4Likes
07-28-2013, 09:53 AM
TN
463 IR Windsor
I have been working on an engine build the past year and I thought I would share with U guys.
The goal was to build a one off, very potent, yet somewhat exotic naturally aspirated small block that would produce substantial amount of HP, and TQ, run on 93 Octane, and have acceptable manners for the street use (A tall order in deed).
I begin an inventory of what I had and what I needed to complete the goal. I enlisted help of Jim Kuntz of Kuntz & Company to help me develop my goal. For those of u who are not familiar with Jim kuntz, let me introduce you. Kuntz and Company is an upper tier level engine builder who specializes in Ford engines. Jim is old school. He does not advertise and his web page is not much to look at, but his customers hold more records then I can list.
I called Jim and told him I wanted 700+ HP, 600+TQ pump gas small block, and I did not want to break the bank. He laughed and said “you and everybody else”. We discussed different combinations for about an hour before a plan came together. We decided that most of my current short block components (463 SBF) were up for task, but the heads and cam had to go (I had already decide on a stack Injection)
My original engine consisted of a Dart sportsman block, Eagle 4.250 crank, Eagle 6.3 H beam rods, Race Tech Pistons .875 Crower sever duty solid roller lifters, LSM solid roller cam, AFR 225 heads, Edlebrock super victor intake, and a Quick Fuel 850.
The short block was disassembled and parts inspected and machined if needed. The block was prepped for race use, extra attention was given to oiling and machining and cleaning up the block casting. The forward lifters bores were plumbed for improved oiling. Center drain holes in the lifter galleys were blocked off, and the front and rear drain holes were enlarged. Lifter bores were enlarged and bronze bushings installed. New ARP 2000 rod bolts were installed along with a new set of Crower EnduraMax .903 bushing lifters. The Race Tech Pistons received a set of Total Seal Rings, Avaid supplied the S2 5 stage dry sump pump, Armando supplied the oil pan, and a Patterson tank holds the oil.
Kuntz is a master with induction flow and a lot of time was spent discussing different head and cam choices. I eventually decided on a set of TFS (TEA) 240cc Hi Ports (no problem finding shaft rockers or pistons). The heads were designed for 427+ CI engines, and target mid lift flow. Valves provided by Ferrea (5/16 Steams),and Springs are PAC circle track 1500 series. Crower stainless shaft rockers (1.70 Ratio) with pin oilers keep everything stable.
Flow figures provided by TEA (2” pipe) are as follows:
Lift Intake Exhaust
.300 233 168
.400 292 209
.500 322 238
.550 331 250
.600 342 258
.700 350 269
LSM supplied the custom ground camshaft. 110 LSA 270/279 duration, 696 /690 Net lift (installed at 105.5) . I discussed the spread on the duration with Jim and we both agreed with the extra long primary tubes that are indigenous to cobras, that more exhaust duration was needed. Ramps are not overly agressive since primary duty is street use.
Sitting on top of the TFS (TEA) heads is a 3 piece Hilborn IR injection system. I chose the Hilborn over other brands because of the larger runners (2 7/16 blades) available for the 351W based engine. I talked to many of the other manufactures before choosing Hilborn. When pressed, most other manufactures admitted that their product would not make the horsepower I demanded. Kinsler and Engler Machine were at top of my list, but Kinsler was above my price point and Engler did not make Aluminum Runners (magnesium only).
Injectors are from Injector Dynamics.
Ram tubes provided by Engler machine (Tim Engler can make any Ram Tube dimension you might need).
Accell DFI dual sync distributor fires the plugs, and receives its timing commands from a Fast XFI 2.0 ECU. Headers are custom stainless steel steep headers 1 7/8 to 2” with SPD 3.5 collectors (My headers were used during the dyno session).
Dyno day finally came, but not without problems. The center cylinder’s (2,4,6,7) would pulse and spark, but the outside cylinders would not. The computer was showing the rpms during cranking ranging from 0 to 12000! After retracing wires, rechecking grounds, ½ the problem was found (cam and crank signals reversed in DFI harness from the factory). I reversed the pins, but the cam signal was still not working correctly so we switched to bank to bank. It had taken all day to resolve the problems. Time was running out. It was now 5PM and we had not started the engine. Moment of truth “Fuel pump on and a push of the start switch”. The engine fired off and idled at 750RPM. Idle was adjusted to 1100 and couple small leaks (loose AN fittings)fixed, and some quick timing adjustments and we are off to the races. Break in was uneventful and no metal found in the oil filter.
