Like Tree2Likes
Old 01-18-2013, 07:00 PM
In our haste to answer your question Mr '427 Street', a big fact was overlooked.
Seeking originality on a street car with an oil cooler?? Why bother when a cooler is 'wrong' in the first place?
Which is why I told him to "forget originality" in the first place. If the red and blue fittings offend thee, then pluck them out... or brush them away, as the case may be.
Old 01-18-2013, 07:03 PM
Rick Parker's Avatar
Oven cleaner or TCP used for cleaning walls will remove the anodizing without scuffing the surface of the aluminum fittings.
Old 01-18-2013, 07:36 PM
Cobra Make, Engine: ERA - B2Motorsports Dart 331
My car came with colored fittings, but swapped them all out. Tried removing the color but elected to replace.
Ordered a set of 48 IDA today from Red Line. Their fuel lines comes with the colored fittings. Elected to home brew them. It can take a little work to source the naturals.
Old 01-19-2013, 05:00 AM
No it doesn't. Aeroquip makes nickel finished AN.
Chas.
Old 01-19-2013, 06:17 AM
Senile Club Cobra Member
Nickel finish fittings are readily available....
rick@autoventureusa.net
Old 01-19-2013, 06:32 AM
computerworks's Avatar
circa 1966 (iow, original) as a sample
Blue elbow, pig metal bare metal hose fittings
Old 01-19-2013, 06:42 AM
Yes but on an S/C, not street car.
Chas.
Old 01-19-2013, 07:05 AM
Actually, that is a Comp, not an S/C
Old 01-19-2013, 07:30 AM
427 Street -- just remember, if you decide to change out the fittings instead of brushing them clean, or using some sort of poison goo on them, make sure you do a careful job, not a half-ass job. Those lines (hopefully) see a regular pressure of 60 psi and you might very well surge to a good bit more than that. These are not fuel lines with 6 psi. If you don't do it right, the line will pull out from the fitting and you're likely to burn up your engine before you notice the gauge or the smoke.
Old 01-19-2013, 08:36 AM
Jerry Clayton's Avatar
Sooooooooooo Patrick----------why haven't you told 601HP about the spark plug wires??????
Old 01-19-2013, 10:33 AM
-Because it made 601HP with 'dangerous' wires.
DO NOT encourage Harry Potter Clayton...
Chas.
Old 01-19-2013, 11:00 AM
DO NOT encourage...
Well, since you asked... Yes, I learned the hard way about the "correct" wire order on the driver's side of FEs when Jerry dinged me for twenty points at the last concours d'elegance. Back in the old days, Ford flipped the wires to help separate plug wires 7 and 8, which had a tendency to cross-fire. Now, I never had a cross-fire wth them in numerical order, but I do have the entire 8 wire order rotated a couple of slots from the original #1 placement, so 7 and 8 don't run along side one another all that much anyway. Truthfully, the Moroso wires are probably just better than the older 60's crap. Here's a shot of the order as specified by Jerry.
  #33 (permalink)
Old 01-19-2013, 11:11 AM
^^^You could disconnect 3 of the 8 wires and still have the same 345 HP that LaPine built you.
Chas.
  #34 (permalink)
Old 01-19-2013, 11:30 AM
Yep. I was savvy to that potential after reading my copy of Steve Christ's BIG-BLOCK FORD ENGINES, pg. 153, many years back. That's why I decided to try these about 12 years ago. So far, no problem!
Product Description:
ACCEL 7054, Spark Plug Wires, 300+, Spiral Core, 8.8mm, Black, Set
150 ohms per foot
8.8mm oversize silicone jacket
These ACCEL 300+ wire sets are custom tailored for race engines and their builders. The oversize 8.8mm wire is rated for 600 degrees F and 60kV. Resists heat, chemicals and moisture. High density insulation eliminates arcing. .
  #35 (permalink)
Old 01-19-2013, 11:39 AM
Originally Posted by 601HP View Post
... and 60kV.
Alright Chas, for the rest of the day I want you to study the difference between real power, apparent power, and reactive power and be prepared to expound on the subject later this evening in this thread.
  #36 (permalink)
Old 01-19-2013, 12:39 PM
Prepare THIS-
I'll be doing better things this evening than looking for your quiz Mr Wizard.
Chas.
  #37 (permalink)
Old 01-19-2013, 12:42 PM
Uh-huh, massaging those hemorrhoids again, eh Chas?
  #38 (permalink)
Old 01-19-2013, 01:11 PM
Mando's Avatar
427street, I agree the red/blue fittings look old to me too. I'm in the middle of changing all my fittings to black fittings and black/silver hose ends.
Regards.
427 Street likes this.
Mando
  #39 (permalink)
Old 01-19-2013, 05:32 PM
Dangerous Doug's Avatar
Mando: The black/silver look awesome. That's the direction I am going with my ERA FIA with my new KC 331.
Okay, everyone after me:
"Hi. My name is [insert your name here]. I am a recovering Cobra originality nut..."
Kidding aside. I walked in to the Shelby tent at the 2012 Historics and was examining the flip-top Cobra. Guess what? Red and blue steel-braided lines everywhere. Now, if the owner of THAT car dismisses originality...
You know, just sayin'...
DD
Dangerous Doug
"You're kidding, right?"
  #40 (permalink)
Old 01-19-2013, 05:41 PM
Probably didn't use AN wrenches on them either.
