| S |
1 |
| 3 |
5 |
8 |
| 10 |
12 |
15 |
| 17 |
19 |
22 |
| 24 |
26 |
29 |
30 |
| 31 |
02-21-2009, 07:11 AM
wa
Cobra Make, Engine: Everett-Morrison, 347 Stroker
Weber said "Good Luck Stopping Popping!!!!
I installed a set of 44 IDF weber carbs on my 347 Stroker. Syncronized carbs but cant seem to stop popping from sidepipes. I spoke to Weber and the man said "GOOD LUCK trying to stop that. Is popping common when using webers. The engine has not been dynoed and perhaps popping could be minimized. Those of you who know webers, what do you think!
Race-it
02-21-2009, 08:13 AM
Administrator
Wa
Popping when letting off gas is very common. Popping while accelerating isn't good.
I've tinkered enough to tell you that I don't know how the heck to make it stop popping on deceleration.
02-21-2009, 09:44 AM
WA
Cobra Make, Engine: FFR, Carb 302
I think they look nice.
02-21-2009, 10:10 AM
Like a beautiful woman, until they start acting up.
02-21-2009, 11:15 AM
KS
Cobra Make, Engine: jbl
from my limited experience i understand the popping on decelleration to be fuel dumping into the exhaust then igniting when o2 from an exhaust leak is intermixed, how the stuff ignites i have no idea.
02-21-2009, 11:43 AM
Ca
When do you experience the popping? Part throttle? Cruise? Deceleration? Full throttle?
Rick
02-21-2009, 12:01 PM
QLD
As above, when does it happen, what rpm at what throttle?
What's the settings of the carbs:
Venturi, emulsion tube, main, air, idle, pump jet, pump bleed, float level?
You really need a wideband O2 data logger to note the A/F ratio at the time of popping.
Gary
02-21-2009, 01:12 PM
wa
It pops at part throttle and deceleration.
Full throttle it screams!!!!!!!!! To bad God made so many trees I could stay at full throttle:
Jim
02-21-2009, 01:16 PM
Ca
Please post the air corrector, and jet sizes (idle & Main) as well as venturi size & emulsion tube # you are currently using.
We need that info before we can point you in the right direction.
Rick
02-21-2009, 08:19 PM
wa
Cobra Make, Engine: Classic ND 427 big block 427 ford with tri power I know the 427 didnt come with tri power just wanted something different. 9 inc. ford rear end top loader four wheel dic brakes.
Jim,
As steve said they due look so cool and the Cobra sounds good as you take off. Send me your correct e mial as what I have is wrong.
Andy
