Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > Contemporary Classic Forums
Like Tree8Likes
  #81 (permalink)
Old 08-20-2010, 05:37 PM
767Jockey's Avatar
Originally Posted by John McMahon View Post
Doug,
It seems like the plan is to 'Pay It Forward', that being the case, I will send everything I have sitting around here, most of it is brand new. Whether its used on your car or another, its all good. Will try to pack it up today, latest by Monday and get it out to Ed.
I have seen the best in people and my family when their backs were against the wall with this disease. Amazing things can happen!
Hang in there and best of luck!
JM
That's a tremendous gesture, John. I am so appreciative of what you and everyone else has done here. I'm hopeful that I can devise a plan to use only what's needed for my build and forward everything remaining to the next Cobra guy who needs help. I've said it many times here, and I'll say it again, you guys are incredible. I don't think it's sunk in yet what you're all doing. What an amazing group of guys you all are.
  #82 (permalink)
Old 08-20-2010, 05:44 PM
767Jockey's Avatar
Originally Posted by dcdoug View Post
Just a note to all, I will be out of the country starting tonight and back next Sun. Please continue to send paypals for donations. If you'd like to mail a check and you PM me, it will probably be a week before I get back to you with my address. (unless you PM me before about 1pm today, in which case hopefully I can get back to you today)
Thank you so much to those that have given so far. To date we have raised $2,855 in paypal and checks from 28 donors, plus a bunch of folks that have donated a lot of value in parts and services.
Thanks!
WOW! This is just unbelievable, incredible, amazing........I'm out of words to describe what you've all done. Just a quick story to let you guys know how what you've done here has helped. I went to the employee lot at the airport today, only to find that my daily driver, a nondescript 2005 Chevy TrailBlazer, was stolen. It's been a stressful and aggravating day to say the least, and with all that's gone on and going on in my life right now, this is the last thing I need. However, I just turned on the computer and read all the posts here and the wonderful, tremendously generous things that you've all done, and equally important, the supportive, kind words and thoughts that you've all sent my way, and I'm right back up and fighting again. I can't tell you guys how the things you are doing and saying here are helping, in a way that extends way past the build of the car. You guys are the best, I am incapable of adequately expressing my thanks and my admiration for you all. As I said above, you're an outstanding group of guys, and I thank you all so much.
  #83 (permalink)
Old 08-20-2010, 08:45 PM
LMH's Avatar
LMH LMH is offline
Question
Geez man, so sorry to hear that! But you know what, pretty soon, your going to have a Cobra to drive!
Alba gu brąth
  #84 (permalink)
Old 08-20-2010, 09:37 PM
767Jockey's Avatar
Exactly! Thanks to all of you guys....
  #85 (permalink)
Old 08-21-2010, 05:26 AM
John McMahon's Avatar
Cobra Make, Engine: SOLD: 2013 Boss 302 Mustang #2775 (both options). SOLD: 95 Mustang Cobra R #4 of 250 "Rosie's Diner" car. SOLD: CCX2-2505, #5 of 7 289 FIAs ever produced at Contemporary! my first Cobra: Unique 427SC w/ 428CJ moder!
Thumbs up
Doug,
I got it all packed up last night, please have Ed go through it all carefully, its a big box.... lots of ziploc bags of parts and what not.
On the list I found:
braided lines and fittings (AN, 6, 8 10)
Remote oil filter housing - Ford FE
2 MSD Caps
Breathers
ARP bolts
Fuel filters
Brake light switch
Ignition wires (2 sets)
Driveshaft safety loop
Battery cables and terminals (+ & -)
Additional bits and pieces.
I also found shoulder harness mounting brackets for on the rollbar
Hope this helps,
JM
REMEMBER....In Case of Spin....Both Feet in!!!!!
  #86 (permalink)
Old 08-21-2010, 07:20 AM
JM,
Rest assured, piece by piece!
  #87 (permalink)
Old 08-21-2010, 09:54 AM
Originally Posted by Double Venom View Post
JM,
Ed,
I just shipped it UPS this morning....heavy bugger.
JM
  #88 (permalink)
Old 08-21-2010, 10:48 AM
gsharapa's Avatar
Just saw that the address was posted earlier and as previousley stated I will send the Holley Red Electric fuel pump. Although it's new it's still on the (roller) and it's still 103 plus in Dallas so probably be late next week before I can get it off and ship it.
Update: A bit cooler Sunday am so took the electric fuel pump off and will ship tomorrow or Tuesday.
Parts List – Cobra
Oil Cooler lines and fittings
Remote oil filter bracket - Ford FE
Air filter and housing
Dipstick and tube - FE 390
Valve Covers - FE 390
Holley 650 dbl pumper carb kit
Cap and rotor – Mallory Unilite Ford FE
Breathers
Summit Chrome Oil Breathere Cap - Push on type - Jim B.
Pushrods - Ford FE
Water pump - Ford FE 390
Cylinder heads - Ford FE to mate to existing Performer RPM intake
Valve springs compatible with Comp 282S cam
Stainless or aluminum water tubes and hoses- radiator upper and lower
Pulleys - Ford FE
Water Pump Pulley - Jim B.
Fan belt
Harmonic Balancer and pointer - Ford FE (Don't worry 767, we won't let Patrickt donate his old balancer )
Engine bolts – external – Ford FE
Alternator brackets – Ford FE
Fuel pump – Ford FE - Gary S.
