08-11-2008, 02:01 AM
OIL PANS - Superformance.
Wanted to get an idea on what the favorite Oil Pans were in your Cobras with a SBF.
Choices ;
FoMoCo ; Stock 5qt front sump
Canton Race 7QT
Boss302 Stock 6 quart
aluminum 5 quart cal-kustom
shelby "cobra" 7 quart aluminum (branda)
or >?
thoughts --tricks>? this is for a street car. with an external oil cooler and temp. IE i do not need a temperature lead in the PAN.
--Steve
08-11-2008, 09:44 AM
CO
Cobra Make, Engine: SPF Roadster, 418W
Canton, but I was advised by the engine builder (Performance engineering) not to run the oil cooler on my 418 Windsor unless I was going to track the car.
Terry
08-11-2008, 10:38 AM
Mi
Mine is a Canton ....with oil cooler not connected . All street use , no track or strip . Bill
08-11-2008, 11:06 AM
ny
Cobra Make, Engine: Gary Edwards Racing 460
Canton - No oil cooler necessary for street driving.
Its not the will to win that matters....Everyone has that. Its the will to prepare to win that matters.
08-11-2008, 12:20 PM
MI
Canton road race SBF pan
Canton remote canister oil filter and thermostat.
AN-12 lines, remote adapter from Rob Frink at Beaumont Metal Works.
http://www.beaumontmetalworks.com/index-perf-ap.html
Setrab cooler
Street and road track use
08-11-2008, 01:09 PM
Aviaid. (Armando)
Armando's Racing Oil PansArmando's Racing Oil Pans. High-performance oil pan manufacturerer for all engines and kinds of racing. Dry sumps and wet sumps.
Show map of 15476 Montana Ave, El Paso, TX 79938
www.geocities.com/motorcity/flats/1624/ - 19k - Cached - Similar pages
B. Ewing
08-11-2008, 01:46 PM
Cobra Make, Engine: Superformance #2589 Titanium w/ Indigo Blue Stripes 408/351w TKO600
I also have the Canton, it was recommended to me and i can't comment on it's "performance". It fits though.
08-11-2008, 05:22 PM
Cobra Make, Engine: FFR, 331 Sportsman block, T5Z, 3.55 IRS, Fuel Safe cell
Originally Posted by bret a ewing
Aviaid. (Armando)
I also have an Armando's pan, but it's the GT40 style. My oil temp dropped by almost 20 degrees when I switched from a Canton rear sump RR pan to the GT40 style front sump, with no other changes.
FFR, 331 SBF dynoed 372RWHP@ 6100 RPM on 87 octane pump gas
09-25-2008, 12:21 PM
Ran into issue with the FORD BOSS 302 block (new one) and my 1970 style BOSS302 oil pan and timing cover combo. Problem --no dipstick boss in F6 style timing cover.
--engine in car, all together,.ugh!!!
--the modern boss 302 block has a dipstick tube boss in the drivers side of the block, the boss302 (repro) pan has a front sump./ they dont line up.
I am running an oil cooler, and this is a street car so i think i will go with a rear sump Fox style pan for now and get it on the street.
also saving about $400 in the process.
Steve
09-25-2008, 02:00 PM
This is an Armando's Cobra Pan:
[IMG]  [/IMG]
09-25-2008, 06:54 PM
Banned
Steve
The swear jar would have been overflowing in my garage.
09-25-2008, 10:02 PM
Tx
Canton 680-S (14 ga.) 9 Quart.
Remote oil filter, Oil Cooler with a thermostat.
09-26-2008, 12:41 AM
No
Refabricated Fox rear sump; hump taken closer to crank (actually only 2-5mm clearance for my stroker crank) and forward to clear steering and rear kick-out to both sides w/ trap doors. Crank scraper welded to bottom of pan. 7 qtrs.+.
Large grille-mounted oil cooler w/ thermostat take-off and an-10 hoses.
"Warm" engine at 80 centigrades oil temp. runs cooler in cold weather (unfortunately...).
For street & track.
09-26-2008, 07:49 AM
Steve
Not a problem, remove the timing cover, drill and tap for a compression fitting and make you own tube. Actually the easiest solution is to remember to tell Armando that you need a dipstick bung in the front sump.
09-26-2008, 09:51 AM
Cobra Make, Engine: SPF #1019
[IMG]  [/IMG]
Wow! Rick, you either have a very understanding wife to allow you to build your motor in the dining room or have a very interestingly decorated garage/work shop
Happy Friday,
Randy R...
09-26-2008, 06:51 PM
MD
None of the above. Aviaid
