SUPPORT OUR SPONSOR
Go Back   Club Cobra > Club Cobra Tech Areas > Transmission Talk
Old 05-09-2004, 06:08 PM
Cobra Make, Engine: ERA 427 SC with 428 PI
Default TKO II from 2-3
Do all TKO's shift like and old milk truck from 2-3 when your on it a little or is it me?
Old 05-09-2004, 07:53 PM
joea's Avatar
Cobra Make, Engine: ERA #676, 428SCJ (2x4), TKOII
That is what I heard. I bought a Pro 5.0 then found out it is too high for the ERA tunnel. I wish someone would find a better shifter that fit the ERA
What gear oil are you using?
"There are 10 types of people out there....the ones that understand binary and the zeros that don't."
Old 05-10-2004, 05:44 PM
Joea,
I using Valvoline ATF, nothing special, do you have a better Idea?
I spoke to Mark who has ERA 627 and he said their is special fluid that will help the problem, but not solve the problem, do you know anything about it?
How high is Pro 5.0? I made a special ring for the TKO that is about 3/4" high.
Mike
Old 05-10-2004, 07:36 PM
joea's Avatar
The recommended fluid is GM Synchro.
I have not attempted to fit the Pro 5.0 in the car. I understand the stock shifter is already high...thus the required spacer. My understanding is the Pro 5.0 quite a bit higher than that
Old 05-10-2004, 08:01 PM
Chaplin's Avatar
Cobra Make, Engine: Original ERA 427sc, Powered by Gessford
Mike,
Pro 5.0 is higher than the stock shifter and doesn't fit well in the ERA trans tunnel. In fact, I ruined one trans tunnel trying to get the Pro 5.0 shifter to fit properly I had to order a new trans tunnel, and after speaking to Doug at ERA, just decided to use the stock shifter. I suppose you could make a spacer tall enough to make it work with the Pro 5.0, but it would probably look ridiculous. As it is, you have to use that 3/4" spacer with the stock shifter.
I am also using the GM Synchromesh fluid and haven't noticed and real problems shifting. I've got about 1300 miles on it now and the shifting seems to be improving with mileage.
Replica is not a dirty word.
Old 05-11-2004, 02:10 PM
It shifts ok at low RPM's but at about 4000 it a problem.
You guys are telling me to change the fluid. Is there a trans doctor close by who can doctor it up?
Old 05-11-2004, 04:59 PM
Cobra Make, Engine: Superformance 156, ex Paxton 351, now a 392 Ford Racing Stroker
try this stuff:
http://performanceunlimited.com/cobr...ltrashift.html
or:
http://performanceunlimited.com/cobr...treatment.html
Old 05-11-2004, 06:07 PM
Bill,
Did you try this stuff? It looks good at the site.
thanks
Mike
"Is it original ?" -- " Yes! But some parts are new."
It's just easier this way.
Old 05-23-2004, 04:06 AM
Cobra Make, Engine: ERA 427SC FMS 351W
Default Removing ERA 427 Tunnel
Chaplin, I believe I need to remove my tunnel to gain access to my 3550. Any suggestions to more easily remove and install these tunnels on the ERA 427 cars?
Thanks, Dave
Old 05-23-2004, 06:13 AM
Dwight's Avatar
Smile TUNNEL
I LOWER MY TUNNEL ON MY LONE STAR. I CUT THE FIBERGLASS OUT FROM JUST UNDER THE DASH TO JUST REAR OF THE SHIFTER. I HAD A PIECE OF ALUM BEND TO COVER THE HOLE. SILCONE AND POPRIVERS. COVER IT WITH PAD AND CARPET.
Old 05-23-2004, 07:22 AM
Chaplin's Avatar
Default Re: Removing ERA 427 Tunnel
Thanks, Dave
Dave,
Unfortunately there is only one way to do it, which, as I'm sure you know, requires removing the seats, carpets and rear panel. However, once you've done it a few times it gets easier and easier. Just use an electric drill with a screwsdriver bit to remove/reinstall and the screws and it will go a lot faster. I can probably remove mine in 20 minutes or so at this point.
Old 06-13-2004, 04:38 PM
I changed the fluid to to Ultra Shift and now after about 200 more miles it shifts better but not perfect.
Old 06-13-2004, 06:43 PM
joea's Avatar
What % improverment in your opinion?
Old 06-13-2004, 08:05 PM
Cobra Make, Engine: Superformance / 427 SO
I went from the GM Synchromesh to the Ultra Shift about 350 miles ago. Didn't see much of a difference at first (I also have a Pro 5.0) but it seems like it shifts better every time I take it out now. It's supposed to improve after about 500 miles, or so. So far, it seems like that could be the case because it just keeps getting smoother all the time.
Old 06-14-2004, 03:38 PM
% of improvement is hard to say, but I'll do it.
I would say 50 % less missed shifts.
I'll give it more time (miles) and report back.
Old 06-14-2004, 04:09 PM
joea's Avatar
not too shabby
Old 07-03-2004, 06:42 PM
Dwight's Avatar
Exclamation TKO AND ULTA-SHIFT FLUID
WHICH DO I NEED FOR MY TKO THAT HAS REDLINE FLUILD IN IT NOW?
ULTRA-SHIFT OR
ULTIMATE Tremec Transmission Treatment -for A.T.F. Based Fluids
11.5 ounce bottle (treats 6 quarts @ 2.0 oz per quart)
(treats 4 quarts @ 3.0 oz per quart)
I THINK THE TKO HOLDS 2 AND 3/4 QTS. NOW MUCH ADDITIVE (ULTIMATE) WOULD I ADD?
WHICH IS BEST? MY TKO GRINDS GOING INTO REVERSE. ITS BETTER IF I SHIFT INTO 3RD OR 4TH BEFORE GOING TO REVERSE.
THANKS
Old 07-05-2004, 01:44 AM
I used the Ultra Shift, not the additive. It's not cheap stuff, but after 500 miles either it's working better or I got used to it, now it's 75-80 % better.
Mike
Rate This Thread:
