Old 11-09-2006, 07:38 PM
Cobra Make, Engine: Superformance 351/427 stroker
Default Carb cars what fuel pump are you running..
Had a Holley blue way to noisey, some people said the carter was good. I got the Carter and it only had inlet/outlet of 5/16, they were part of the pump and couldn't be changed to 3/8 inch which I have on both sides of the pump. Now have a small, Mr. gasket "micro" but it looks like it is only putting out 3lbs.(supposd to be 4-7 lbs. according to paperwork). Haven't had a chance to thrash the car, not registered yet, to see if the pressure will be maintained at high RPM. What is everyone else using? Would have like to have just used the mechanical pump but block is 1990 I don't feel like pulling the timing cover and all that's involved.
Old 11-09-2006, 08:52 PM
Burgs's Avatar
Cobra Make, Engine: Hurricane 427S/C, KC/Pond aluminum 427/482 SO, TKO 600
Carter Competition Silver, 3/8" in/out, 6-8 psi, 100gph, internal regulator.
http://www.jegs.com/webapp/wcs/store...17653_-1_10307
Old 11-10-2006, 10:02 AM
MFE III's Avatar
Cobra Make, Engine: Hurricane Motorsports, 427w
Size:  33.1 KBHere's what I did. Used a Summit pump, that I believe is a Holley Black, private labeled for Summit.
http://store.summitracing.com/partde...5&autoview=sku
Old 11-10-2006, 10:51 AM
trularin's Avatar
Member of the north
Cobra Make, Engine: A Cobra
I have a Holley Red with a filter before. There is no syphon hills for the pump to overcome and I put a filter at the carb for added protection.
780 CFM Carb.
Old 11-10-2006, 11:14 AM
flipper35's Avatar
Mechanical.
Brent Dolphin
Old 11-10-2006, 12:08 PM
Ken Oikawa's Avatar
I'm using electric Carter Street/Strip competition with 3/8 input and output.
7psi @70 gpm. A bit noisey but side pipes drowns it out.
Old 11-10-2006, 05:04 PM
jwoodard's Avatar
Thumbs up Fuel pump
Aeromotive Street Rod Pro Billet Pump - 150 GPH
Jim Woodard
Old 11-10-2006, 05:26 PM
Secret Squirrel's Avatar
Cobra Make, Engine: Backdraft Racing BDR144
Carter Electric P4070, no regulator required.
Works Great on my Holly Street Avenger 770cfm.
Picture in my gallery, similar to the one in Burgs post.
Wayne W.
Pewter with Steel Gray Stripes
Old 11-11-2006, 11:05 PM
Default ful pump
Thanks for the responss, probably going back to original Holley Blue, after changing out Carter and Mr. Gasket pump which was defective. Hall
Old 11-12-2006, 10:07 AM
Cobra Make, Engine: SPF 2046; P.E. Aluminum 427 Windsor.
I have the Holley blue. It works fine and once the engine starts all you hear is the sweet sound of those sidepipes.
Old 04-04-2007, 07:02 AM
392cobra's Avatar
6th Generation Texan
Hey Jim,
Still like it as much as when you first got it ?
Is this the one that requires a regulator ? P/N AEI-11203
"Street/Strip"
Been checking Jeg's & Summit and that don't have a Aeromotive listed that says "Street Rod ".
They have one that says "Pro Billet" & "High Output" (same pump) and doesn't use a regulator and has a lower volume,P/N AEI-11209
Old 04-04-2007, 07:45 AM
Cobra Make, Engine: Hurricane 1014
I don't have much experience with the other pumps, but I'm on my second Aeromotive pump (Street/Strip one) and I will say it's rather noisy. Sometimes you can hear it over the sidepipes, but mainly just while idling. The first one took a dump on me after about 150miles so I think it was defective from the factory. No big deal, it happens. The new pump changes loudness to over a drive so I'm a little leary of it. I have all the proper filtration in place before and after as well.
I was actually surprised how noisy it was. I'm considering trying another pump that might be a little quieter or shall I say consistant on it's DB level :-)
This is my first experience with Aeromotive. Not saying it's bad as I have nothing to compare it to. I don't know, just trying to provide you with enough data points to make a decision.
Chassis #HM1014
http://www.cassidypics.com/cobra
Old 04-04-2007, 06:44 PM
jwoodard's Avatar
Thumbs up
rcassidy,
You can help minimize the noise level by placing some rubber insulation between the pump and your frame or whatever it's attached to.
Fred,
Yes, I am still very pleased with my pump, and yes, it does require a regulator. I got it from Rob at Keith Craft in Plano.
Jim Woodard
Old 04-04-2007, 07:35 PM
JAC's Avatar
JAC JAC is offline
Cobra Make, Engine: Classic Roadsters II
Just wondering why you guys are running electric pumps instead of mechanical?
"COBRA" Big kids gokart
Old 04-04-2007, 08:26 PM
Cobra Make, Engine: 2002 Lone Star Classics LS427, 428 CJ engine stroked to 464, 580hp/590tq at flywheel
KC told me to use the Holley black with 1/2 inch tubing to feed 600 HP - don't know what your running HP wise.
Old 04-04-2007, 08:31 PM
Putting in a Barry Grant 220 this week. Comes with its own regulator
Old 04-05-2007, 01:09 AM
Cobra Make, Engine: southern roadcraft (UK) 350 edelbrock performer rpm
Send a message via Skype™ to david dickinson
hi there i have the same pump but have a regulater as well,could this be causing low pressure at the carb? i have 4 psi and cannot get it any higher .could the pump and regulater be working against eachother thanks for any input dave dickinson
Old 04-05-2007, 02:49 AM
Holley red pump hear. Yes makes noise, but how can you hear it over the side pipes?
Old 04-05-2007, 06:38 AM
392cobra's Avatar
Thanks Jim. Are you running a 1/2" fuel line ?
Bruce, I making 602 hp.I kind of thought that 3/8" would be too small for sustained high rpm. Even to the end of a 1/4 mile blast.
The fuel tank outlet on our LSC's are 3/8",I think.If you increased it to 1/2",how did you go about it ?
Old 04-05-2007, 08:26 AM
undy's Avatar
not Bruce, but...
The fitting bung on the bottom of the LSC tank is 3/8" FPT. All you need is an 3/8" MPT x 8AN (or 1/2") 90 degree fitting to replace the old one with. That's what I installed in mine. While you're doing the work you might want to plumb it up for a return system. It may save future headaches.
Dave
Too many toys?? never!
