394Likes
01-05-2012, 04:56 AM
Yes...........
01-05-2012, 12:01 PM
Mark
My bellhousing is stock Ford item made of aluminum. I know that many guys are after the steel as a clutch can explode however I have never had that issue and feel that a true FOMOCO part is just fine.
Stock clutch planned however I am looking at lightweight set up as an alternative to reduce spinning weight. Helps on the 2-3rd change.
No drive shaft yet.....
The engine offset to the right, have to go with Nick as the car is not in my possesion to measure.
01-11-2012, 10:15 AM
01-11-2012, 02:47 PM
Cobra Make, Engine: AC cox 2699 roadster Riverside FIA RSR2001
heat shield
That`s as good as it gets Jeff. You`ll find that getting the battery in and out is fun once the body covers it.Be careful as my friend let the battery slip and acid spilled all over the place!
Best of luck and look forward to seeing it in person at one of the meets.
Ross
01-11-2012, 04:53 PM
Ross
Thank you, hope you are feeling better. I figured the battery would be a bugger however it will let me rest easier as it will be in the correct place. LOL
Look forward to seeing you as well..... Take Care
02-05-2012, 09:21 AM
02-05-2012, 10:12 AM
OR
Originally Posted by 1985 CCX
Mark
The early CI bellhousings are out there. I picked one up last year for not too much money. I plan to pull the motor this year & replace the Almnm I have in there. Chances are I'll never need it, but it's just not a chance I want to take. I kinda like having legs to walk on
ERA FIA 2088
02-05-2012, 11:06 AM
IL
Jeff there has been a lot of talk about these glovebox latchs. How do they come apart.
I see the nut to tighten it . But does the it all come apart from the front or back. Mark
02-05-2012, 11:15 AM
If you hear of a CI bellhousing for a 5 bolt 289 let me know.......... Jeff
02-05-2012, 11:24 AM
Mark
It has a blind allen nut underneath the chrome pull. This allows it to come apart for rebuild, cleaning, new lockset etc......
They are scarce in fully lockable mode. The Cobra Restorer part is a good looking part just not lockable. Not sure is is necessary to lock anyway as it is a space that I would not use for valuables.
02-05-2012, 11:36 AM
OR
Well, you can't have mine  I know they aren't as common as the 6 bolt, but they are out there. I actually was thinking of re popping them when I worked at the foundry, but there were some personalities I didn't feel confident in maneuvering through to get it done. Too bad... Mine came up on Ebay & I have seen them up a few times when I had been looking. Set up a saved search & you will be alerted if one pops up. Sometimes, like in my instance, no one bids on them because the are the 5 bolt or no one is looking at the time. I will keep my eyes peeled, as well.
ERA FIA 2088
02-05-2012, 02:34 PM
If you see one out there be sure to drop me a line.... Thanks
02-05-2012, 02:58 PM
OR
You probably already know this but I have personally seen two types of CI Bellhousing for the 5 bolt pattern. Mine says "HRA" on it. I assume this pre dates "NHRA", was before I was born... I have also seen the COBRA bellhousing which is marked across the top just like the 6Bolt CI Cobra Bellhousing. Bob Shaw Has or Had(I assume he still has it) a Unique I looked at years ago when i was trying to decide which car to build. His had the 5Bolt Cobra Bellhousing. It's a long shot, but you might get in contact with him to find out if he still has the car or maybe knows of another bellhousing. Performance & appearance products for Cobra enthusiasts
ERA FIA 2088
02-26-2012, 06:33 PM
Added a clock to the dash........
02-27-2012, 12:28 AM
Ya, but did you figure out if it works  ? Post some pics of the dash when you get it finished...
Thanks for the note on the A/C horn cap! I'll check it out...
Paul
Unique Motorcars 289 USRRC
1964 289 5-bolt block
Toploader and 3.31 rear
02-27-2012, 06:18 AM
bell housing
Fran Kress has a C.I one with COBRA stamped on it
I was going to copy and recast but after costing it out against potential return not worthwhile but nice for the one off rebuilds.I cant remember if his 5or6 bolt, but I think 5 bolt which made it even less "worthwhile".
Ross
02-27-2012, 07:27 AM
OR
Less worthwhile? I don't think so. I think some of us replica freaks would be all over it. The lack of popularity of the 64 block is, in large, due to the fact that there is no good racing bellhousing. I would have re-popped them, had the situation been better. The drawback with re-mfg them is that a new pattern needs to be made, to do it accurately. If one were to use the original bellhousing as a pattern, the copy would come out about 1/8" smaller, due to the cast iron(Ductile Iron) shrinkage rate. With that said, there is now a mfg on ebay making a bellhousing for the 5 bolt pattern. It isn't CI, nor accurate for Cobra Replica use...but it looks as if there is now an option! The Bellhousings are out there, diligence will produce one in time
ERA FIA 2088
02-27-2012, 08:01 AM
whats your guess of how many cobra freaks out there are using 289/302 5 bolt blocks first of all and then what percentage would bother to choose a correct repop against a cheaper one? As you rightly say it`s costly and to get some return on that outlay makes it in my opinion "not worthwhile"
Having said that, I hope someone ,with a lot more money than I, does do it.
Ross
02-27-2012, 08:15 AM
I think it's broken...it's indicated 2:54 ever since he posted the photo...
Nice find, Jeff!
- Allen.
02-27-2012, 08:55 AM
OR
Ross
I don't want to totally derail the thread, sorry guys  , but its not that expensive & we are talking more than just Cobras. My CI housing has HRA stamped on it. If you were to stamp Cobra on it, I'm sure royalties would make it pretty pricey.
ERA FIA 2088
