Like Tree394Likes
LinkBack Thread Tools Rating: Thread Rating: 17 votes, 3.12 average. Display Modes
  #941 (permalink)
Old 10-29-2014, 05:51 PM
Cobra Make, Engine: HI-TECH 289 FIA
A little late for you Jeff, but for straight cuts, try using a table saw or a Skil type saw with a straight edge. Use a carbide blade. This goes super quick and accurate. You can polish the edge with a file or belt sander, or just use "as cut". You can cut aluminum that is several inches thick with a carbide blade. Sheets are a breeze. Use hearing and eye protection as the "sawdust" goes everywhere. Just as in wood, more teeth gives a better cut. Hand work is for odd shapes. If you have good patterns, you can knock these out very fast.
fiaroadster
  #942 (permalink)
Old 10-31-2014, 10:41 AM
Thor maine's Avatar
Looks great Jeff! Do have provisions for a regular windshield or are you going to be doing the Ken Miles look with the goggles and helmet on every trip?
  #943 (permalink)
Old 11-01-2014, 08:43 AM
1985 CCX's Avatar
Adding a new voltage regulator as the 50yr old one may not be operational
  #944 (permalink)
Old 11-01-2014, 10:52 AM
1985 CCX's Avatar
May have found my issue?
Old regulator was a D4AF
New regulator is a C5AF
Alternator C5AF
Need to start up once freezing rain opens an opportunity
  #945 (permalink)
Old 11-01-2014, 11:39 AM
*13*'s Avatar
***duplicate post***
ERA FIA 2088
  #946 (permalink)
Old 11-01-2014, 11:41 AM
*13*'s Avatar
Hope it works out! I took mine out for a last ditch spin, this morning. Trying to snow now....
ERA FIA 2088
  #947 (permalink)
Old 11-01-2014, 01:04 PM
LMH's Avatar
LMH LMH is offline
The old regulators say not to use solid state ignition systems. Anyone know why?
Alba gu brąth
  #948 (permalink)
Old 11-01-2014, 01:18 PM
1985 CCX's Avatar
I have all old stuff, not new.
To answer that question, no idea?
  #949 (permalink)
Old 11-02-2014, 11:03 AM
1985 CCX's Avatar
Did not solve the issue.
Ahhhh.
Frustrating
  #950 (permalink)
Old 11-02-2014, 12:02 PM
CompClassics's Avatar
The old regulators cause voltage spikes that can damage solid state electronics.
LMH likes this.
  #951 (permalink)
Old 11-02-2014, 01:07 PM
*13*'s Avatar
Did you have the alt tested?
ERA FIA 2088
  #952 (permalink)
Old 11-02-2014, 03:40 PM
Send a message via AIM to krausewich
Hi Jeff,
Are all of your grounds set up well, direct to metal on frame?
MK.
-J. James
M. Krause
1.508.944.3368
  #953 (permalink)
Old 11-02-2014, 07:11 PM
Cobra Make, Engine: Scratch Built with 482 FE
Default Alternator pulley size?
Ive found with my hipo the large pulley doesnt get the alternator spinning fast enough on short drives.
SB
  #954 (permalink)
Old 11-03-2014, 02:26 PM
1985 CCX's Avatar
Ok,
All great questions....
Checked grounds, so far all checks out
Whether idle or at 70mph down the highway no charge
Mike Pack mentioned that the dash indicator has to be set correctly and its critical to the running of the system. Will check that tonight as it is direct to the "I" on the VG.
Mike Thank you..................... old electronics .......
  #955 (permalink)
Old 11-04-2014, 08:07 AM
1985 CCX's Avatar
With Mike's help........
Looks like I need to attaché the VR to the indicator light then connect it to "Run" on the ignition switch.
Also found an old diagram showing that..
Guess I will try to get this done today. Wish me luck
  #956 (permalink)
Old 11-04-2014, 08:47 AM
LMH's Avatar
LMH LMH is offline
Auto wiring is like voodoo for me! I wish it was as easy as house wiring!
Alba gu brąth
  #957 (permalink)
Old 11-04-2014, 10:32 AM
Here is an original diagram (put the three photos together) of the 1964 Ford alternator wiring diagram:
  #958 (permalink)
Old 11-04-2014, 10:34 AM
  #959 (permalink)
Old 11-04-2014, 10:36 AM
  #960 (permalink)
Old 11-04-2014, 01:02 PM
1985 CCX's Avatar
Thanks.............
on it now.......
CompClassics likes this.
