Like Tree17Likes
Old 10-09-2018, 08:49 PM
Bearwolf's Avatar
Cobra Make, Engine: ERA FIA kit on order
Default My number is coming up at ERA, options / order advice?
Some time ago I sent a check to ERA for $5,000 and they sent me the build manual for a 289 FIA car and Peter told me I'll likely have ERA 2159. ERA appear to be building car 2157 right now so it looks like I'll be up before too long. I've always been of the opinion that advice never hurts, so I figured I'd come and ask the veterans if there are any "must have" options that should for sure be ordered with the car.
I'm going to throw out there that I am a mechanic, I don't make a lot of money so this is an extremely budget oriented build. I plan on doing nearly everything myself. I know that having ERA bond the body would save me a lot of pain, but I don't think I'll have the extra $2k to have them do it for me so I'll probably even be doing that myself. Honestly, I'm really hoping at this point that I can move enough funds around to just be able to buy the kit and don't have to skip out to 2160 or 2161.
So far what I have on the order is:
-bare bones 289 FIA kit
-upgrade to street seats (because it'll be a lot more expensive to do later, I'll swap in a Kirkey vintage seat on track days)
-heater / defroster (because my wife said that I have to, and seeing she's letting me build the thing I better listen)
Other than that there's trunk dimples, an FIA dash and I think they have something in there about installing the roll bar
The master plan involves a lot of ordering things like the steering column, oil cooler, 6 pin hubs, rear suspension subframe and all of the small stuff as I have the money to buy it.
I guess what I'm mainly looking for is, keeping budget in mind, is there anything that should absolutely be ordered with the car, or any options that I'd really be a fool to skip out on.
Thanks for reading. I've been looking forward to building a Cobra since I was 14 years old so I'm extremely excited about it.
Old 10-09-2018, 08:58 PM
Bearwolf's Avatar
I'm not sure if it matters or not, but I have already built a 302 for it, have a TKO 600 on standby and have the rear suspension cut out of a Jag.
Old 10-09-2018, 09:44 PM
fastd's Avatar
forget the heater/defroster to save money. i dont have one but don't imagine it would work very well.
Old 10-09-2018, 09:46 PM
Cobra Make, Engine: ERA FIA 2158, ERA 427SC 649 sold
I live in Colorado and have an ERA 427 with a heater.....never used it. Definitely a place to save a few $.
Old 10-09-2018, 09:48 PM
I doubt you will need the oil cooler either if you have a high capacity oil pan, unless you are tracking the car.
Old 10-10-2018, 05:31 AM
1795's Avatar
The oil cooler you could probably skip. If your wife is insistent on the heater and defroster, do it now. It does add some heat and if you decide to drive on a cool day she may appreciate it. If you do not put it in now, she might ask for it later and I installed a heater/defroster unit post build on a used ERA that i bought due to NYS inspection regulations and it was a PITA to do once the car was complete.
Old 10-10-2018, 06:21 AM
kevins2's Avatar
I put in a heater/defroster to pass the state inspection. It is not effective at all except when sitting still so I wouldn't put one in unless necessary. If your wife is looking for warmth, heated seats are the way to go. My wife loves them and stays nice and comfortable with a blanket on her lap in colder weather. So, if you like the idea of your wife accompanying you on rides, they extend the driving season considerably.
Kevin
Old 10-10-2018, 06:32 AM
Ron61's Avatar
I agree with Kevin. I have had a heater in a couple of Cobras and took them out because they just didn't do much good. Maybe they would help if you have a top but I never had one. Heated seats are definitely the way I would go if I were to ever get another one.
Ron 61
Ronnie Widener
View my Miscellaneous Gallery
Old 10-10-2018, 06:44 AM
MOTORHEAD's Avatar
Neutral
Thinking about resale, I would think a factory attached body to frame would aleveiate a
prospective buyers concern about the quality of that bond .
I know probably most of us have done some small F/G jobs, and I am not familiar with the
ERA to know how complex that job might be, but that would be an area of concern for me.
What's your F/G experience level ?
