83Likes
04-13-2016, 12:55 PM
Cobra Make, Engine: All original, with Chevy engine since 1964
Originally Posted by cycleguy55
You could always create a hybrid - put FE valve covers on the Windsor with adapters.
Oh, I don't know about that...
I mean, what if some guy at a car show sees my valve covers, and asks me if my engine is a C5, C6, or C7 casting...? I'd be busted...
Then, I'd have to humiliate the poor chap by asking him why he noticed my fraudulent engine BEFORE he noticed my car's doors and wheelbase?
or the lug nuts...
or the 9-bolt steering wheel...
or the Mustang steering rack...
or the fiberglass wheel wells...
or, well, you get the picture.
- Robert
04-13-2016, 01:39 PM
SK
Originally Posted by Shootnride
It's always amazing to me that some folks can turn any thread on this forum into an opportunity for personal attacks.
Ted
Welcome to the Internet.
Brian
04-13-2016, 02:09 PM
KY
Originally Posted by EZ$
Been sitting here reading the thread, and debating if I wanted to respond. When I read the discussion of the 1.2 to 1.4 hp/ci being a .85% increase I just couldn't not respond. That difference is actually a 17% increase, .2 divided by 1.2 = .17 or 17%. Since I have no knowledge of the differences between GM & Ford engines, (don't care, long term Ford guy), I'll go away now.
Exactly...
When you equalize the displacement you'll see that the Ford would be almost 70 hp over the Chevy.
Now try and explain to me how superior the LS engine is.
04-13-2016, 02:18 PM
Originally Posted by blykins
Exactly...
Sounds like you are getting your numbers from "Loch Ness" the engine builder, you may have a grainy picture but it does not exist.
04-13-2016, 02:19 PM
KY
"Sounds like you are getting your numbers "Loch Ness" the engine builder, you may have a grainy picture but does not exist."
I have no clue what any of that means. Repost when you're sober.
04-13-2016, 02:27 PM
Senior CC Premier Member
To me, it's "whatever lights your pipes!" and gets you what you want.
I am an FE guy, but try to be objective on other views and choices. Some are budget driven, some are loyalty driven and some just dare to be different. To each their own.
04-13-2016, 02:32 PM
When sober , that will be a long wait. The clue is you are making h.p. numbers up!
04-13-2016, 02:37 PM
KY
Chevrolet advertises the Corvette engine to be 460 hp with 6.2L. The 5.0 in the mustang is 420 hp.
I am not making those numbers up, doesn't take a rocket scientist to figure out which engine is more efficient at making horsepower.
And yes it is extrapolation, but it is reasonable extrapolation that all engine builders use. If the 5.0 added more displacement it would be head and shoulders above the Chevy engine.
I'm sorry, but your superior engine just isn't superior. Also, to add insult to injury, the 5.2 L Mustang engine makes over 520 hp.
04-13-2016, 03:17 PM
The current Mustang GT coyote is rated at 435 HP and the older Boss 302 coyote was rated at 444 HP. Ford modular motors make some serious HP and revs.
04-13-2016, 03:22 PM
Can we talk about resale value? Cobras with Chevy engines sell for more money, when you factor in the fact that Chevy engines are cheaper to build. So you lose less money.
And what about the "If Chevy had supplied Shelby an engine....we would have all be better off." Would we all be arguing about whether a Ford engine in the Cobra looked better and made more HP for more, or maybe less, money?
Come on Bernica, pick a side and stop being politician.
04-13-2016, 03:26 PM
Well said!
04-13-2016, 03:29 PM
Exactly...
I'm still waiting for you to point out Ford's equivalent performance engine platform (let alone Ford's superior one)-
If you want to call out the Coyote platform, then I won't argue, except to say: "Time will tell", and/or "I guess 18 years was a long enough head start for Ford to give GM"
You're entire argument has been "Pro engine builders like me understand things that imbeciles like you don't..." You're a custom engine builder who prefers Fords - I get that, and I also get that there are successful race teams out there running engines based on a whole myriad of design platforms.
But shops like Lingenfelter and MTI Motorsports were out there building 600HP NA LS engines (Using factory GM cranks and connecting rods) for a decade, while all Ford was doing was fighting to get out of honoring warranty claims against its crappy modular V8, Which the Mustang tuner crowd was out there blowing up left and right...
I consider the LS to be a superior engine platform simply because LS engines are proven to handle the abuse (even the excessive abuse dished out by 20-something, FastandFurious wannabe's) and they are capable of producing 100%+ VE without any significant degradation in engine longevity or durability. And they've been doing this since 1997 (nearly 20 years).
Ford does not have a modern engine platform that can match that track-record (unless you can point it out to me)
If HP/displacement is the governing factor on what makes a "superior" engine, then I guess the 4.6 Modular V8 is/was not only better than the LS, but is also better than the FE or the Windsor before it... right?  If so, then why are there so many windowed 4.6 liter Fords sitting in junkyards, compared to so few LS1's... ?
Now, we could continue to volley this little yellow ball back and forth, but it would only serve to entertain everyone else on ClubCobra... You are unlikely to change my mind, because you lost me at "LS heads are based on Cleveland heads", and "LS heads will bolt directly onto a Windsor block" - neither of which is technically (nor historically) accurate...
Besides, we're talking about OHC versus pushrod engines here - If we want to level the field, then like you said earlier- we should compare apples to apples...
But it's been fun...
- Robert
Reason: Apples, Oranges, engines, and fruitcakes...
04-13-2016, 03:38 PM
Originally Posted by Thor maine
Well said!
Well, we can say anything on the Internet and cannot be proven wrong, since there's no verifiable data to support what any of us say.
The only person who quoted something, anything, that was 100% correct is EZ$:
We'll ignore the double negative.
04-13-2016, 03:41 PM
That was an awesome post.
I don't even know how I got stuck in this honey-trap - I'm not even a "GM guy" necessarily- True, I have owned more GM powered vehicles through the years, but at this moment in time, I own 3 Fords, and ZERO GM vehicles.
I already stated above that I think the engine should match the application...
Now, if you will all excuse me, I'm going to go find a Cheetah replica forum so I can tell them all about the exciting new Cheetah build I'm doing, using a 400M I yanked out of a 71 Mercury Marquis... It should be a RIOT.
- Robert
04-13-2016, 03:52 PM
KY
Well, you actually can bolt LS heads to a Windsor block. Do a search, guys do it.
Also, there is nothing new under the sun when it comes to engines. BBC's, BBF's and Clevelands all share the same design architecture. When Chevy decided to start with a clean slate, look at the design characteristics that they implemented: same bore spacing as a Ford, similar valve angles, valve sizes, port CSA, and exhaust layout. (Chevy switched from having the middle two exhaust pipes close to each other, to spacing it out like a Ford. They also changed to a Ford style oil pump, among other things.) There are only so many ways to design an engine, but Chevy copied a lot of Ford ideas on the LS. Actually, you can convert an LS to distributor ignition and guess what you use.......an MSD Ford 302 distributor.
As for superior engine designs, what are you basing your decision on? Horsepower? Surely not, because there are many naturally aspirated SBF's, Clevelands, BBF's, etc., than can easily match the horsepower and efficiency that an LS can. I'm not sure where the idea that the LS is such a brain child came from, because none of the engine builders I know just don't share that same idea.....??????
As far as Modular Fords go, the Mods have been out since 1996. A factory aluminum 4.6L DOHC block will take 1000 hp without batting an eyelash. They are bulletproof as far as I'm concerned. As for how many 4.6's I see windowed in the junkyards, to be honest, I've seen zero. The 5.4's are known for poor piston quench and poor spark plug design, but the 4.6's and 5.0's have been out for a very long time and are very proven.
I've quoted numbers, taken straight from the manufacturers' websites. I guess that's not enough argument that the Ford engines will make horsepower easier.
A 1.2 hp/ci engine (referring to that 6.2L LS) is not hard to duplicate. FE's are certainly not the epitome of big horsepower, but if I couldn't duplicate that with a Windsor or Cleveland, I'd give up engine building. Saying an engine has had durability or longevity since 1997 makes me laugh out loud.....because SBF's have been doing that since the late 60's.
Nice try, but no cigar sir. As far as I'm concerned, if your GM fact quotes are anything like your math, I'm unimpressed....LOL
04-13-2016, 04:12 PM
NO, they don't... They bolt LS heads onto modified Windsor blocks. As to WHY they do that...? Who knows- I mean, why would someone want to run inferior GM cylinder heads on their superior SBF, anyway...?
Damn- Because impressing you is the only reason I've hung around this thread as long as I have... I'm a loser- an abject failure.
I surrender - You win. Ford built the better mouse trap, but the world was too stupid to buy it, because Chevy's mouse trap was cheaper.
- Robert
04-13-2016, 04:14 PM
SK
That was not my experience two years ago when I was in the market to buy. What I observed was that any engine other than a Ford consistently had a lower asking price and was often on the market much longer.
In retrospect I probably should have bought one of those dirt cheap (especially if it had an auto tranny), yanked the engine and transmission and sold it to someone with a bowtie fetish, then replaced it with something fresh. Ah, lost opportunities...
Brian
04-13-2016, 04:24 PM
KY
Glad you're catching on. ;-)
04-13-2016, 04:26 PM
Let's go back to Keith Craft's original question - After all he asked for opinions.... And all I've done in this thread is act like a pro-GM dick... (I'm good at that)
No longer Keith, just Craft for now on.
I think Keith got bought out or fired.
I love the power my 408 puts out.
That's all I have to ad to this post.
FFR MK1---Sold
Superformance #884 --- Sold
No more Furds.
04-13-2016, 04:39 PM
Originally Posted by Millsy
Once i get my backdraft cobra (ordered 4/4 from Vintage) with the Coyote 5.0 i can then compare to the LS3 in my vette. One thing i know is both will go like a bat out of hell and thats all i care about. Some like authenticity, some are brand loyal, but i just like speed.
WHAT !?!?!?!
You're going to attempt owning a Ford AND a Chevy at the same time?
Didn't you ever watch Star Trek? Don't you know what happens when matter and anti-matter collide? The entire Universe could implode.
You sir, must have brass balls. I don't think there is a single Internet forum out there where you won't be loathed 50% of the time ... Except on the Mopar forums, where you are certain to be loathed 100% of the time...
- Robert
