| S |
1 |
| 5 |
8 |
| 12 |
15 |
| 19 |
22 |
| 26 |
29 |
30 |
12-20-2011, 05:47 PM
md
Cobra Make, Engine: superformance 1022
Side Curtain help
I'm a new Superformance owner and put up the soft top because its getting chilly here in Md. The side curtains are driving me bats. Is there a proper way to adjust or trim them so it isn't a struggle to close the door easily? Any help appreciated.
12-20-2011, 06:37 PM
Cobra Make, Engine: SPF#0760
You have a mail Message
SPFWiringDiagrams@Comcast.net
12-21-2011, 02:25 AM
Cobra Make, Engine: Superformance V8 Ford BB
Hi,
I've got the same problem, may I have the same infos ?  Thanks in advance...
12-21-2011, 04:39 AM
Why do you go to the trouble of sending a mail message, and then posting here that you've sent the mail message, when it would have been much easier to have just posted the answer to begin with (not to mention the fact that it would benefit others who have the same problem). Months later somebody does a search, finds the same question was asked, but the answer is "You have a mail message."
12-21-2011, 05:21 AM
NY
Totally agree! And I've seen this happening more than once.
12-21-2011, 05:41 AM
md
I'm not a computer whiz and if I made a mistake I'm sorry. So back to the question is there anything that makes the side curtains easier to use?
12-21-2011, 09:16 AM
“347stroker” – you did nothing wrong….You should ALWAYS feel free to ask ANY question here on CC….that’s why it’s here. Any of the Moderators (which includes me) will point out / or correct something if someone does it wrong, like posting in the wrong area, etc.
Since “347stroker” is a new member on CC he may not realize he has a personal message… I posted a message for him to check his message inbox. And since I don’t really know if his problem with the side curtains is related to a misalignment of their pins in the door sleeves, or an interference with the wind-wings when opening and closing the doors, or the side curtain misalignment with the windscreen, or a side curtains and convertible tops interface issue… Sometimes, the original top and/or side curtains that were fit to the chassis at the factory did not get put into the trunk of the proper car at the dealership; and the top and side curtains may have never been installed by the previous and/or original owners so this problem was never caught (FYI: all the storage bags have the chassis numbers on them). May people have purchased replacement tops or just the newer style top, and they have never been fit to the chassis. Windscreens also get replaced, and maybe the angle of the windscreen does not match the side curtains leading edge…. So with all the different causes for a problem like this I thought it easier to just give him my phone number so he can call me and discuss the problem. Also gives me the opportunity to be sure new owners know about the Superformance Car Registry and the availability of a great MKIII Owner’s Manual on the 2nd Strike website.
If someone has a similar problem and sees my reply to a thread, they all seem to know how to contact me ...been that way for years now - with no problems.
patrickt: Perhaps a quick review of your CC posting history would reveal a little “bandwidth waste” too maybe? I for one don’t like to type a lot, you on the other hand, with 13000+ posts, apparently like to be “chatty”… so feel free to answer his question online regarding the side curtains.
12-21-2011, 03:14 PM
wa
First off, my reply is not directly related to you.
But this seems to be common thing that I see on this forum. Someone asks a question, and the reply is, you have a PM.
It leaves a question in the minds of a lot of people, what is the answer and why is it not shared.
And unlike Patrick who has an inferior product, this is not specific to you Blas.
John Hall
12-21-2011, 03:22 PM
Well I'm glad I brought this up, since it obviously annoys a gaggle of the geese around here. Hurray for me.
12-21-2011, 04:15 PM
Just got off the phone with Tom, he'll post later I think. Basically a first time installation of a 10 year old top...
I usually ask people to follow up on their own posts after talking with me directly...Some do and some don't....
Regarding ERA's, I've seen some nice examples. If I would have chose to build a Kit Car, that's what I would have purchased. None are perfect and all are replicas. I won't get involved with talking trash about one manufacturer vs another...
If you aren't happy with what you purchased or built yourself, that's your problem. There are a lot of guys out there that can only dream of owning one of these cars, and would be satisfied with any manufacturers’ car, and most of them never will never own one... consider us the lucky ones...
12-21-2011, 05:34 PM
md
I talked with Blas and he offered some possible cures including warming up the top and stretching it. this is probably the cure since it was put on coldand for the first time. I'll keep updating my progress. Next step will be torches pry bars and winches.
12-21-2011, 06:03 PM
MD
Cobra Make, Engine: Superformance #2689 Roush 427R TKO 600
347, if you are still having problems give me a shout! I'm in Elkton MD there is a few little tricks the first time. Had mine on only a couple times, I drive all winter without the top weather permitting not really that bad just need the courage to get started. 26* is the coldest I have been out in a lot of thumbs up!
01-02-2012, 02:36 PM
WA
Cobra Make, Engine: SPO2089, Ford Crate 393 475 Hp
347, I have a similar problem with the left door. The top was never put up by the original owner, and the top is one number up from mine. Found that the interference was with the windscreen and the lower aluminum door sleeves. It's about 1/4 inch too long. Also, the plexiglass extends about 1/8 longer than it should. Both hit on the windscreen support when closing the door.
The right side is OK. I've ground down the door sleeve and now working on trimming the plexiglas. Once these items are taken care of the door should close properly.
You might check to see if this is what's happening with your car..
Bob
01-06-2012, 05:28 AM
FL
Cobra Make, Engine: Superformance # 1774 / 392 Stroked Windsor
Bob, Where did you get the black vinyl that covers the window framework? I need to cut mine down 1/8 inch but will have to remove the black vinyl first. I bought a hardtop for mine and the passenger window will not fit. I had to remove the rubber molding on the botton of the hardtop and grind on the bottom of the hardtop for it to fit perfect. For what they charge for these hardtops they are junk! I have it fitting perfect now. Good thing I found the top 2nd hand but never used. Saved a bunch of money on buying it used cause they are very overpriced. The car numbers were very close also so it is the right top. Mark
01-06-2012, 09:25 AM
Any good fabric shop, convertible top repair shop, or interior shop should have similar material. Bring samples when you shop. The material texture design, color, finishes and embossed pattern size varies wildly.
01-06-2012, 05:21 PM
WA
..TN, probably wont be of much help for you. On my car it was just the end of the aluminum tube that bumped up against the windscreen. I was able to grind off a bit of the tube and that solved the tube hitting the post. Now working on getting the plexiglass trimmed. Didnt have (fortunately) to deal with the black vinyl.
Good luck getting that top working for you. Regards
01-07-2012, 12:47 PM
FL
Thanks for the info! Its hitting a little on the top and where it goes against the vertical side of the hardtop. Only need to trim about 1/8 inch. Mark
| Thread Tools |
| Display Modes |
Rate This Thread |
Hybrid Mode
