Like Tree23Likes
LinkBack Thread Tools Rating: Thread Rating: 2 votes, 2.00 average. Display Modes
  #101 (permalink)
Old 07-21-2013, 11:10 AM
Originally Posted by KevinW View Post
Great pics, nice build.
Can I just ask, as I have sen this on a few US cars, why is Cool-It matting put on the floor and side of the car? I would not have thought it gets very hot there?
The floorboards don't get hot unless you have undercar exhaust. When I installed the floorboards I realized they would vibrate, so I installed the Cool-it for sound dampening. The Cool-it in the footboxes and on the firewall are more to control heat.
  #102 (permalink)
Old 07-21-2013, 11:29 AM
Thanks for the reply.
Crendon 427, in the making
http://crendonreplicas.com/
  #103 (permalink)
Old 07-21-2013, 10:28 PM
The right side wheel went on to the pins no problem. On the left side I used a lead hammer and "adjusted" the pins to slide into the template a bit easier, and the wheel went on with some coaxing.
But now I have another problem. On the driver's side, there is 1.5" between the back of the front tire and the fender, and when the wheel is turned, it interferes with the fender (the painted part, not the well). On the passenger side, there is 2.0" between the back of the front wheel and the fender, so it (barely) clears the fender when turned.
I assembled each side with both upper and lower A arms offset to the front, and I double checked this. The tires are correctly sized at 225/65-15. I understand the car is on the dollies and isn't yet loaded, but this seems like a problem if turning with the wheels unloaded (maybe I'd have to be flying, dunno). I'll speak with the guys at ERA tomorrow to see what they say. In the meantime any experience with this would be appreciated.
  #104 (permalink)
Old 07-22-2013, 05:11 AM
DanEC's Avatar
What size front tire are you using? I have the same interference on the driver side because I'm using a 70 series tire which is slightly taller than ERA recommends. If you are using their recommended tire size and wheel offsets you shouldn't be having that problem unless the suspension alignment (probably caster) is way out.
They cover the possibility of this driver side interference in their manual - I think it has something to do with the slight differences in the right side and left side body panels that were duplicated from the orginal car. These cars (orig and most replicas) just aren't symetrical from side to side. I had to grind the lower lip on mine slightly for clearance. I haven't touched up the paint yet because I haven't aligned the suspension. The caster/camber will affect how much interference there is.
Good deal you got the knockoffs worked out. After they have been off and on a few times, they seem to go a little easier.
  #105 (permalink)
Old 07-22-2013, 09:55 AM
The front tires are incorrect- they should be 60 series not 65. They are too tall.
Chas.
  #106 (permalink)
Old 07-22-2013, 10:15 AM
DanEC's Avatar
I missed the tire size in Lippy's thread. Yes, those are probably the same heigth tires as my 215/70-15 tires. Same interference.
  #107 (permalink)
Old 07-22-2013, 10:31 AM
I spoke with ERA this morning and they said this is typical and the wheel/tire should clear when the car is loaded. They also said it is extremely unlikely to encounter a situation while driving where the suspension suspends fully while the wheel is turned. I guess I'll wait until I have the engine in to see what it looks like.
  #108 (permalink)
Old 07-22-2013, 10:39 AM
Chas, you're right that the math says the OD of the 225/65 is larger than the OD of the 235/60. Avon doesn't make the 235/60, so ERA recommended I go with the 225/65 and mentioned there shouldn't be a problem.
  #109 (permalink)
Old 07-22-2013, 12:08 PM
DanEC's Avatar
I think I did pick up a little less interference when I put the engine and transmission in - not a lot but some. Also my front still sits slightly high and I haven't roughed in my alignment yet.
  #110 (permalink)
Old 07-22-2013, 12:09 PM
Well now you know there is. All the tires sizes are different per manufacturer.
I had 4 sets of Hoosier TD's, size 245 / 60 on the fronts for 8 years. Like all ERA's with any tire, the driver front will rub on the inner fender panel (where the screen vent is) and the pass side will rub a little less.
That's only at full lock at parking speeds. You're never at full lock any other time, even in auto-x.
For the record, my front BB's with 26.5" diameter had a circumference average of 82.875 to 83.187 and rubbed no worse than the TD's.
It's always wise to check circumferences and adjust up to the highest (or have a bad set shaved). Radials are more closely sized but I'd check anyway.
Chas.
  #111 (permalink)
Old 07-22-2013, 12:11 PM
Weight, drop and settle the car to final ride height then do final alignment.
Chas.
  #112 (permalink)
Old 07-22-2013, 12:23 PM
Problem is I have interference on the driver's side at full extension, but when the wheel is only turned say 1/4 of way in. Not at full lock.
  #113 (permalink)
Old 07-22-2013, 12:30 PM
DanEC's Avatar
ERAChas - the difference is we are hitting the fiberglass lip on the newer bodies instead of rubbing the wheel well aluminum. My tires clear the aluminum fine.
  #114 (permalink)
Old 07-22-2013, 01:22 PM
Understand but if you're at full extension under-weigh, you're off-roading.
Not a normal condition for Cobra driving.
Chas.
  #115 (permalink)
Old 07-22-2013, 01:24 PM
OK I see. The answer is still a lower aspect ratio. I'd rather change tire profiles than remove fiberglass unless it's just a trace amount.
Chas.
  #116 (permalink)
Old 07-27-2013, 05:51 PM
Managed to get the rear suspension in. I made a simple wooden platform with a hole that fit over the circular mount on the floor jack and provided quite a bit of stability. With the platform it was easy to jack the suspension subassembly into place and bolt it in. I only made one small dent in the concrete floor in the process.
We also planned where to mount the rear fuel filter, ordered some of the fuel components, and started to cut holes for the speakers. I will run a small but powerful JL Audio Class D 600/4 amp in the trunk powering 4 JL Audio 5-1/4" speakers - two behind the seats and two in the footboxes (they will *barely* fit). The amp has a neat feature where you can plug any source (e.g., iPhone, through the Lightning line-level jack) into the line in on the amp and control the volume of the amp with an accessory pot that JL Audio provides.
Untitled by Lippy111, on Flickr
  #117 (permalink)
Old 07-27-2013, 06:23 PM
Nice progress … better a dent in the floor than in your Cobra
I like the look of the dual coil over shocks, can't wait to see what it looks like with the FIA wheels. Are you mounting the battery in the right rear fender? Will you use a bulkhead battery cut off switch or the dash mounted racing type with the red key?
  #118 (permalink)
Old 07-27-2013, 08:29 PM
TKB,
I'm just mounting the battery under the hood. I will have a simple disconnect just on the battery, and an interrupt switch on the MSD box.
  #119 (permalink)
Old 07-27-2013, 08:38 PM
I did not know there was room under the hood, especially with a big block motor. Any photos of where it mounts? Will you be using any special heat shielding?
  #120 (permalink)
Old 07-27-2013, 09:54 PM
It mounts on a pedestal directly behind the passenger side wheel. You remove the panel behind the wheel for access. I have the optional heat vent and heat shields, and I am going to add either heat shlelding on the bottom of the pedestal, an insulated battery cover Thermo-Tec : Battery Wrap Acid Absorbing Heat Barrier, or both.