Fuel filter
PCV plate and basket for rear of intake – Ford FE
Master cylinder – front brakes
Master cylinder – rear brakes
Master cylinder – clutch
Brake light switch and fitting
Headlight relay – Ron Francis Wiring
Braided line from clutch master to slave
Braided lines from three hydraulic reservoir cans to masters
Bracket to hold three hydraulic reservoir cans to inner fender
Ignition coil and bracket
Ignition wires
Spark plugs
Cut pile carpeting for interior and trunk
Vinyl for rear bulkhead inside cockpit
Seat belts
Rear yoke for TKO 600
Emergency brake handle, cable and caliper linkage for inboard brake Jaguar rear
Twin batteries for behind passenger seat
Stock looking horns
Gary
CAV GT40
  #89 (permalink)
Old 08-22-2010, 08:17 AM
Cobra75's Avatar
Cobra Make, Engine: CSX 4100-Shelby 75th Anniversary Edition
Send a message via AIM to Cobra75
As you can tell from the number of my posts, I don't spend much time on the the CC site. So when DC Doug alerted me of 767s situation, I had to check it out. I just spent the last 2 hours reading the history of 767s build and subsequent issues, and I want help out.
I have the following items to contribute:
Snelling and Helling air cleaner.
Chrome 427 FE Valve covers
Mallory ignition coil and mounting bracket. Revised: I see you already have this.
(I wish I had as many FE heads as 302s)
I'll keep looking in my parts bins....
I also have a FE coolant reservoir tank...not pretty, but it doesn't leak.
Could you use this?
I would be glad to help with transportation or any other logistical issues that arise.
Kudos to David Kirkham, DV, Rick Lake, DC Doug and all the others who have stepped up with more than just moral support.
Scott Harrison
CSX4100
Growing old is mandatory...growing up is optional.
  #90 (permalink)
Old 08-22-2010, 09:27 PM
767Jockey's Avatar
Neutral
Ed,
JM
Thanks so much, John - I truly do appreciate it.
  #91 (permalink)
Old 08-22-2010, 09:28 PM
767Jockey's Avatar
Parts List – Cobra
Breathers
Pushrods - Ford FE
Pulleys - Ford FE
Fan belt
Fuel filter
Ignition wires
Spark plugs
Seat belts
Stock looking horns
Thanks so much, Gary. That pump should work great. I really appreciate you sending it along, it's a huge help. Dallas isn't too far away I hope we get to meet one day so I can thank you properly in person.
  #92 (permalink)
Old 08-22-2010, 09:33 PM
767Jockey's Avatar
Could you use this?
Wow, Scott.....That's great stuff. The valve covers and air cleaner are exactly what I was going to buy. I appreciate your generosity so much, thank you! I think I'm ok for now on the expansion tank. The Contemporary requires the expansion tank to be altered, and the engine builder has altered the one on the engine that I have to sell. I'm planning to take the tank off of that engine since it's already altered. Unless FE's when purchased usually come with the expansion tank and it is expected to be on there, I was planning to sell the engine without the tank. The only way I'd need another is if I needed to put a tank on the engine to sell it. Thanks again, Scott, I appreciate it very much.
  #93 (permalink)
Old 08-23-2010, 06:15 AM
Cobra75's Avatar
Ok...they'll be on the way to DV.
Scott Harrison
CSX4100
  #94 (permalink)
Old 08-23-2010, 07:36 AM
767Jockey's Avatar
Thanks so much, Scott!
  #95 (permalink)
Old 08-23-2010, 02:38 PM
dcdoug's Avatar
Thanks Scott!
www.partskeeper.com
  #96 (permalink)
Old 08-23-2010, 03:06 PM
rodneym's Avatar
Full Blown Member
Premier Contributor
Default Here you go!
Doug,
I wish I could have donated some parts or service but I sent a little of the green stuff. You'll at least need it for gas!
Best of Luck!!!
rodneym
  #97 (permalink)
Old 08-23-2010, 04:02 PM
FFR428's Avatar
Cobra Make, Engine: HM-2027 / 427 SO
Doug, I cleaned and painted everything Sat. It'll all get shipped by Wed to Ed's address.
Glenn.
  #98 (permalink)
Old 08-23-2010, 07:10 PM
gsharapa's Avatar
Doug,
Shipped the Holley Red Electric Fuel pump out at lunch and is scheduled to be delivered on Thursday. I now noticed we were suppose to put your name inside the package so let Ed know this is for your car. Funny I actually owned the Team Jenny Kirkham FIA for a year or so and didn't know Ed still collect for that project every year. Good luck with the car and your health!!
Gary
CAV GT40
  #99 (permalink)
Old 08-23-2010, 07:42 PM
767Jockey's Avatar
Glenn.
That's incredibly kind of you, Glenn. Thank you SO much, I truly appreciate it!
  #100 (permalink)
Old 08-23-2010, 07:46 PM
767Jockey's Avatar
Doug,
I really appreciate that, Gary. Thank you so much. I owe Ed a call just to touch base, I'm sure he's taking good care of the stuff that arrives. The Kirkham must have been an awesome car, aren't they all? Thanks again, Gary, I hope one day to return this kindness that you've all extended to me to another brother in need.
