Like Tree61Likes
  #121 (permalink)
Old 08-29-2020, 08:56 AM
Cobra Make, Engine: ERA #829, Ford 427
Slow going waiting for stuff but this weekend we will be fitting the fuel log, making fuel lines and getting things finished on the top of the motor. Once done we will be installing my aviaid oil pan and Craig’s rail supports. So slowly moving forward to where we can finally drop the motor in...
  #122 (permalink)
Old 08-29-2020, 09:50 AM
hauss's Avatar
I just could not wait that long not for me sorry That said your car looks great good luck hope you finish soon.
  #123 (permalink)
Old 08-30-2020, 08:11 PM
xb-60's Avatar
Originally Posted by CCKW353 View Post
Hi Rob
The paint is looking great. Looks like you're really gathering momentum on the build. I'm looking forward to following your progress.
This forum really needs more epic start-to-finish documented builds like yours.
Glen
Pete Munroe and rads42 like this.
  #124 (permalink)
Old 08-31-2020, 03:04 PM
Thanks guys. We extended the wiring harness so the puke tank can mount where it should , fuel log mounted, fuel lines almost done and turkey pan base is on (had gotten the 2 piece from Nick based on Patrick's wisdom).... so next weekend we will finish up and maybe attack the oil pan. Only have a few hrs on the weekend so I am trying to make the most of it. Way too busy with work but just dying to finish it!
  #125 (permalink)
Old 09-01-2020, 10:03 AM
Cobra Make, Engine: ERA FIA 2158, ERA 427SC 649 sold
Could you send a couple of pictures, details and any issues you had moving the wire harness? I am considering doing the same.
  #126 (permalink)
Old 09-01-2020, 08:29 PM
Ok, will do.
  #127 (permalink)
Old 09-06-2020, 07:02 PM
More progress.... all firewall wiring/relocation done for puke tank, radiator back in with repro top and tag from Nick, radiator fan back in, oil cooler in and one of two fuel lines for the motor is done. Will post photos soon. Leaves just one fuel line before we put on the new oil pan and pick up.
  #128 (permalink)
Old 09-06-2020, 09:04 PM
  #129 (permalink)
Old 09-06-2020, 09:05 PM
  #130 (permalink)
Old 09-06-2020, 09:07 PM
  #131 (permalink)
Old 09-06-2020, 09:08 PM
  #132 (permalink)
Old 09-06-2020, 10:08 PM
xb-60's Avatar
Rob,
Nice work on the build! You must be putting in 'extended' hours on the build if you've got significant work pressures as well
Cheers!
Glen
  #133 (permalink)
Old 09-07-2020, 07:51 AM
Thanks Glen.... you can only imagine. Weather is getting cooler so more work getting done without sweating to death
  #134 (permalink)
Old 10-24-2020, 04:19 PM
We are installing the motor and tranny tomorrow. Will post an update once the day is over.
  #135 (permalink)
Old 10-25-2020, 12:13 PM
ERA 626's Avatar
Used lizard skin and cool it on the cockpit and trunk just got lizard skin. Also used rubber undercoating in the wheel wells on the fiberglass areas but not on the aluminum panels. On the panels in the wheel wells used a product called shark skin.
I would like to see the "shark Skin " product... please send link
  #136 (permalink)
Old 10-25-2020, 01:43 PM
Hi Mike,
Apologies.... It is called shark hide. Go to sharkhidestore.com
Never used it before but figured why not try it.
  #137 (permalink)
Old 10-25-2020, 01:45 PM
Well the motor went in nicely but not the tranny. Had to order the correct size hydraulic throw out bearing. So it should arrive Tuesday and the tranny will then go in... I hope. Ha
  #138 (permalink)
Old 10-25-2020, 01:52 PM
1795's Avatar
It wouldn't be any fun if everything went well and worked perfectly. Anybody that tells you that their build was perfect is not being honest. Good luck.
  #139 (permalink)
Old 10-25-2020, 03:41 PM
Photo from today....
cobrakiwi likes this.
  #140 (permalink)
Old 10-25-2020, 04:10 PM
DanEC's Avatar
A big step. Is the tranny in too?
Congratulations
ERA 782 Running
