07-15-2011, 03:57 AM
NSW
A wise man once said to me:-
"The crank does not know what brand is on the rocker covers"
Tomcat, stick a stock 351 in your car and I will be happy to race against my stock 350........
Ben
07-15-2011, 04:24 AM
I think Carroll Shelby proved all that long ago ...
Merv
Ford Cobra
Harrison #80.
Peregian Beach
Sunshine Coast Qld.
07-15-2011, 06:57 AM
Until an LS engined cobra takes fastest lap @ the nationals then the windsors have the bragging rights... Gary Walthers 1:03 was pretty quick.. Ok so it's a 6 litre dart blocked V8 supercar engine but it's still ford based ....
On the other side I use a VE SS sportwagon to tow so I'm also an LS engine fan...
07-15-2011, 05:39 PM
vic
There is no doubt that windsor engines can produce some awesome power, but for big bucks.
Very few engines could match a LS engine power for dollar. (OK Scotty quad cams too)
The fact that Waz and Mizzi have both bought LS engines is testament to that!
Powered by Cu
07-15-2011, 08:35 PM
Cobra Make, Engine: Some kind of FORD thingy, with several pis tins, twin chain driven SUs feeding a Y block, apparently.
just a bit of good banter boys but, waz can confirm that his crate ls7 cost over $20000, you could build a 427 windsor for around that,give or take, so thats hardly HALF price. beejay im not about to destroke my engine then drive south to race you, so how about this, you would probably like more power so why dont you stick your hand in your pocket, stroke your ls to 6.3ltr same as mine, stick some 3.6 gears in the bum and put in down the 400, that would be a fair comparison,then show us your time slip. then we will see if youre faster for half the price
Nuts,,, Bolts,,, and 2 smoking barrels.
07-15-2011, 09:16 PM
Windsor sure look better, I'm putting this stroker in my Mustang
006 (2) by , on Flickr
Harrison Cobra
Ford 4.6l supercharged
T56 six speed
07-15-2011, 09:31 PM
vic
Tomcat,
A stroker LS3 taken out to 400+ci can be had for as little as $7700US
While a LS7 would be great, the are definitly big bickies!
Powered by Cu
07-15-2011, 11:12 PM
NSW
Ash,
Since when does power equal fast laps.......!
Tomcat,
I bet a stock LS3 with a cam would make similar power to your engine, and be under $10K. Ugly engines - yes. Bang for buck - awesome.
HSV300.
Very sweet motor!
07-15-2011, 11:18 PM
How's the re-build going Geoff? Did you solve the mystery of the pitted piston?
Merv
Ford Cobra
Harrison #80.
Peregian Beach
Sunshine Coast Qld.
07-15-2011, 11:38 PM
we certainly dont want to do any comparisions there do we.
GAV point taken, but you can also buy a coyote 400hp crate engine,for less than $7000 us that you can now stroke to a 351 with all the latest technology.
my point being, youre gm based products are not half the price for crate engines or worked performance engines otherwise ford would be bankrupt long ago which is where gm finds itself now, bankrupt and broke
07-16-2011, 12:51 AM
vic
Bet a coyote would spank your stroker Tomcat
Powered by Cu
07-16-2011, 01:36 AM
HSV300, That motor is a thing of beauty.
Regards.
Mando
07-16-2011, 03:50 AM
That is one of the things about the way the Original Cobra image has developed - motors like that are as attractive as the cars themselves.
Merv
Ford Cobra
Harrison #80.
Peregian Beach
Sunshine Coast Qld.
07-16-2011, 04:05 AM
Had some time today (its the weekend) to do a little more work on the engine.
With the damage to the top of the No.2 piston, I decided to remove the piston and check (a) for damage to the sides of the piston (b) damage to the big end - bearing or journal. Thankfully, the damage appears to be confined to the top of the piston and the mating surface of the head (as in the photos above). Here is the side of the piston:
There was also no visible damage to the bearing or the crankshaft journal for the No.2 big end.
With all this in mind, I am happy to agree with the two earlier conclusions (thanks boxhead and blykins), something has made its way into the combustion chamber and caused the imprints on the piston and head before being exhausted.
So with one piston out, it was little effort to remove the others and the crankshaft.
With all this apart, I measured the crankshaft bearing journals (connecting rod and main), the pistons and the bores and I am very pleased with the results. All were well within specifications for both size and taper.
Before removing the pistons and crankshaft, I also checked the big end bearing play and the crankshaft end play - again, both well within spec. All corresponding measurements were within tenths of thou of each other.
Next, I will be taking the block to be honed and will be replacing the bearings and the rings before it all starts putting itself back together.
Geof
07-16-2011, 04:12 AM
Tough engines Geoff! However, not as much weight on that engine stand now ..
Merv
Ford Cobra
Harrison #80.
Peregian Beach
Sunshine Coast Qld.
07-16-2011, 05:40 PM
Merv
Not sure about tough. I don't know if this engine has ever seen much service at all. There is a complete lack of wear all over the engine - pistons, bores, crank. One of the main bearings shows some minor signs of wear but that is it (apart from the damage to No.2 - which is effectively cosmetic). Even the bores had very little lip on the top of the cylinder. I wiped off the carbon deposits and dropped the pistons - easy. No need to machine or scrape the lip off. I'v only ever rebuilt a couple of engines but this is the best I've seen. So, yes, they are either tough or this one has done very little work ... or maybe a bit of both.
Geof
07-16-2011, 06:45 PM
well if it did, it would simply annialiate your ls gav, which just destroyed your own original statements about how much more hp for half price your ls engines make
07-16-2011, 11:53 PM
NSW
Anyone managed to fit one of those Coyote engines into anything here in Oz yet?
Ben
07-16-2011, 11:58 PM
I have the 4.6 litre Supercharged SVT motor in my cobra the Coyote is the same size so i'm sure they will fit into the Harrison Cobras.
Harrison Cobra
T56 six speed
07-17-2011, 01:10 AM
vic
Half the price of a Windsor I said Tomcat.
Powered by Cu