First pull would be from 3500 to 6500. Some adjustments were made to air fuel ratio, timing, and another pull to 6500. Still running lean in 4000 to 5500 range so more adjustments made and another couple of pulls to 6500. Timing was set to 32 degrees. Next pull was to 7000 and dyno read 741HP at 6600 and TQ 633 at 5400! Timing was adjusted to 34 degrees and another pull to 7000. The engine liked the extra timing, yielding an Averaged hp of 581 and 574 TQ. Max HP was 738 and max TQ 648. Out of time and well pleased with the results we called it a day. I discovered after I got home that we had forgotten to adjust the timing above 6500 prior to our 7000 rpm pulls. With more time I am sure we could have squeaked out 750HP.
Important Notes:
Engine was dynoed with following: Alternator, engine driven water pump (overdriven), Cobra headers, 93 octane, Break in oil, Vacuum relief set at 10”
Compression 11:1
Precision Race Engines preformed engine dynoing.
Special Thanks
Jim Kuntz Kuntz & Company
Mark Davis Precision Race Engines
Mike Schmidt Total Engine Airflow
Steve Sr. LSM
Rich FastmanXFI
Andy Hilborn Fuel Injection
Tim Engler Engler Machine
Mike Patterson Patterson Enterprizes
07-28-2013, 11:30 AM
KS
Cobra Make, Engine: jbl
WOW! Very good numbers.
07-28-2013, 02:46 PM
Very nice project and great results. You picked the right guy in Jim.
It's a moot point now as you have a successful build with 'only' 350 heads-but ask Jim next time you're there about the 10 deg, 410CFM World head he largely developed. You'd have needed a sheetmetal intake though....
Chas.
07-28-2013, 04:09 PM
KY
I thought Gary's engine was an underwear-striper, but you're 20 cubes over him....plus a half point of compression, 10 more degrees of cam, 15 more cc of head volume, and pulling vacuum on the crankcase. That'll be a barn-burner for sure....
Congrats man, sweet engine, and good choice of builder. I have a lot of respect for Jim.
07-28-2013, 07:34 PM
NJ
Cobra Make, Engine: BDR #1230/B2 445CI SBF
Congrats Mark-i was wondering when you would go public!!! It was hard for me to keep my big mouth shut
Gary Bowman
Voorhees NJ/Key Largo Fla/Ventnor NJ
07-28-2013, 07:53 PM
TN
Thanks Vector1
Yea like i need those heads.  Chas once we established that we were looking at 1.6 to 1.65HP per cubic inch with the 240 heads i said thats enough HP. He Dynoed a 422In small block recently that made around 1050 (all motor).
Brent I am very pleased. I was a little nervous about street manners of the large bore IR manifold (no previous experience), so i went ahead and spent the extra bucks on the ID injectors. I think it was money well spent.
07-28-2013, 07:55 PM
TN
07-28-2013, 10:27 PM
CO
Sweet! That is a very impressive motor, with very impressive results.
I am especially impressed with the changes made to improve oiling to the lifters. I was under the impression that the Dart block did not need these changes.
What is the reason for the bronze bushings for the lifters? Longevity? Reduced friction?
You didn't mention it, so maybe you already did this. For street/part throttle driving, it's very important to get the throttle bodies perfectly balanced with a synchrometer. If you don't, it will never run right at part throttle under a load, and no amount of tuning will get it right.
I had to figure this one out on my own. I find I need to adjust this about twice a year.
Tuning Tools
.boB "Iron Man"
NASA Rocky Mountain TTU #42
www.RacingtheExocet.com
07-29-2013, 01:58 AM
KY
We do the bronze bushings sometimes when the lifters are really tall. Under high lift with high spring pressure, the lifters will want to "wiggle". One, it's easier to R&R a bronze bushing. Once cast iron is oblonged, then the only choice is to....well....put a bronze bushing in it. Another reason is that we can leave the bushing sticking up out of the lifter bore some, so that gives added stability at full lift.
07-29-2013, 10:04 AM
KS
Don't want to intrude on your oil plans, on my dry sump after break in I have finally settled on a Mobil 1 0w40 oil, rated with european standards and I think it was recommended for some of the current dry sump production cars. Numbers looked good and I haven't noticed any loss of oil pressure compared to my previous brands & weight at temperature. Auto parts stores charge a pretty penny but you can pick it up at walmart for $23 a jug.
07-29-2013, 12:16 PM
TN
Bob I agree with Brent, but i would add that it does reduce friction (dissimilar metals) and it gives u an opportunity to verify and correct bore alignment. I went with a .903 vs .875 lifter so adding bushings was not a problem.
The SHP or sportsman block does not have rear oil feed, so oil travels from the front to back, therefore; the rear lifters are fed first. By tapping in from the rear and plumbing to the front a more balanced stream of oil is provided to the forward lifters. I am sure Jim could add to this.
MP
Reason: spelling
07-29-2013, 08:28 PM
TN
[quote=bobcowan;1255090]
Andy (hilborn Fuel injection) educated me on this very issue. Very good point.
07-29-2013, 08:31 PM
TN
They do have the best price on Mobil 1.
07-31-2013, 10:47 AM
Very impressive on a pump gas motor! You'll have to post up it's driving manners when you get the chance.
07-31-2013, 12:14 PM
CO
The SHP or sportsman block does not have rear oil feed, so oil travels from the front to back, therefore; the rear lifters are feed first. By tapping in from the rear and plumbing to the front a more balanced stream of oil is provided to the forward lifters. I am sure Jim could add to this.
MP
Very interesting. Next time I do a major overhaul, maybe I'll do that. I don't have any lifter problems, and I don't seem to have any problems with oiling. But I don't really want to wait until I do have a problem. That looks like a simple enough mod to do in the garage.
I'm still considering dropping solid roller lifters on my hydraulic roller cam. So maybe I'll have the machine shop put in some bronze bushings.
Thanx for sharing that with me/us.
.boB "Iron Man"
07-31-2013, 12:42 PM
KY
You don't need it Bob, and it's a lot of expense to do it correctly. You can't just drill the hole and press a bushing in, it needs to be done with the block and a BHJ lifter fixture for it to be done right. Most hydraulic roller cams do not have the lift nor do they require the spring pressure to need anything near this kind of prevention, and you won't see any horsepower increases because of the bushings.
As for a solid lifter on a hydraulic roller, be aware of what's necessary here....you still need to run lash, and you will need to run a very tight cold lash, because hot lash needs to be in the .006-.010" range. Even then you still have lash, which coupled with higher valve spring pressures is what kills a solid roller lifter over time. There are many short travel hydraulic roller lifters out there from Comp or Morel, where you can adjust them and run high spring pressures and get more potential rpm out of your combo.
07-31-2013, 12:50 PM
KY
You don't need the bushings, Bob, and it's a lot of expense to do it correctly. You can't just drill the hole and press a bushing in, it needs to be done with the block and a BHJ lifter fixture for it to be done right. Most hydraulic roller cams do not have the lift nor do they require the spring pressure to need anything near this kind of prevention, and you won't see any horsepower increases because of the bushings.
07-31-2013, 01:13 PM
Brent,
Bushings also allow machining the lifter bores individually to optimize cam / pushrod angles-correct? I've seen it done frequently on Hemis and Wedges.
Always reserved for maximum effort motors-yes?
Chas.
07-31-2013, 01:16 PM
KY
I got an email that you replied Chas, but for some reason, the website won't let me go to page 2, no matter what I do.
But yes, bushings can be used in that aspect as well, when you need custom angles, or you need to move lifters around for better positioning.
07-31-2013, 09:49 PM
CO
Oh, sorry. I meant the oiling mod. That looks like a fairly simple job I could do in the garage. I don't think I have any oiling problems now. But you don't really find those kinds of problems until something goes, Boom!
The lifter bushing, OTOH, would definately required a skilled machinist with specialized equipment. That is something I would not consider doing on my own.
As for the lifters themselves, I'm using Comp Cams hydraulic short travel lifters and beehive springs with a slightly higher rate. The engine easily runs to 6,500 rpm's.
Every year I consider solid lifters, just for the fun of it. But, so far, I haven't done it. I think at the last minute my smart brain over rides my crazy brain, and I stick with what works.
.boB "Iron Man"
