SUPPORT OUR SPONSOR
Like Tree4Likes
  • 2 Post By Wbulk
  • 2 Post By Wbulk
Old 12-21-2012, 05:03 PM
Wbulk's Avatar
Cobra Make, Engine: 66 Cobra
Default Axle Alignment Question
Do 9" rear axles have toe in or are they straight? I strung lines on both sides of my car off the frame to set my front toe, and while I was at it I measured the rear axle and found I had 1/16" toe in on each side. At first I thought I had my four link adjusted wrong so I rechecked everything and sure enough both sides are toed in. Are they supposed to be this way or do I have problems.
Thanks.
Wayne
"Everything is alive. If you get angry at a vehicle or the trans, it won't fix until you apologize and say you are sorry." "The vehicle always knows what it is doing and what the cause of it's bad feeling is. If you ask it humbly what the problem is, it will tell you. Then you and it will both be happy."
Gil Younger
HTML code is On
