November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Old 10-19-2004, 12:13 PM
S_Beaudry's Avatar
Cobra Make, Engine: (building) - Hunter #74 w/ 302 small block (320hp under the hood). . . how many wires are there in a wiring harness?
Send a message via AIM to S_Beaudry
Default '73 390ci out of a ford pickup . . . worth $350?
Have the chance to buy a 390ci from a running '73 ford pickup truck. She actually sounds pretty good running and runs strong.
So, do you think it is worth the $350 (complete engine) to buy it and maybe rebuild it?
Any thoughts . . . .
I'm not busy because I did it right the third time . . .I think!
Old 10-19-2004, 12:34 PM
Cobra Make, Engine: Self Built, 427 USRRC, 427FE, Toploader
S_Beaudry,
Actually 80% of all our builds are based on the D3/D4----- Ford 390 engines from trucks. We have also had the best luck with this series of FE.
Yes $350 is a good buy as a cutout, that is all the brackets, alt, starter, distributor, and so on. Removing it be removing the mount to frame bolts, the tranny bolts, exhaust flanges, all the fuel/oil lines and all wiring at the motor. Finding most of that stuff takes time and get it in a pile for exchange or use.
Good luck on the find.
grumpy
Old 10-19-2004, 01:20 PM
Cobra Make, Engine: Unique 427SC-Junkyard 390 with a few aluminum parts-toploader
Don't do it!............... No matter how much money you throw at a 390, they won't run hard.
Just kidding...........
Old 10-19-2004, 01:24 PM
Cobra Make, Engine: Kirkham, Pond Aluminum 482FE
Local junkyards around me want $300 to pull one out of a truck that is out in the yard (not running)...so I'd say that's pretty decent!
Joe
Old 10-19-2004, 02:30 PM
S_Beaudry's Avatar
Thanks guys . . . . . good thing I have an oversized 2 car garage!
Old 10-22-2004, 01:55 PM
Cobra Make, Engine: Everett Morrision FE 427 so 2-4s
The Truck engines that I remember had different cranks. Getting hipo stuff for older FE truck is difficult.On the later small block pushrod truck engines had a different firing order than the engines in the cars . The cam would dictate that . And the 390 has the same stroke as the 427 but bores differ making the large valve heads of a 427 a no go.and the 427 is an almost race ready prepaired engine clearenced, oiling system modifications, etc.
In 60 Fords hot FE was a 360 hp 352. In 62 it was a 401 hp 390 in 62 it was a 410 hp 406. 63 it was a 425 hp 427 then the sideoiler, then in 68 they came up with the 428 to fill the gap between allout and streetable machines. With all the preperation involved with a 427 the 428 was also much less expensive . Picture the same blocks and start changing the bores and strokes but allways using the good parts.You can make a terror out of a 390 by evolving it into a 406 you're going to buy new pistins anyway.The truck heads arn't very racey either.
Everything has a trade off a 352 with 4" bore and a 3.5" stroke has less torque potential but higher rev potential than a 390-406 with a 3.78" stroke. The 390 is .050" bigger bore take that another .075" and you have 4.125" that is the bore for a 406 and a 428 take the 406 stroke it another .200" and you end up at 3.98" for a 428. 427 start out at 4.230" bore and its hard to get another block to go that large and end up with any cylinder walls left. Given that all the parts are the best available there is allways a trade off. short strokes give up torque for rpm potential. Bigger pistons are heavier and forged pistons are even heavier.Cheap to buy will end up expensive to build.How fast did you want to go?
Mike H
Old 08-17-2007, 06:16 PM
joey_hv's Avatar
Cobra Make, Engine: Joey Manufacturing Inc.
Send a message via Yahoo to joey_hv
hey, i found something similar take a look at this one on craigslist and let me know if its worth rebuilding..
http://houston.craigslist.org/pts/395524203.html
thanks
"Me fodder was King Neptune, me mudder was a mermaid. I was born on the crest of a wave and rocked in the cradle of the deep. Me hair is like hemp, me arms are like spars. When I spits, I spits tar. I'm hard, I am, I is, I are. "
Rate This Thread:
