Go Back   Club Cobra > General Discussion > Advertisers Forum
Old 07-17-2010, 09:08 AM
Default B2 Motorsports 347SBF Short Blocks/Complete Engines
Short Block:
*Fully CNC machined production block
*Block clearanced for stroker crankshaft
*ARP main studs
*Scat 9000 series crankshaft
*Scat forged I-beam rods
*Probe forged pistons (flat top or dish to match your application)
*Clevite main/rod/cam bearings
*Total Seal piston rings
*Felpro rear main seal
*New cam retainer plate
*ARP cam retainer plate bolts
*Comp Cams hydraulic roller camshaft (custom picked to perfectly match your application)
*Ford Racing timing chain set
*ARP camshaft bolt
*Professional Products harmonic balancer
*ARP balancer bolt
*RAM billet steel SFI flywheel
*Rotating assembly balanced
*Camshaft degreed
*Block painted, freeze plugs/galley plugs installed
*Assembly pictures provided along with build specs (bearing/engine clearances, cam specs)
$3349
*Forged crankshaft, main girdle, etc. available as options.
Complete Engine
*ARP main studs
*Scat 4340 forged crankshaft
*ARP camshaft bolt
*ARP balancer bolt
*Camshaft degreed
*Ford Racing hydraulic roller lifters
*Ford Racing lifter spider
*Stainless steel bolt kit
*Melling HV oil pump
*ARP pump driveshaft
*ARP oil pump/pickup bolts
*ARP head bolts
*ARP flywheel bolts
*Comp Cams pushrods
*Felpro gaskets
*Comp Cams roller rocker arms
*Edelbrock Victor Jr intake
*AFR 185cc heads
*Edelbrock water pump
*Moroso T-sump oil pan, dipstick, pickup (other applications may be substituted)
*CVR gear reduction starter
*Quick Fuel Q-750 carburetor
*MSD Pro Billet distributor
*MSD plug wires
*Engine broken in and dyno tested
*Build pictures, spec sheet, dyno results, and dyno video included
347ci, 450hp/425lb-ft
$8799
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
Old 07-17-2010, 11:14 AM
Default Dang
Lykins, how do you expect to make any money when you're essentially giving away your product? We need to learn ya some bizness sense....
Old 07-17-2010, 11:21 AM
Don't worry about me buddy....I'm doing just fine.
Old 07-17-2010, 11:24 AM
I forgot to add that a NEW timing cover, pointer, and distributor clamp are included...
Old 07-26-2010, 11:30 PM
Brent builds a very good rebuilt engine and should be considered when thinking of what power you are going to put under your hood. Plus, he is a darn good guy to do business with too. He does what he say's he will do and does it pretty darn quick as well. Several of us around this site have a lot of respect for Brent and a few others like him. Maybe we should have our own Angies List?
That's really a lot of things. I need to read it thoroughly again. Good luck !
Old 07-27-2010, 04:55 AM
Clois Harlan's Avatar
Brent builds a very good engine and should be considered when thinking of what power you are going to put under your hood. Plus, he is a darn good guy to do business with too. He does what he say's he will do and does it pretty darn quick as well. Several of us around this site have a lot of respect for Brent and a few others like him. Maybe we should have our own Angies List?
Clois
"Let's roll"
"Be part of Something Good
Old 07-27-2010, 07:55 AM
STOP IT.........
I'm not tradeing my FE for a stroked small block.....
are you going to do FEs as well ????
Old 07-27-2010, 07:57 AM
Originally Posted by rustyBob View Post
STOP IT.........
Very nice. As RodKnock will attest, small children and adults alike cry when you open the hood of a 427 car and it has a small block in it.
Old 07-27-2010, 08:03 AM
Cobra Make, Engine: LoneStar 427 SC, "Red Venom", 351W B/S 400 HP, TKO 600 .64 OD
Only if they can get past the dual, padded roll bars first!
Randy
Old 07-27-2010, 09:18 AM
Yep, I do the FE's as well. FE's and SBF's are my faves...
I even do Chevys.....
Old 07-27-2010, 09:26 AM
... and if a customer begged and pleaded with you for a solid flat tappet, you'd put one in for them?
Old 07-27-2010, 09:30 AM
RodKnock's Avatar
Just please don't ask him to install a flat tappet cam in anything but an eclectic art sculpture.
Wow, Patrick, it seems like its been a while since you've put words in anyone's mouth. Kiss your 3-month BBFEFA (Big Block FE Fetish Anonymous) chip goodbye.
Old 07-27-2010, 12:12 PM
RodKnock's Avatar
I was referring to this comment, which you attributed to me, but was yours.
If I'm building another engine, Brent will be at the top of my list of people who I speak to about my new engine.
However, no where in that conversation will I ask or demand Brent for a solid flat tappet cam, for the same reason that there are no rotary telephones anymore nor are there many dial-up Internet connections left in the world. either. Technology has moved on.
So, Patrick, get out your new 3G-enabled iPad and do a little research on the benefits of roller cam technology.
Old 07-27-2010, 12:54 PM
Oh, dang. It's not like me to misunderstand something like that. But I agree with you on Brent. I think he's an excellent engine builder, and a sweetheart of a guy to boot. I would have no problem in having him build an engine for me either. And that would be.... solid flat tappet, please.
Old 07-27-2010, 01:24 PM
You worry me when you keep calling me a sweetheart.
Old 07-27-2010, 08:00 AM
I think he already does Rusty!
I know Dean Lampe and Mat Twiehaus have bought several FE parts from him.
Clois
"Let's roll"
Old 07-27-2010, 08:02 AM
Clois is correct. But Brent steadfastly refuses to put a solid flat tappet cam in one -- regardless of how much you offer to pay him. Isn't that right, Brent?
Old 07-27-2010, 09:33 AM
Patrick, you do a lot of post hijacking, you know that?
Old 07-27-2010, 05:25 PM
Whats the max rpm that still makes horse power with this hydro roller cam?
5600-800 or so max (I'm guessing)? Of course the actual cam profile will be dependant on a number of variables supplied by the customer, but in general, what would the useable rpm range at this price. I'm assuming the higher the rpm range of a hydro roller goes the cost goes up considerably as well.
Old 07-27-2010, 05:32 PM
Ernie, I usually aim for around 5500 with a hydraulic roller. Considering if you're running through the gears, you usually shift about 500-600 rpm higher than peak hp rpm. I feel that's pretty safe for a hydraulic roller cam and if more hp/rpm is needed, then I go with a solid roller.
You can go higher of course, but you have to start looking at higher pressure dual springs (or beehives), lightened lifters, titanium retainers, etc.
