DefCon 3 - Fasten seat belts
Everyone wants to know how and why so long...
Body work-primer, wet sand-check body work re prime, wet sand- paint the center sealer, wet sand, mask off the stripe, seal the rest of the body....wet sand, put the first coat of color on..........wet sand.........
With pruned fingers, off to bed. Tomorrow, final color coat, unmask, check for errors..., clear coat -twice-cure then wet sand again in prerp for the final clear coat...
DV
  #798 (permalink)
Old 04-14-2009, 06:37 AM
capteddie's Avatar
Man DV!!! Your working like a man possessed
I sort of thought you were just pulling my leg about the two weeks to finish paint commitment Well looks like the car will make LCS after all
Great job DV!!! I hope your as proud of this build as I am. I couldn't have got a better person to bring this car to completion The first (of I hope many) show award she gets is coming straight to you!!!
"the other ed"
  #799 (permalink)
Old 04-14-2009, 07:55 AM
- Not possessed! Warm weather, well almost!
DV
  #800 (permalink)
Old 04-14-2009, 12:04 PM
capteddie's Avatar
Well warm weather or possessed.... keep the pictures coming. I'm back in NJ most of next week, so a photo fix will help end out the days of regular work.
Thanks DV!!!
"the other ed"