"When Injustice becomes Law,
Old 10-10-2018, 06:50 AM
ERA 778's Avatar
Cobra Make, Engine: ERA #778 427SC Keith Craft FE 428 stroker
I built a 427 a few years ago and tried to do as much as I could myself as well. Mounting the body is a great way to save money and is certainly something you can handle. I did a lot of research on the epoxy and selected GelMagic from System 3 with the slow (summer) hardener to allow lots of time for adjustments. You will just need to get a few friends to help you remove and install the body. (I used 4 or 5 helpers since it goes easier if you have someone to spread the rocker panel areas while dropping the body over the frame. Unless the manual has been updated, it is not very good on describing the mounting process since it reflects the old body design.
While I had the body off, I flipped it over and painted the entire underside with a satin black color.
I agree that the oil cooler is useless for the street. I spent an extra $1000 to install an oil thermostat to keep the oil warm enough on mine! But - it looks fantastic!
Building the rear suspension will also save some money but you might have to get ERA to modify some parts for you. I built mine but ERA supplied all the hardware.
I would definitely spring for the powder coated chassis. Excellent protection and includes coating several other parts. Will make the whole car look more complete and ups the quality of the build.
I also recommend opting for the trunk mounted battery if that is available for the 289. Makes life easier under the hood for access to the engine and for battery swaps.
Old 10-10-2018, 08:29 AM
Bearwolf's Avatar
Loving all of the input so far.
I should have mentioned before but as soon as I have the money I want to buy a LeMans top from Mr Bruce. Watching videos from Goodwood is what ended up making me change my mind and go with an FIA instead of a 427, that's the look I'm going for. Even if my wife didnt make the heater mandatory I think the defrosters might help with windshield fog in certain seasons. I know in my 67 GMC a small amount if warm air can really clear my windshield up. I know I didnt mention the lemans top before but does this change any stances on the heater or is it still useless?
Also, I think the trunk mount battery is standard on the FIA but I'll check with Peter next time I talk to him. Thanks for bringing this up, I for sure want the battery in the rear.
As for heated seats, is this something that can be done to the ERA seats or would I have to buy different ones? I hear ERA's street seats are some of the best around.
For the oil cooler, I guess I'll get the car running and install after the fact if I really need it. At track days the most I rin right now is 3 or 4, 20 minute sessions spaced about an hour apart so the large oil pan should be fine.
I'll look into the powder coated chassis. If ERA will bond the body fir me and let me do all of the riveting and other stuff I'd be happy to let them do it if it costs less, maybe I'll ask Peter if this could work?
If I do end up bonding the body I plan on making a video so others planning a build can see what it's all about. Then you all can point out what I did wrong. If it happens maybe I'll make another post and ask if there is anyone around WI has bonded a body and would want to come and supervise in exchange for dinner. We will see.
Thank for the advise so far, keep it coming.
Old 10-10-2018, 09:44 AM
I have every option that is available, except the window washer spritzer bag and wool carpeting, and most of them you don't need, and a lot of them you'd never even know were on there. If you're watching the cost, make your decision on something based on how hard/costly it is to add it in the future. The costliest upgrade, should you choose to do it later, is the pin drive hubs and wheels. So make that decision now carefully. You don't need the ERA outboard braked rear, and you don't need a heater/defroster. You don't need heated seats either, just get your wife a 12v powered electric blanket and she can use that -- it actually is better than heated seats. You don't need wool carpeting, leather seats are another "that will cost you later, so think" but not as much as the pin drive choice. High-end gauges, mahogany steering wheels with quick release hubs, over-the-top big brakes, extra large cooling fan(s), you don't need any of that and you can always add it later. Rear sway bar, later. Oil cooler, later (I like mine and use it). Powder coating and body bonding are a now or never choice. Stuff like the Girling reservoirs, "accurate" knobs and switches, all that can wait until later. You can ceramic coat your pipes later, let that wait. Sun visors and wind wings, later. Seat belts... ehrrr, better get those now.
Old 10-10-2018, 12:38 PM
kevins2's Avatar
Originally Posted by Bearwolf View Post
...As for heated seats, is this something that can be done to the ERA seats or would I have to buy different ones? I hear ERA's street seats are some of the best around...
ERA makes their seats in-house so, rather than take them apart, I had the heated seat pads delivered to them to put in the seats as they were being built. Can't remember what they charged me but it wasn't much.
Kevin
66gtk likes this.
Old 10-10-2018, 02:26 PM
Bearwolf's Avatar
Troy, yes, it's me, Don. I couldn't decide what I wanted to use for a handle so I just used a nickname from a past life as a Marine that I thought sounded somewhat cool at the time. You're absolutely correct about my finished product goal looking nearly identical to yours. The only way to tell then apart will probably be my lack of carpet and I'll need to split the trunk lid so I can a run a LeMans top.
I do definatly want a period correct look and feel to the car, if that makes sense. Is there anything you can think of that is a must order now item as far as being a faithful period looking car? I know the 17" PS wheels you sold me aren't exactly period but they're more for being able to find cheap trackable rubber, I'll run 15" FIAs on the street.
I've been having trouble deciding between vinyl and leather. Obviously vinyl is cheaper but leather would be correct. Is it noticable?
I like the idea on running without paint for a couple of seasons. That'll get me on the road a lit quicker. Seeing most ERA cars are painted after bonding there probably wouldn't be a lot of added struggle to paint it after it's a running car anyway.
Old 10-10-2018, 04:54 PM
DanEC's Avatar
The 427 SC cars used vinyl upholstery from memory. It may be that FIA cars, since they were intended for competition, may have also had vinyl seats. Possibly a question for the "Originality" section of the forum.
You typically need to paint after bonding the body and frame. There are a few areas that rivet after bonding - most notably the rocker panels to the frame outrigger tubing but also a couple places in the nose. I guess it would always be possible to carefully drill and rivet the rockers later and leave exposed bare rivet heads or carefully touch them up with a brush and touch up paint.
ERA 782 Running
Old 10-11-2018, 10:16 PM
xb-60's Avatar
....I've been having trouble deciding between vinyl and leather. Obviously vinyl is cheaper but leather would be correct. Is it noticable? .....
Hi Don,
Good choice, ERA.
Do you know what the price differential is with leather and vinyl? My seats required two hides at a total cost of AUD 300 (USD ~210), and mine are covered all over (incl. the back of the seats) and there was enough left for the dash, so the extra cost of leather may not actually be excessive.
Leather smells nice
Glen
Old 10-10-2018, 10:02 AM
twobjshelbys's Avatar
Some states will require the defroster. I had one (the heater too) and wondered what for until I was in a rain storm and the inside window fogged up. That's why they are required in some places. Don't skimp on it.
Jdata likes this.
CSX4005LA
Old 10-10-2018, 10:05 AM
The way some guys get around that little nuisance is to buy 12v powered portable hair dryers and run them with a little flexible hose for the inspection.
Old 10-10-2018, 10:39 AM
OK, I've read this a little more carefully.
I don't want to be Debbie Downer, but someone has to say it. I'm sure others are thinking the same thing.
If you are so strapped for money that you can't afford to have the body mounted to the frame and have to wait to buy a steering column and wheels, I would say that the chances of a successful build are practically nil. Do yourself a favor and instead of buying pieces and parts over time, put the money into a savings account until you can afford a complete kit. Too many other things will happen in your life over the 5 or 6 years it will take you to pull all the pieces together, and I'd wager that in 3 or 4 years we'll see an uncompleted kit in the for sale section.
Whatever your decision, good luck.
CSX4005LA
Old 10-10-2018, 10:44 AM
There is one other way. Fly to either Atlantic City, or Las Vegas, and take a cashier's check for every cent that you've saved up for this build. Talk to the croupier and tell him "I want to bet this on one cut of the deck, double or nothing, and a tie goes to the house." If you win, then you'll get the car that you wanted, and if you lose, well then it just wasn't meant to be.
