LinkBack Thread Tools Rating: Thread Rating: 4 votes, 3.00 average. Display Modes
Old 07-26-2010, 08:26 AM
Default Brad Penn Oil and the ZDDP Debate
Yes, I've been a proponent of Brad Penn oil for some time now (being a solid flat tappet type of guy that I am). This letter went out in early June of this year, but apparently it took a while before it made it to me. If you give a shi* about the ZDDP debate, this should put your mind at ease.
Old 07-26-2010, 09:02 AM
FWB's Avatar
FWB FWB is offline
i also have used this refinery's oil since 1978 starting with the kendall brand marketed as GT-1 oil, then the kendall name was sold to conoco-phillips. the GT-1 formula did not go with the kendall name.
this formula is now Brad Penn high performance oil. i use the 20w-50 exclusively in my 427 and also sell the oil thru my company http://www.origincorp.net/
we have 20w-50 in stock at 48.00 a case plus the ride, we are listed on the Brad Penn site as a PA dealer of their products.
regards, fred
Old 07-26-2010, 01:19 PM
Any disadvantages to bradd penn oil. Seams like a win win, price is about $5.25 per quart, has the zinc and phosphourous additives. Why isn't everyone using it?
Old 07-26-2010, 01:38 PM
FWB's Avatar
FWB FWB is offline
i think the lack of national advertising is the main reason. there is a void in advertising funds provided to the dealers also. i have to foot the bill myself for any ads i run on behalf of my company. compared to the other oils it really is good oil, and priced right too. the gibbs racing oil is very pricey and i can't imaging a advantage over the brad penn.
Old 07-26-2010, 01:51 PM
RodKnock's Avatar
There are many good engine oils on the market with high ZDDP levels including oils from Redline and Joe Gibbs Racing. Brad Penn is one of many good oils to run.
Old 07-26-2010, 02:06 PM
The oil companies don't make it easy to figure out what's in their oils. The "information" on the internet is completely wrong as often as it is right. People rely on an oil that they grew up with that now is owned by a different refinery, made up of completely different additives, and bears no resemblance to what it was even just a few years ago. Add to that the fact that a lot of people don't put a lot of effort in to thinking. The final wild card is that some of the testing laboratories give varying results on the identical sample of oil. Fortunately, unless you have a solid flat tappet cam, the need for ZDDP is really not that great.
EDIT -- BUT, unless I had a catalytic converter on my car, I would rather have an abundance of ZDDP even with a mild hydraulic cam and a 250 horsepower build.
Old 07-26-2010, 02:38 PM
FUNFER2's Avatar
I had a 428 FE with a solid flat tappet. With my 527 side oiler and not needing,.... the added ZDDP because of my mechanical roller, is his oil and additives, any better than most other company's ?
I believe,... this quote from his website, is the first time I've seen any comments about using the ZDDP oil additive for roller cams.
"In addition to our unique base oil cut, increased concentration of “zinc” (zinc dialkyldithiophosphate a.k.a. ZDDP) provides outstanding anti-wear/anti-scuffing protection for engines employing either ‘flat tappet’ or roller cams. BRAD PENN® Penn Grade 1® High Performance Oils have been evaluated by a number of premiere camshaft manufacturers with tremendous success. Many are now recommending our Penn Grade 1® High Performance Oils to provide outstanding protection for their ‘flat tappet’ or roller cams".
Kevin
Old 07-26-2010, 03:06 PM
I didn't think ZDDP was that big of a deal with a roller, but who knows. What might be important though for Cobras that sit a while in between starts is the "cling" factor.
Old 07-26-2010, 04:01 PM
CobraEd's Avatar
Default Isn't Brad Penn the guy going out with Angelina Jolie
Just buy your mostest favorite motor oil, and then add this:
http://www.eastwood.com/zddp-plus-oi...e-4-fl-oz.html
. . . . and you will have the best of all worlds.
________
________
Old 07-26-2010, 04:14 PM
FUNFER2's Avatar
I've kind of had the same thought, as with synthetic oil. From what I've heard elsewhere, if your car sits for more than apx,..... a week, the synthetic is so slippery, it falls off the valve train, bearings ect. ect.....
I do not know, how true this information is, especially just a week, but doesn't it make a little sense, let's say a few weeks ?
Kevin
Old 07-26-2010, 04:16 PM
dcdoug's Avatar
When will your site have the shopping cart set up?
www.partskeeper.com
Old 07-26-2010, 04:22 PM
... and when you do make sure you can undercut these guys: http://theoilwarehouse.com/
Old 07-26-2010, 04:34 PM
scootter's Avatar
I called a local dealer here. It runs $70 per case!! I can almost buy it from the oil warehouse with $27 for shipping and be the same. Anyone here in the SF bay area get it cheaper somewhere?? Hell, I pay more then $40 per case for the Valvoline 20W50. I have done the ZDDP additive, but all that stuff can be a pain. Would rather buy 1 oil, then having to put additives!!
Scott
Old 07-26-2010, 05:07 PM
4pipes's Avatar
Cobra Make, Engine: Kirkham #185, Shelby Alloy 482; sold
I think Goodies usually stocks it. Hot rod service co. In Campbell is listed on the Brad Penn site. I use the 20w50.
Dave
Old 07-26-2010, 05:16 PM
I feel with hydraulic roller and "aggressive" cams as compared to street, not racing engines the zinc and phosphorous play a key roll. One of the advantages to roller cams is aggresive cam profiles, ie, steep ramps, high lift,etc. This requires "high" valve spring pressures when compared to street, ie, 350lb -450lb open as compared to street 275 lb open, not to mention overhead cams are much easier on the camshaft itself. If you have a pushrod v-8 with anything over 400 hp, and turning anything over 5300 rpm, your camshaft, rocker arms, pushrods, roller bearing in your lifters would really appreciate the zinc and phosphoous.
Needless to say the next question is what weight, I like that Brad Penn offers 15W40, a nice medium between 10W30 and 20W50 (much much to think in 99% of applications) If you live in the rust belt use 10W30, if you live south of the rust belt 15W40.
Additivies are a pain in the a$$$$$ and run $10.00 for 5 quarts. By the time you are done you are at the same price as Brad Penn etc.
Old 07-26-2010, 05:20 PM
By the way we have high performance engines not racing engines. I played around at a shop this weekend where a guy had a drag boat. Camshaft had .995" lift, 950lb open pressure, solid rollers, rebuilt engine every 2 season or about 2 hours run time. Beleive it or not he used castrol 10W30 gtx between races. $11.00 at Walmart, LOL!
Old 07-26-2010, 06:22 PM
Cobra Make, Engine: ERA 427SC FMS 351W
Default Good Source ??
Patrickt,
Where do you get your Brad Penn oil from? I live in central Florida and all the auto parts "houses" now carry junk.
Dave
Old 07-26-2010, 06:27 PM
Originally Posted by Cobra 29 View Post
Patrickt,
Dave
I was getting it off Amazon.com and you could generally find it for just under five bucks a quart and then try for the "Super Saver" free shipping. But the Oil Warehouse now ships it to me for that price as well, so I think I will give them a try. I think that's the price to beat right now, five bucks a quart delivered to your door.
Old 07-26-2010, 06:42 PM
dcdoug's Avatar
Fred (FWB) also sells it if you want to buy from a CC member. See earlier in this thread.
www.partskeeper.com
Old 07-26-2010, 07:47 PM
$5.00 to my door, I will be ordering tomorow
