Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > Antique & Collectibles
Old 05-24-2005, 05:22 PM
jerry w's Avatar
Cobra Make, Engine: Antique & Collectable 302, C-4,Ford 9 inch
Default Insulating firewall/footbox
Hello all,
I would be very interested in how people insulated thier firewalls and footboxes. What did you use for material, and what you used to fasten it to the fiberglass. Thanks in advance to all who respond.
Jer
Jerry
Old 05-25-2005, 06:51 AM
Roscoe's Avatar
Jer,
I used thin aluminized fireproof material on the firewall and then a layer of the aluminzed carpet padding. On the rest of the interior I used peel and stick Dynamat and covered this with the aluminized carpet padding. Used 3M spray glue for the whole thing where peel and stick was not used.
In the pic below you can barely see some of the insulation on the passenger sidewall in front of the door.
Roscoe
Old 05-25-2005, 08:02 AM
trularin's Avatar
Member of the north
Cobra Make, Engine: A Cobra
1/2" jute felt ( spelling? ).
Old 05-25-2005, 01:39 PM
jerry w's Avatar
Thanks Roscoe and trularin;
Roscoe I owe you a beer if I ever meet you at a ralley or show, thanks again for the great picture it really helps a neophyte like me out.
Jer
Jerry
Old 05-26-2005, 06:21 PM
PNJSNAK's Avatar
Club Cobra Member
Cobra Make, Engine: A&C 427S/C, 351W, T5
Jerry: I used the same stuff as Roscoe. It is a bit difficult to cut. I stayed away from putting it on the floor where the seats go just to keep the height down. I did the entire transmission tunnel, foot boxes and where ever else I could put the stuff to keep heat from getting into the interior area. There still is some heat getting in around the pedals and a few other places. Use the Scotch 77 spray adhesive for the insulation and the carpeting.
Have fun.
Jim
OhioCobraClub.com
Old 05-27-2005, 05:43 AM
jerry w's Avatar
Jim,
thanks for the tips, hvae you (or anyone else) tried insulation on the inside of engine compartment? I like to keep my feet cool
Jer
Jerry
Old 05-27-2005, 06:34 AM
Roscoe's Avatar
Jer,
I used it under the seats but bolted the seats directly to the floor with no tracks. Using the Cobra Classic seats I have no problems with height.
Also, with the insulation I installed I get absolutely no heat coming through the firewall. If you do it right you should not have to use any stuff in the engine compartment.
Roscoe
Roscoe
Old 05-27-2005, 04:12 PM
jerry w's Avatar
Roscoe,
thanks again for the tips, seats look great!
Jer
Jerry
Old 05-27-2005, 05:14 PM
Banned
Cobra Make, Engine: P. O. of KMS 91,92,193,196,197,205,207,S024
i install a fire proof aluminized heat shielding on the foot boxes of the cars i do i glue it with 3m #08090 super trim adhesive . i have installed it on the engine side of the foot boxes and it works great even with all the heat generated from the headers i have never had any problem with it comming unglued try aircraft spruce for the material ,regards,jerry
Past owner of:
KMS- 91, 92, 193, 196, 197, 205, 207 AND S024.
REAL SHELBY COBRA's OWNED
CSX 3355, 3358, 2200, 2571, 2295
GT40 #1086
Old 05-28-2005, 04:15 PM
jerry w's Avatar
Jerry,
Thanks for your reply, appreciate help from someone who builds cars.
Jer
Jerry
Old 05-28-2005, 05:48 PM
Cobra Make, Engine: Classic Roadsters 351 Windsor 405 HP
I used Kool Mat. A 5 foot long by 30 inches wide piece was $150, but this material is very thin and can be used under the seats. I glued in place with silicon adhesive. It supposedly withstands temps to 2,500 degs. I didn't use the jute stuff but installed the carpet right on top of the Kool Mat.
Old 05-29-2005, 06:16 AM
jerry w's Avatar
Thanks Art,
Do you remember where you purchased the Kool mat/
Jer
Jerry
Old 05-29-2005, 06:35 AM
Don Don is offline
Another alternative:
Frost King Duct Insulation, self adhesive Foil and Foam, Each roll is 12" wide, 1/8" thick and 15' long, SKU FV 516. Mentioned in the Corvette Forum for both heat and sound insulation.
Available at Home Depot and Lowe's.
www.frostking.com
Old 05-29-2005, 05:53 PM
jerry w's Avatar
Don,
thanks for the tip, did you insulate the inside of the footbox & firewall, or the engine compartment?
Jer
Jerry
Old 05-29-2005, 09:20 PM
2KWIK4U's Avatar
Cobra Make, Engine: Lonestar LS427, Keith Craft 496 Genesis, 649 hp, 668 ft-lb, TKO-600, Dynatek Stack EFI
Jerry
The Dynamat Roscoe refered to is very thin and can be used under the seats. I lined everything in passenger compartment. Its very easy to use. Cut it with a box knife, peal off the liner and stick iti in place. THen glue the carpet to it with super trim adhesive. There was a recent thread I responded to with the part #'s from Summit. Might want to do a search. Here are two pics in my gallery that show the installation.
http://www.clubcobra.com/photopost/s...cat=500&page=1
http://www.clubcobra.com/photopost/s...cat=500&page=2
Brad W.
A good friend will come and bail you out of jail...but, a true friend will be sitting next to you saying, "Damn...that was fun!"
Old 05-30-2005, 05:18 AM
Don Don is offline
Jerry, I have not installed the Frost King Duct insulation, However, the reported results were favorable on the Corvette forum regarding insulating the entire transmission tunnel and shifter area, both for heat and noise.
Another use mentioned as a succesfull installation was was the entire rear compartment to reduce the road noise and sound level, especially after installation of an exhaust system.
Old 05-30-2005, 04:27 PM
jerry w's Avatar
Brad,
Excellent pics! Thanks....nice color also, mines a candy apple red.
Jer
Jerry
Old 05-30-2005, 04:31 PM
Cobra Make, Engine: A&C 460
Jerry, check my gallery for frostking insulation installation. We had the car on the road without it, made a big change in my opinion. The aluminum tape you see on the seems is less visible in person.The headers are less than 1/2" away with no visible problems yet.Only have 100 mile on car while we finish exterior.
Gman
Old 05-30-2005, 05:43 PM
Don Don is offline
Jerry, I poster an inquiry on the Corvette Forum , reference the attached web site:
http://mikemercury.home.att.net/sound.htm
Even the Corvette at $50K needs attention.
Hope this helps !!
Old 05-30-2005, 07:46 PM
I purhased Kool Mat from Classic Enterprises
PO Box 1162
Pleasantville,NJ 08232
609-646-7032
It cost $30 per foot and is 5 foot wide.
