Like Tree19Likes
  #41 (permalink)
Old 06-14-2020, 04:45 PM
twobjshelbys's Avatar
Originally Posted by Thunderbird123 View Post
What Roush 427 do you have? 427R? the reason I ask is I'm having mine built right now but I haven't decided on engine choice
The fuel injected version is 427IR. I had an early one in my Cobra. In the beginning they used Accel DFI controller, but with the problems I had and others eventually they changed. But universally, it doesn't like to idle at a low speed. The physics of the air flow through the throttle bodies and trumpets does not lend itself to low speed. You have to compromise the timing of the injector fire to the air flow and with the TB's almost closed, you get a very rich condition. This is because proper dispersal of the fuel into the cylinder depends on vertical flow with the blades open. The solution is to raise idle speed and open the TB blades a little bit.
Tony
CSX4005LA
  #42 (permalink)
Old 06-14-2020, 09:34 PM
xb-60's Avatar
Originally Posted by MJJ View Post
...Based on the feedback and additional research I am leaning towards a push rod motor with EFI. It is true that I prefer to drive my cars over wrenching on them. I am confident I Will work with a builder to come up with a fairly reliable solution.....
I'm sure that choice is well considered. Good luck with your car.
If I could comment further....Cobras typically weigh not much over a ton, so virtually any half-decent engine will give it more than enough performance to frighten you.
If you don't go way overboard pursuing massive power, you will gain on driveability and reliability (and enjoyment) from your 427W
Keep us posted!
Glen
  #43 (permalink)
Old 06-15-2020, 03:01 AM
letsboogie351's Avatar
Cobra Make, Engine: Kenmer with Ford Quad Cam Boss 260
I love my efi modular motor. but if I was to build another Cobra it would have the Coyote.
Doug
  #44 (permalink)
Old 06-15-2020, 06:13 AM
Cobra Make, Engine: Backdraft 1048
It’s a 427 SR
Gary
Backdraft 1048
  #45 (permalink)
Old 06-15-2020, 06:31 AM
Moritz55's Avatar
Cobra Make, Engine: Superformance, '65 427/MKIII with Roush V8 - 351W w/770cfm 4BBL Holley, 514hp
Thunderbird123 ... I second that going with a Roush 427SR ... Mine has one with plenty of power (500+HP) and yet it idles real well... I have over 21k miles on it ..and love it.
Many thanks,
Mark
Superformance: SPO2454 , Titanium w/Black Stripes
Engine: Roush 427SR w/770cfm 4-Barrel Holley
Transmission: Tremec TKO-600
  #46 (permalink)
Old 06-15-2020, 11:00 AM
Do your research on Roush. They are more like a mass produced product and don't have the greatest customer service.
I would go with Blykins or Kraft Racing. You will get much more personal service, and bang for your buck with these guys. They will build you a better engine toward what you want, for less than Roush. In my opinion, of course.
BigGuy, xb-60, Ozzie Goat and 2 others like this.
  #47 (permalink)
Old 06-16-2020, 04:45 AM
IMLost's Avatar
Cobra Make, Engine: BDR #178 United Speed World Special
To each his own. Everyone has an opinion and I agree with all of the above. It's going to be your car. You know your abilities, and you know what you plan to do with it. I started with the 1000 mile mindset and now drive it all over the country. Your choice, your fun.
Drive it!
Doing and driving what other people dream about!
  #48 (permalink)
Old 06-16-2020, 03:14 PM
MKS427's Avatar
Cobra Make, Engine: FFR MkIV 427
From my experience: If you go for the big cam, spend money and get EFI up front.
  #49 (permalink)
Old 06-16-2020, 04:36 PM
IMLost's Avatar
Compliments to the Arizona guys. They have good feedback and logical suggestions. One of these days i hope to get out there and hopefully meet some of them.
Alfa02 likes this.
  #50 (permalink)
Old 06-16-2020, 09:12 PM
Cobra Make, Engine: SPF#1867 , KC427
I like both engines. I think you have to step back and really ask yourself what you are going to use the car for. If you drive all the time, run errands, and enjoy gas mileage then a coyote would be a great engine.
