| S |
1 |
| 5 |
8 |
| 12 |
15 |
| 19 |
22 |
| 26 |
29 |
30 |
13Likes
04-10-2010, 07:03 AM
CT
Cobra Make, Engine: FFR3985:
FFR1003985RD
Mk 3 roadster. . . non donor build
351W crate motor (carbed)from Engine factory, tremek 3650, IRS, 4 wheel disks, Team III wheels.
Color is an '05 Mustang code. . .Legend Lime Metallic with a custom "root beer" stripe painted by NC painter. Rolled edges, hidden body mounts. Interior is a Brown leather from Mercedes.
Located in Central Mass (picture below is from FFR's Plymouth run for 2 Guys Garage in '09)
04-10-2010, 03:41 PM
Pa
Cobra Make, Engine: Factory Five, 95 5.0
FFR#1005555, donor build, 96 TBbird red, chrome bullit wheels, and too many hand made custom parts to remember.
charlie
04-21-2010, 09:13 PM
NY
I own a MKI
07-03-2010, 05:57 AM
Va
Cobra Make, Engine: FFR MkIII IRS
Houston FFR
Building a Mk3. FFR 6203 Full go-kart and ready to drop the body on and start the fitup, etc.
07-22-2010, 05:48 PM
Tim Pierce, Traverse City, MI
Mark III roadster non-donor build. 351 Windsor with Edelbrock Performer RPM heads, camshaft and air gap intake, Keith Black pistons. Tremec TKO 500 trans , Lakewood scattershield and Mike Fortes driveshaft safety hoop. The chassis is complete and I am a couple of weeks into the body work. The gel coat lines have been ground out and filled with HSRF. The fender tops have been faired on the right side and the quarters which leaves the nose and front fenders. I have gained a whole new respect for body folks. I am a couple of weeks from panel fitment and the first coat of primer.
08-29-2010, 03:37 PM
PA
Cobra Make, Engine: Factory Five 5.0
Bill
Bill from Harrsiburg PA
FFR MK3
Blue with silver stripes.
09-01-2010, 08:22 PM
AZ
Cobra Make, Engine: FFR MkIII 302/345 Mass-Flo
Tucson FFR
FFR6043 Delivered 04/29/07 Mk III, Non-donor, IRS w/3.55 Traction-Lok, Levy SD T-5, FRP 302/345HP Mass-Flo, Team III wheels, Sumitomo 315/35R17, 255/45R17, FFMetal Grand Slam, Wipers, Heater. Russ Thompson turn signal stalk, Damplifier, Heat-wave, Earl's Vents. First start and first go-kart 03/01/09. Legally on the road 07/08/09. Paint by Jeff Miller (da Bat). Finished08/29/10.
11-30-2010, 05:16 PM
NY
MKI.
Bought summer of 2001
Finished November 29 2010.
2806
12-01-2010, 05:58 PM
OK
Cobra Make, Engine: FFR MK III,462 FE/TKO 600, IRS w/3.27
signature line states the main points.............
I built my engine after picking up a std bore 428 block
Scat 4.25" stroker, 10.1:1 forged
Edel heads, intake & water pump
850 DP Holley
full MSD
Comp Cams
roller rockers
go-karting is so much fun!
looking forward to putting body on!
Wideglidejoe
FFR#6143 Mk III: FE 462" w/four 48 IDA Weber's w/TKO 600 .82, IRS w/3.27, 17" Team III's w/245/45's & 315/35's. Gas N's.
Picked it up end of Aug '08
First start May 12, '10
First go kart May 26, '10
Tag & title 5-26-11, driving in gel coat
Painted Nov 2015
'05 Harley Wide Glide (60 hp stock, now 107 hp & 107 ft/lbs at wheel. Mid 11's in the 1/4 mi.)
'55 Bel Air hot rod project (WIP)
12-04-2010, 03:28 PM
Ffr6055
MKIII with IRS & pin drive. 351W with Edelbrock top end set. TKO500 transmission. Chassis is done, aligned and go-karted. Body work started spring 2010 and continues with door, trunk, and deck lid fitting. I hope to have it completed spring 2011.
12-06-2010, 06:49 PM
WI
Cobra Make, Engine: FFR MKIV 482 Aluminum by Mike Forte
Ffr # 7347
Lew Poberezny
Milwaukee, WI
MKIV ordered Sept. 02nd 2010
Stewert Delivered Oct. 11th 2010
Order Forte's Magic Dec. 02nd 2010
Roller Dec. 04th 2010
Vredestin 245/45R17 Front 315/35R17 Rear
http://ffr7347build.blogspot.com/
12-06-2010, 07:33 PM
Bruce Collins
Cleveland, Ohio
FFR 6795
Ford 390 iron block bored .030 over & stroked to 447
Vintage expansion tank
Edelbrock RPM Performer heads
Scat 4.25" Crank
Holley 750DP Carb
Manual choke
Scat H-beam rods (chevy)
Diamond flat top pistons
Comp 294s flat tappet cam
Erson roller rockers
Romec balancer
Edelbrock intake
Moroso T-pan
10.5 compression ratio
Dyno at 490 HP at 5200/510 ft lb torque at 4200
15" Vintage pin drive wheels
Goodyear 295R15's in rear, 235R15's in front
RAM flywheel and clutch
Quicktime bell housing
Tremec T-56
Ford 8.8 pumpkin, IRS with 3.55:1 ratio
Drive Shaft Safety Hoop
Twin chrome roll bars
Halon fire extinguisher
Black powder coated aluminum panels
Aeromotive A1000 fuel pump
Aeromotive firewall regulator
Stainless Steel -6 AN fuel lines
Stainless Steel brake lines
Polished roll bar trim rings
Polished seat belt bezels
Wood steering wheel
Vintage heater
Cobra heat seat heaters
Kirkey seats
Lucas style wipers
Black Bently carpet
Chrome 100 amp 1 wire alternator
3M clear splats
12-20-2010, 02:06 PM
tx
FFR 7124, non-donor. Dallas, TX
Roller, doing bodywork now. Drive train to follow.
Levy 5 link,billet LCA's & Wilwood brake package and a few other 'non traditional' modifications.
Reason: spelling
12-20-2010, 05:22 PM
FL
Cobra Make, Engine: VSE alum. frame, FFR carbonfiber body (under construction)
DALLAS:
Nice job!
Question: If you run an oil cooler I assume it will be rigidly mounted and not attached to the tilting hood/front?
How about a close-up picture of how the hood/front is supported and attaches to the piviot point?
Again....Very nice job!
11-16-2016, 06:09 PM
Just purchased this beast and put 1200 miles in two months even though I've been making many mods to suit my taste. Playing with the Mr. Bruce built hard top I got last week. I'm a rear glass and paint job away from enjoying cruising with the hard top.
11-16-2016, 06:17 PM
Pic of the car before the mods. They include rim, rubber, fuel injection, shortened reward end, Willwood brake upgrade, sidepupe wrap, hard top and roll bar with head rests
01-24-2017, 07:46 PM
Finished product
01-24-2017, 07:50 PM
Shots
01-24-2017, 07:57 PM
More.
01-25-2017, 09:36 AM
CA
Cobra Make, Engine: FFR, V8, Manual Trans, Htr, Wipers, Radio Delete
I can't believe I never posted to this thread, but better late than never.
This is a no donor IRS Mk II built by me in 13 months. Paint by Jeff Miller.
Frank
FFR - V8, Manual Trans, PS, Inop Wipers, No Radio, Gas Mileage so-so
| Thread Tools |
| Display Modes |
Linear Mode
