Old 06-28-2011, 10:46 AM
Neutral
Default SPF Ride Improvement
I have the stock Bilstein shocks and springs on my SPF and was wondering if any of you guys had replaced them with anything that rides better.
By better, I mean more controlled. My car seems to take quite a hit (bounce) whenever I hit a bump in the road. There must be a better option. Something that absorbs the bump better and doesn't trasmit such a shock to the driver.
My previous car, an FFR, I replaced the non adjustable Bilsteins with adjustable Konis on all four corners and felt more connected whenever uneven terrain was encountered. I might be wrong, but if there is a way to improve the overall handling, I am open to suggestions.
Many have said the Bilsteins are the best you can get, but I thought I would ask anyways.
Old 06-28-2011, 11:09 AM
Jim Kellogg's Avatar
Cobra Make, Engine: Superformance MKIII #887, drive it a lot!
Send a message via Yahoo to Jim Kellogg
I upgraded my SPF suspension last year with new shocks and springs from Cobra Valley that are made specifically for SPF.
There are lots of choices for you here, depending on what you are looking to do with the car. I would recommend calling Randy at Cobra Valley.
Cobra Valley's SHOCK & SPRING Suspension UPGRADE
I am VERY happy with my new setup. Check it out.
Hope this helps!
Jim Kellogg
Old 06-28-2011, 12:36 PM
Cobra Make, Engine: SPO 2644 Roush 427R
I second Randy at Cobra Valley..
Upgrade to QA-1's and install his sway bars. Made all the difference with my ride.
Old 06-28-2011, 12:39 PM
Silverback51's Avatar
I will also recommend Randy at Cobra Valley.
However I went with heavier springs and milled up some solid mounts for the sway bars. I'm willing to sacrifice some comfort for handling.
John Hall
Old 07-23-2011, 07:42 PM
cdog's Avatar
I have QA-1's and they are great. Car sits super low and looks cool....
Old 07-23-2011, 09:31 PM
WardL's Avatar
JHV48, how are the new Shell Valley ball joints? I received mine but have not installed them yet. Didn't they help what you are talking about?
Old 07-23-2011, 09:35 PM
Senile Club Cobra Member
"Cobra Valley" I think you mean
rick@autoventureusa.net
Old 07-23-2011, 09:43 PM
bobcowan's Avatar
What are your current spring rates? You might save a bunch of money simply by replacing the springs.
.boB "Iron Man"
NASA Rocky Mountain TTU #42
www.RacingtheExocet.com
Old 07-23-2011, 10:06 PM
They absolutely did the job. Vibration gone. Steering feels much more solid and connected.
Nothing left to do here.
Old 07-24-2011, 11:39 AM
SPF1061's Avatar
I have Olthoff Racing custom racing Bilsteins on 1061. It's a whole different car than with the stock Bilsteins. Give Dennis Olthoff a call: (704) 647-9924.
Old 07-24-2011, 07:01 PM
Kenm4187's Avatar
Cobra Make, Engine: SPF# 2560
It depends on how far you want to go. I have mine setup for Autocross. Very rough on the street but handles great on the course. 850 LB springs, Penske 3-way adjustable shocks, Modified GTP front swaybar, this was to make it adjustable (see pic). No rear bar. 285/30/18 front and 335/30/18 rear (Hoosier A6's). If you are doing track days it would be different.
Ken
Old 07-24-2011, 09:13 PM
I have Dennis Olthoff spring, shock, rear sway bar setup. Dennis also set proper ride height and alignment. Feel every bump but it sticks and is still streetable.
Old 11-30-2011, 01:48 PM
So, as a follow up, I replaced the stock shocks, springs (350 lb.) and sway bars with the ones from Cobra Valley. Feels like a different car. Slightly stiffer but more connected to the ground. Small bumps don't rattle the wheels any longer. Absorption and rebound are much smoother. Got the shocks set on number 8 out of 18 stiffness settings.
Much more enjoyable driver now with the new ball joints and suspension pieces.
Old 11-30-2011, 06:00 PM
Have you ever had your car on scales???
HUGE Improvement right there. Try that first
Old 11-30-2011, 09:51 PM
Cobra Make, Engine: SPF roush 402
What size springs did you go with?
Old 11-30-2011, 09:55 PM
I chose The 350 lb springs. Could easily handle the 400 pounders as well.
Old 11-30-2011, 10:01 PM
DanMartin's Avatar
Cobra Make, Engine: Superformance Cobra Chassis #408, 427FE, TKO600
+1 on the cobra valley set up with their shocks, sway bars, etc.
I'm running the 400lb springs and the sway bar in the middle setting...firm, but 1000x better than the crappy stock set-up.
Also get the rear upper shock mount kit while you are there...it's a must-replace item, as the stock one can fail.
Old 11-30-2011, 10:07 PM
Thanks I'm also up grading my suspension,waiting on my ball joints to come in the mail.
Old 12-01-2011, 08:35 AM
You're going to love the upgrades. Ball joints are a great first step. The shocks and sway bars really top off the upgrade.
Old 01-02-2012, 09:32 PM
How difficult is it to change stiffness in the shocks from Cobra Valley? I ask because I'm thinking it would be nice to make the ride smoother for cruises and stiffer at the track.
Also, the shock/spring upgrade says it "accepts remote adjustable shock control from the cockpit". How does that work?
Lastly, would you all agree to start with the following order of upgrades for the MkIII:
1) R/T Rear Shock Mount
2) Ball Joints
3) Sway Bars
4) Shocks and Springs Upgrade
I'm not able to do all these at once. Where would a Pro 5.0 short throw shifter fit into upgrades for you? Quick shifting would definitely play a part in faster times at the track and more fun on the street
