SUPPORT OUR SPONSOR
Old 07-26-2004, 01:44 PM
relaxinrob's Avatar
Cobra Make, Engine: FFR Daytona Coupe done to replicate CSX-2299 at the '64 LeMans
Default Ford 9" rearend trouble!! HELP!!
My 9" is leaking so I naturally assumed it was the gasket, but someone told me to wipe the center clean and observe where the lube is coming from. It seems as if the lube is leaking out around the bottom stud and the next stud over towards the passenger side. I have done all of the normal stuff like checking to make sure they are all tight, and they are. Does anyone know if the back end of these studs go into the lube, and if so, what do I do to stop it? Do I try to take them out and put some teflon pipe tape on them? I have never faced this issue before and am looking for some guidance.
Thanks in advance,
Rob Burton
Replicas are the highest form of flattery!
http://www.rehobothproperties.com/coupe.htm
Old 07-26-2004, 04:25 PM
Bruce Edwards's Avatar
Cobra Make, Engine: Hunter with a 4.6 supercharged
Rob,
Do you have the nice little copper washers on the studs? Those are what keep it from leaking around the studs.
Bruce Edwards
Gemini Motorcars Inc.
http://home.bellsouth.net/p/PWP-GeminiMotorcars
Old 07-26-2004, 04:26 PM
Club Cobra Member
Cobra Make, Engine: Shell Valley KCR 393 Stroker Cleveland
I had the same problem on my 68 Fastback, so I got some o-rings, take off one nut at a time,roll the o-ring over the stud, pusing it up against the housing,then put the nut back on and tighten.
If this is where the leak is from, this should help.
It's a cheap fix if it works, good luck !
I have one just like that, Only Different !
Old 07-26-2004, 04:41 PM
The copper rings are cheap and will not tear. Your local Ford dealer should have plenty of them.
Bruce Edwards
Old 07-26-2004, 06:41 PM
relaxinrob's Avatar
Thanks guys.....I knew someone would have the answer for me.
Display Modes
HTML code is On
