Old 02-11-2010, 05:00 PM
Default TKO 600 Neutral Safety Switch.
I have a TKO 600 with the standard neutral safety switch and would like to disconnect it so that I can start the car while in gear in case of trouble.
And no, I don't want a bypass switch. I just want to remove/disconnect the existing switch.
Where is the switch, and how do I disconnect it without causing any other problems?
Old 02-11-2010, 05:13 PM
I am not sure were they put there's but I put mine in the clutches hydraulic line look there.
Some guys put a touch switch on the peddle.
Stop by and see what we are working on @ www.eddytheb.com
Old 02-11-2010, 06:57 PM
Cobra Make, Engine: Antique&Collectible 392 stroked
the tko 600 has two wires coming out of the side of the trans around the shifter location on the drivers side.these go to the safty switch. cut the wires and cap off the two going in and out of trans. splice the other two together and that should eliminate the switch
pops67
Old 02-11-2010, 07:13 PM
PANAVIA's Avatar
If memory serves they should be black and white stripped wires from the top of the tunnel. they lead into a switch which is on the SIDE of the TKO 600.
There are two switches on the TKO
1. reverse lamp switch
2. neutral saftey switch
the factory SPF harness has a dual female T connector off the car harness that you could take 2 x 1/8" male uncovered terminals and make yourself a jumper wire to plug in.
Steve
Old 02-17-2010, 11:01 AM
Sounds like wiring a hidden button to that switch, would be a cheap but efficient way to make sure unauthorized drivers don't steal the car
Old 02-17-2010, 12:28 PM
The switch is just in front of the tailshaft housing and has a pigtail going to a plug. (drivers side)
The one on the drivers side about mid-way is the reverse lights (has two pins sticking out the top). You may also have a sender on the passenger side which is the speedo.
The TKO manuals are here: http://ttcautomotive.com/English/onl...er/product.asp
(the TKO is basically a upgraded 3550 so that's the manual you want)
Oh, forgot to mention what needs to be done.. Splice the two wires together from the chassis.
Old 02-17-2010, 12:46 PM
Blas's Avatar
Cobra Make, Engine: SPF#0760
FYI: It's just a ground loop at the trans end.
SPFWiringDiagrams@Comcast.net
Old 02-17-2010, 01:46 PM
If they're using a relay, I'd bypass the relay itself. Piece of 10ga with two male quick connects or a double male terminal would do it. (depending on weither it's in a socket or not)
Old 02-17-2010, 02:12 PM
Blas's Avatar
Yes, there is a relay on the drop down fuse panel.
Old 02-17-2010, 02:18 PM
Thanks for the info, I was going to disconnect the safety switch so that I could start the car in reverse and avoid grinding the gears.
Decided to pull the damn trans and fix the real problem rather than just temp fix by bypassing the lockout switch.
This isn't going to be cheap either.
But, I was tempted!