It also depends on how much of a gear head you are. Almost 100% of the time I fire my car up it is because I’m going for a pure drive. I LOVE the way it sounds, the carb and the raw power of the 427w. You can absolutely have a reliable street friendly EFI 550hp windsor setup that is turn key go and would run for many many miles. My only advice is get way more power than you think you will want. These cars lose tons of power in their drivetrain and don’t have the most efficient exhaust layout. 500hp in one of these isn’t as fast as some make it out to be. I’ve got a 550-575hp 427w with 4.30 gears and drag radials and it will barely pull a stock c7 z06 from a 40mph roll. It’s not slow by any means but it’s not as frightening as some make them out to be. Remember they have gas pedals so you don’t have to use all the power all the time.
I have nothing against a coyote setup. I think about a potential whipple coyote as a second cobra for the future. If I could only have one cobra it would be a pushrod setup. I can almost guarantee you will sometimes get tired of the thumpy cam just like you grow tired of the toned down drone of a coyote. As I mentioned earlier carefully consider much time you going to spend in the car. It’s also not a bad idea to buy a used car to see how much you really enjoy ownership before you haul off and build one. There are many car people that get a cobra and have no clue what they are getting into....hence all the low mileage cars. One thing is for sure and that is that no matter what you go with you will enjoy it!
IMLost likes this.
  #51 (permalink)
Old 06-17-2020, 03:04 PM
Cobra Make, Engine: BDR #656 402 SR TW
Just buy it blacked out from Jay so you don’t have to polish anything.
SGwick likes this.
  #52 (permalink)
Old 06-17-2020, 11:08 PM
Alfa02's Avatar
Gold Star Contributor
@IMLost, careful what you wish for Myself and 2 other PNW members went down to Phx.. last Dec. to crash the Az boys Christmas party (No one knew we were coming ), all great guys, but you know there's always one in every group, and that one would be Ol'Karlos (Karl Bebout) In all seriousness , those guys are nothing but fun to hang with. In fact we left one of our member's Cobra down there, so we could hang out this spring with them, but the virus thing came, and kept us from doing so. At least Tim's car, had a nice vacation Cheers TommyRot
  #53 (permalink)
Old 06-18-2020, 08:32 AM
IMLost's Avatar
My plans were to be up you guys way also also. I want to do the PCH from Frisco to Seattle then up north to 20 ( i think that's it) over to Idaho. this BS has really screwed up many plans trying to hit the moving target.
  #54 (permalink)
Old 06-18-2020, 09:30 AM
Alfa02's Avatar
Your always welcome here in the Northwet Believe it or not, we have a pretty active group what with our weather (Sometimes we get rain ) Lets us know when you are coming, and we'll set up a drive around our area. Karl came up last year, and went to a show with us. Any member passing though is welcome to look us up, we always have a place to lay your head, and a garage for your Cobra here in the PNW . Cheers TommyRot.
IMLost likes this.
  #55 (permalink)
Old 06-26-2020, 11:19 AM
thorconstr's Avatar
Cobra Make, Engine: ERA 427" 351W
I had a 496" aluminum SO with TWM EFI. The engine was done by Keith Craft and was very dependable, but at 717hp it needed a lot more attention than a Coyote. There are quite a few alterations needed to shoehorn a Coyote into a Cobra, but it has been done. I really like the variable cam timing and constant HP from 1800 rpm on. I imagine there are chips out there to make it really nasty. You can drop $35k into a 427 in a heart beat. I'd do a Coyote.
Al W.
  #56 (permalink)
Old 06-26-2020, 09:12 PM
I intend no insult, here. I miss speak all the time myself.
I'm sure a brain fart, but to prevent misleading a newbe, I will correct. Constant Torque, not Hp.
Also, this was meant as a relative term not a precise exact constant torque, if anyone questions this.
  #57 (permalink)
Old 06-27-2020, 05:00 AM
thorconstr's Avatar
You are correct, I was at work rushing a response. Thanks, Al
Al W.
Rate This Thread:
