Like Tree394Likes
LinkBack Thread Tools Rating: Thread Rating: 17 votes, 3.12 average. Display Modes
  #121 (permalink)
Old 01-03-2011, 01:47 PM
1985 CCX's Avatar
Differential updates.....
Made custom brackets to ally the use of a Jaguar 4HU differential in a 289 transverse leaf type A-frame. We had made the brackets using a diffy jig set up from a Shelby differential. This means correct alignment.
Test/dry fit went well and it looks to work. The benefit is that you can use a Salisbury diff made by Jaguar in a 289 chassis = more affordable direction without sacrificing original type hardware!
Benefits:
1) Jaguar diffy with Thornton posi easy to find in good working order <$1000
2) Parts are plentiful for Jag diff
3) Saves about $3000 = Win Win
Trying to post pictures.
  #122 (permalink)
Old 01-08-2011, 11:04 AM
1985 CCX's Avatar
Jag Diffy brackets for MKI and MKII Frame
  #123 (permalink)
Old 01-08-2011, 01:03 PM
mickmate's Avatar
Unroll that piece of paper behind it and put it under them for the next photo. Sheesh how can I employ you as promotional photgrapher.
mickmate
http://www.actoncustom.com/
  #124 (permalink)
Old 01-08-2011, 04:32 PM
LMH's Avatar
LMH LMH is offline
Ok, now I see how it's going to work! Nice job guys!
Alba gu brąth
  #125 (permalink)
Old 01-09-2011, 07:05 PM
Hi Jeff,
Do you or Mick have a picture of the side brackets mounted or a picture of them held up close to where they go? The bolt for the lower mount, is that a through bolt? Or does it take a bolt from each end? If it is a bolt from each end, is there threads in the end of the bushings or what? How does it work? Thanks Mark
  #126 (permalink)
Old 01-10-2011, 02:26 PM
1985 CCX's Avatar
Yes, I will try to dog up for you and post....
  #127 (permalink)
Old 01-10-2011, 02:57 PM
mickmate's Avatar
Hey Mark, I was trying to get it all pretty before a picture but here you go
As you've figured out already there isn't enough room for a through bolt. I use a 5/8 fine thread coupling nut in the centre with a hole drilled in it to reach in and stop it turning. Then it gets a shorty bolt each side.
mickmate
  #128 (permalink)
Old 01-14-2011, 08:37 PM
Thanks for the pictures. I really didn't give it a thought about the through bolt. After I read the previous post, I had to get my plans out. Now it is obvious that you can't put a 6 3/4" bolt in, there is not enough room to insert it. Jeff, if you get a chance before you install the rear end, click a few pictures of the center section with the brackets installed. Thanks Mark
  #129 (permalink)
Old 01-23-2011, 03:10 PM
1985 CCX's Avatar
Default Comp Windscreen
Comp windscreen installed
Base installation first:
Lexan self installation and fitment second:
Test drive by son third; also priceless:
  #130 (permalink)
Old 01-23-2011, 04:25 PM
LMH's Avatar
LMH LMH is offline
Thats very cute! Nice job Jeff.
Alba gu brąth
  #131 (permalink)
Old 01-23-2011, 05:21 PM
*13*'s Avatar
Windscreen is awesome!
ERA FIA 2088
  #132 (permalink)
Old 01-26-2011, 06:08 PM
gdorn's Avatar
Are these bits you are purchasing, or making yourself? cost?
Gary Dorn
Perth Australia
  #133 (permalink)
Old 01-26-2011, 10:02 PM
mickmate's Avatar
I make or have available all parts for 427's and most of the 289. I make a lot of Contemporary (out of business) and other hard to find parts for original and high end replicas with attention to detail and originality. With the axle adapter plates as pictured $400.
mickmate
  #134 (permalink)
Old 01-27-2011, 08:57 AM
legenmetals's Avatar
Looks to be a fun project-good job.
  #135 (permalink)
Old 01-27-2011, 11:44 AM
1985 CCX's Avatar
Headed to Mike McCluskey's shop this afternoon, hopefully to get some goodies......
Full report later.............
  #136 (permalink)
Old 01-28-2011, 07:55 AM
1985 CCX's Avatar
Visit with Mike was a success.
He has a great shop and very nice staff.
Few more parts off the needs list.....
Coupe in the works..............NICE!
  #137 (permalink)
Old 03-19-2011, 10:39 AM
1985 CCX's Avatar
Back at it, time has been short, life complicated and now back on track with the buggy................
Trunk tray was a *****, wow it is a tight fit however fits.....
Have a helper today! Peaking over top of boot.....
  #138 (permalink)
Old 03-19-2011, 10:44 AM
1985 CCX's Avatar
Footbox fitting was time consuming however they seem to fit and be right for the application.......
  #139 (permalink)
Old 03-19-2011, 10:47 AM
1985 CCX's Avatar
Fixed Ironman pedalbox cover..........
Correct side up
Correct rivets
much better.......................
  #140 (permalink)
Old 03-19-2011, 10:55 AM
LMH's Avatar
LMH LMH is offline
Oh, so that's how the pedal cover goes. I'll do the same to mine.
Alba gu brąth
