January 2026
4 5 6 7 8 9 10
11 12 13 14 15 16 17
18 19 20 21 22 23 24
25 26 27 28 29 30 31
  #41 (permalink)
Old 07-27-2010, 06:19 PM
It was your verbage in your original post that caused me to search the Mobil website and others for NON- energy conserving oils, that is when I found the Mobil 1 15W50. You will also find alot of 10W40 oils and 20W50 have the higher zinc/phosphorous additives since they do not classify and energy conservation. Valvoline VR-1 is a misleading fraud, they lead you to believe it has the additives but with the SJ rating it cannot have more than 800 ppm. Royal Purple also does not carry the SJ rating and loads their with zinc and phos but it is $$$$$ Pretty interesting.
Perfect example of how someone who does not carefully read your post will get mislead. 15w50 weight oil is exempt from the API limitations on SM oil. So they can indeed have the higher levels of zddp. Now if you pick up that same oil with a different weight, that zddp you want can be significantly reduced. And on the off-chance that oil has the SN rating after October and you see the words "Resource Conserving" on the label, forget it.
  #42 (permalink)
Old 07-27-2010, 06:24 PM
Yep, we don't conserve energy and we're damn proud of it.
  #43 (permalink)
Old 07-27-2010, 08:46 PM
RodKnock's Avatar
Now I realize the reason I'm running Joe Gibbs' 15w-50. Thanks.
  #44 (permalink)
Old 07-28-2010, 07:05 AM
Bob In Ct's Avatar
Cobra Make, Engine: SPF - 351W, 944 non-turbo
It should be remembered that thicker is not always better. One of oil's three functions is to carry the heat away. Is it worth going to 20W-50 just for the ZDDP?
I'm sure if somebody would produce a 50-80 oil there would be a bunch of Cobra guys that would buy it.
Bob
  #45 (permalink)
Old 07-28-2010, 07:38 AM
Well said!!!!!
Bob
  #46 (permalink)
Old 07-28-2010, 07:51 AM
Snakebit's Avatar
Club Cobra Member
Cobra Make, Engine: ERA 289 FIA #2100 Rio Red Wimbledon White Stripes 302 stroked to 331 Webers Richmond Road Race 5 speed
We don't need to run synthetic oil as we change oil once a year, which is less than 3000 miles. I use synthetic in my daily driver as I expect to get over 200,000 out of the engine. Bradd Penn realy sticks to the engine parts, when I remove the valve covers to adjust the valves everything is coated with oil.
The cost from my local distributor, 10 miles from home, is $58 per case 15W40. No shipping charges. Comes to $4.84 per quart for real piece of mind.
As far as buying ZDDP, go to your local GM dealer. I think I paid $8.99 a bottle which is cheaper than ordering from Eastwood plus shipping.
Snakebit
  #47 (permalink)
Old 07-28-2010, 09:13 AM
Yep, the puddles under my engine tend tend to run off the cement less quickly with Brad Penn.
  #48 (permalink)
Old 07-28-2010, 01:11 PM
CobraEd's Avatar
Bob
All the more reason to buy your own ZDDP. You can add it to 0 - 20 weight if thats what you want to do. Buying your own ZDDP gives you the flexibility to do whatever you want to meet your own specific oil desires.
LIFE IS TOO SHORT TO WORRY ABOUT GOOD GAS MILEAGE
________
Utinam logica falsa tuam philosophiam totam suffodiant!
________
  #49 (permalink)
Old 07-28-2010, 01:18 PM
The problem with ZDDP additives is that you can not be assured that the additive is properly dispersed throughout the oil supply.
  #50 (permalink)
Old 07-28-2010, 01:38 PM
CobraEd's Avatar
It comes pre mixed in a small oil base.
________
________
  #51 (permalink)
Old 07-28-2010, 01:43 PM
... which may sink to the bottom or float on the top. I would much rather have in from the get-go by the oil's manufacturer.
  #52 (permalink)
Old 07-28-2010, 02:03 PM
CobraEd's Avatar
You are kidding right !
________
________
  #53 (permalink)
Old 07-28-2010, 02:25 PM
RodKnock's Avatar
And not being a chemist, although I play one on TV, when it does mix, does it mix in the same manner that it mixes when manufactured at the "oil factory"?
  #54 (permalink)
Old 07-28-2010, 02:50 PM
CobraEd's Avatar
it is a perfectly clear golden oil color. There are no particles or solids in suspension. You would swear it was just regular oil.
________
________
  #55 (permalink)
Old 07-28-2010, 03:03 PM
because it is just regular oil, LOL!!!
  #56 (permalink)
Old 07-28-2010, 03:25 PM
Putting together an additive that will disperse evenly and suspend consistently in a variety of densities (different oils have different densities) is more difficult than you would think. Ed, I don't know why you are so adamant on ZDDP additives. Even if you save three bucks a quart by buying a different oil, after you buy your additive you're only saving less than $20 on an oil change. If you need ZDDP, or just want it, then taking that risk is just dumb.
  #57 (permalink)
Old 07-28-2010, 03:38 PM
CobraEd's Avatar
I am only adament about the flexibility it gives you. I have not and do not claim it will save money. All I am saying is that you can have free reign to pick and choose the very best oil per your personal preference without being hindered by ZDDP level issues since you can add that yourself.
So, . . . It is not about cost savings, it is about total flexibility and control over the oil that goes in your Cobra.
________
________
  #58 (permalink)
Old 07-28-2010, 03:49 PM
Well, what specifically is it that you want, but can't get in say BP or Gibbs? Or is your argument purely theoretical? (ie, "if BP or Gibbs didn't have something I really wanted, and I found it in another oil, but that oil didn't have a sufficient ZDDP content, then I could 'roll my own' and I would be happy.")
  #59 (permalink)
Old 07-28-2010, 04:06 PM
CobraEd's Avatar
Not sure about Gibbs, but Brad Penn is not a full synthetic.
Personally I feel that Mobil 1 & Royal Purple are the very best oils on the market. When I add my own ZDDP, I am in my happy place
UPDATE: I just checked Gibbs and it is also not a full synthetic. And, . . I don't know who makes it.
________
________
  #60 (permalink)
Old 07-28-2010, 04:18 PM
Ed,
To give you some perspective-you are debating this critical issue with a man who gladly spent $800 on a $380 flywheel and who's need for this highly specialized oil is the critical endurance of his 450 HP FE to make it to a trendy restaurant and back. His ET always includes the time of the meal.
Greg Anderson, producing 1800+HP out of 500 cubic inches worries less about his oil's molecular composition than our resident expert AT (All Things). And yes-he has a solid roller that's over an inch and springs with a jillion pounds of pressure and he changes oil after every run.
Hint: it's all about the post count.
Chas.
Rate This Thread:
