| S |
| 1 |
5 |
| 8 |
12 |
| 15 |
19 |
| 22 |
26 |
3Likes
05-29-2016, 10:01 AM
WI
Originally Posted by blykins
Well, with that logic, you *can* buy *real* FE engines for the same or less money than a small block.
(Where? you mean a 390 built to fool the public into thinking it's a 427 side oiler?)
I just don't see why you would pay for a small block Ford and then make a feeble attempt to make it look like an FE ....when you could have bought an FE to start with.
I understand that replicas are replicas, but bolting FE parts on small blocks to try and fool the public and pass it off as another engine is just absurd to me.
Well, in my case - for just one example - I bought my near basket case replica down here with a Chevy 383 stroker already installed. when I rebuilt it with all new parts and wiring from Unique Motorcars, I thought about converting to an FE and Ford drivetrain, but with our import duties and tariffs it would've cost me 3 times as much as you would pay in the US.
The Chevy stroker has been strong, ultra reliable and runs like a scalded cat, so the conversion is simply not worth it as far as I'm concerned. I like the look of the black finned Cobra valve covers (without the "powered by Ford" script) and if I can find an adapter, I will bolt them on.
Not trying to fool anybody - just doing what pleases me without giving a fat rat's ass if it puts someone else's nose out of joint. Feel free to do as you please with your own car and your own money.
Tropical Buzz
05-29-2016, 10:23 AM
CA
Hey, here's a nice set of SBC heads from GM that look like they are BBC heads.
This stuff obviously happens all the time!! Shucks the valve placement even resembles a BBC, not to mention the rocker covers. Intake manifold is OK too.
This masquerade approach is obviously the plan ...
Ed
05-29-2016, 10:29 AM
WI
Thanks anyway, but I'm really not interested in making my engine look like a BBC. If you're so keen on being of assistance, find me a set of adapters for the Cobra valve covers.
Tropical Buzz
05-29-2016, 10:41 AM
KY
Buzz, my gripe isn't with you as you obviously have a Chevy engine and aren't trying to disguise it.
What I find hard to stomach is the guys who tout that their SBF or their SBC is the far superior choice, then try to make their engine look like an FE....
I noticed that Joe edited his post to add that an FE is "more expensive" than a SBF. Simply not true. You can have a 525-550 hp FE for the same price (or less) as a Dart blocked SBF. It's also funny that guys use weight as a bias. Obviously the original 427 Cobra didn't have trouble winning LeMans with that big ole heavy FE engine in there. 99% of the guys here do not race their cars and probably couldn't tell the difference in weight while driving any way.
When you get down to looking at it, how far are you willing to go to fakely make your drivetrain look like the original? Glue external linkages to the side of your TKO so it looks more like a Toploader?
05-29-2016, 11:30 AM
Wrong on the edit, fixed a typo "build" to "built".
As for the rest, I think you are a little clueless about the reasons for going with FE covers on a SBF.
1. For some the FE pentroof cover just looks better than a SBF cover. If that suckers the "experts" then the joke is on them isn't it.
2. As these are freakin' replicas isn't that the idea - make it look like something it isn't.
3. Some replicas are designed for a SBF and not a BB - and done so for a reason, look at the replicas makers biased toward the track environment.
Just because your bread & butter is building FEs, that doesn't make it the smart choice, and for many it isn't. But making your replica look the part is the common thread and done to varying degrees by all.
05-29-2016, 12:51 PM
KY
There are pentroof SBF valve covers out there that don't require trying to make an engine into something it's not.
Also, just because all of this is your opinion doesn't make me clueless. I get that you have FE envy.  I had it too and went through all the same steps with my own Cobra. It initially had a Windsor. I stroked it and got as close as I could to 427 inches just because, you know, that's the magic number. Went through all the same mental exercises that you're going through, trying to make my Cobra play the part. In the end, I sold the 425W and built a 428FE for it.
05-29-2016, 03:06 PM
CA
You're missing the mark Buzz!
SBFs made to look like BBFs. SBCs made to look like BBCs. This predisposition to look like something that was desirable (the Big Block versions of each engine line up) is not a one time, one family occurrence. It happens across more than one engine family and more than one manufacturer.
If anything it is an endorsement of what is being attempted rather than a critical review of it.
With respect to the set of adapters you indicate you are looking for, I think you are uniquely qualified to research and find those all by yourself.
Ed
Reason: Spelling & Grammar
05-29-2016, 05:50 PM
WI
Ed
Not at all Ed! I know exactly what I want to do and believe me when I tell it's totally unrelated to and uninfluenced by other peoples' fads, trends or opinions.
Ed
I appreciate the vote of confidence. It takes a real man to openly recognize the positive attributes of his peers.
Tropical Buzz
05-29-2016, 10:47 AM
WI
I think some builders put fake crossbolts on 390's...
The weight issue is really a non-issue. Big block Cobras are actually quite neutrally balanced, some even with a slight rear weight bias.
Tropical Buzz
05-29-2016, 11:00 AM
KY
Equally as sinful....
The originals had 428's in them. I suppose if you're going to mislead someone, you could always tell them it's a 428.....
05-29-2016, 01:06 PM
... you are still kind of clueless on the reasons why, even after it was explained to you.
05-29-2016, 01:12 PM
KY
Trust me, your three "reasons" weren't explanations for anything.
1. That's your opinion.
2. Lame excuse, if you really want to make it look like something it's not, put an FE in it. A stinkin 352 would look closer to the original than a Windsor with those big valve covers hanging off each end. If you spend all your time trying to make your Cobra "play the part", then it will be a never-ending journey. If you were proud enough to put a Windsor in your car, then be proud of it. If you like pentroof valve covers, which is understandable, there are plenty of them out there that fit Windsor heads.
3. There's only one that I know of: JBL. Do you have a JBL?
05-29-2016, 08:11 PM
FL
Cobra Make, Engine: Contemporary Classics, red white stripes
I can see both sides.
I sometimes don't get it when people put stuff on an engine to make it look like another engine. I have seen a Pantera 351C with valve covers that made it look like a DOHC engine. It was most likely custom. I can't imagine anyone tooling up for something like that.
On the other hand, I'm not that crazy about Windsor valve covers. I have had several SBFs, and the valve covers look like small block valve covers. They are puny. The FE covers, on the other hand, look the part. I could see using pent roof covers on a stroked 351W in a Cobra. They would probably look awkward on an 8.2" deck block, though.
05-30-2016, 06:13 AM
KY
Anyone make adapters to put a 289 FIA valve cover on an FE?
05-30-2016, 06:25 AM
WI
  - Ok - good one, I have to admit!
Tropical Buzz
05-30-2016, 07:45 AM
New FE Valve Covers on 351W
Looks good Brent, nice job on those FE style valve covers for the 427w
Reason: added style
05-30-2016, 07:53 AM
KY
Well, before you pee your pants from excitement thinking that you got me, those are valve covers made to fit a Windsor......they are not FE valve covers.
They are the same size as a Windsor head and everyone knows it's still a small block. There's no trying to fool anyone into thinking it's an FE....which seems to be the point in the valve cover adapters. Otherwise there are plenty of pentroof valve covers for small block Fords. Ford Racing makes them, Blue Thunder makes them, etc.
Using the FE valve cover adapters so that you can put FE valve covers on a SBF would be exactly the same as my point about trying to fit 289 FIA valve covers on an FE, so that people will "think" that you have a 289 car. No logic there.
05-30-2016, 08:04 AM
KY
Listen, I agree totally with you that pentroof valve covers are more appealing than the standard SBF valve covers. I use them quite a bit myself as they give more room for "race stuff" underneath. They even make them for Cleveland heads:
However, the adapters are made for the sole purpose of trying to make an engine look like something it's not....to fool people who look at the engine into thinking there's an FE under the hood. That's what I have a problem with. If you want the width, height, and appearance of an FE to make your replica look more correct, then my point was to just put a stinkin FE under the hood to begin with and you won't have to go through all the cloak and dagger junk.
05-30-2016, 08:08 AM
KY
Here's the Blue Thunder pentroofs on a Windsor head. Pentroof style, but they are made to fit a Windsor and are not intended to look like an FE.
05-30-2016, 08:24 AM
I almost did pee my pants, great cost effective solution. Then upon closer scrutiny I realized Ford Racing didn't quite get the shape and size right, oh well
I'm just trying to make it "my own" as many have recommended, the mantra in these here parts ...
Go forth and enjoy your cobra as you have made it, we're all one big happy family!
... yeah right, my ass
| Thread Tools |
| Display Modes |
Rate This Thread |
Hybrid Mode
