Go Back   Club Cobra > Engine Building, Tuning, and Induction > Ignition
Old 03-13-2012, 08:04 PM
xb-60's Avatar
Have you considered using a real Lucas generator; then you wouldn't have to replicate one? Apart from electric radiator fan(s), which should be intermittent use, what high current draw items are there to consider?
Glen
Old 03-15-2012, 01:47 PM
ceslaw's Avatar
Glen
Interesting thought. So accustomed to thinking 'alternator' had not seriously considered the option of a true generator.
Have not researched it but guessing would need some sort of external regulation device.
Only significant power draw would be the lights and cooling fan.
I suspect one would want a robust battery to keep everything running when the output drops at low rpm / idle.
You mention Lucas. I am guessing the early Cobras used a Ford unit. I suspect they would not be that expensive.
Chuck
Old 03-15-2012, 02:50 PM
xb-60's Avatar
Originally Posted by ceslaw View Post
...You mention Lucas. I am guessing the early Cobras used a Ford unit....
Chuck
Chuck, you're correct. CSX2129 would have a Ford generator
CSX2000 - CSX2070 ...Lucas generator
CSX2071 - CSX2200 ...Ford generator
CSX2201 - CSX2589 ...Ford alternator
Glen
Old 03-15-2012, 03:00 PM
Senile Club Cobra Member
The "PowerGen" unit works well and provides a lot more amperage at low RPMs than any generatior will.
You will not have the tach drive off the back as the Lucas units had. The PowerGen has an internal regulator so the regulator on the firewall can be for "show" only making wiring easy.
rick@autoventureusa.net
Old 03-15-2012, 06:51 PM
ceslaw's Avatar
Good points. Wiring the Power Master unit would certainly be easier. Hard to misfire a single wire.
Now I need to find a good picture of what the generator regulator originally used would have looked like. Would want to use a "dummy" unit for looks on the firewall.
Old 03-15-2012, 06:45 PM
ceslaw's Avatar
Glen
I was just guessing. Wherever did you come up with those details? Excellent bit of info. Thanks
Old 03-15-2012, 07:51 PM
xb-60's Avatar
SAAC Shelby World Registry.
There's a lot of good info in the Originality Forum as well:
Originality Forum - Club Cobra
Glen
