Old 07-20-2009, 11:00 AM
Cobra Make, Engine: ERA gt40 2076
Default adding power brakes
Bob
How difficult is it to change over to power brakes on my GT40 #2076.
Is this something i could do or does it require a trip to new britain
LLoyd
LLoyd
Old 07-20-2009, 02:49 PM
It's a PITA. We did major surgery on Jose's car. If we can fit a dual booster in the front of the nose, it's "just" a matter of changing a lot of brake lines and running a vacuum pump or a line from the engine. If you want to experiment, I found a mechanical setup that's supposed to reduce pedal pressure by about 35%.
Old 07-20-2009, 03:58 PM
Question Is if possible to go with hydro boost
If the car has power steering hydro boost would work but the brake would be very touchie. Is there a problem with the car stopping? Could you move the linkage on the pedal up or down to change the amount of foot pressure needed to stop the car. Is it possible your bias of front to rear is out of whack. How about larger rotors and wheels like what was on Jim Holdens new GT-40 from Carlisle? That is one nasty looking car. Rick L.
Old 07-20-2009, 05:27 PM
Bob
Why the dual boost. Couldn't you use one boost and a dual cylinder. what would have to be changed to use the reduce pedal pressure setup. Thats my real issue is the pedal pressure. It stops ok but just the peddal pressure. I guess its what we are use to the modern car takes so little peddle pressure to stop
RL
no power steering. The system has two Master cylinders brake setup with a proportioning bar to the pedal, no proportioning valve. I already have large brake disk. Just the pedal pressure is my main complaint
LLoyd
LLoyd
Old 07-21-2009, 04:06 AM
Originally Posted by Lloyd GT40 View Post
Bob
We used a single booster setup on Jose's car. We had to change the entire brake pedal configuration so that a single pushrod ran through the front of the footbox to the booster, which was bolted to a bracket on the front of the footbox. For structural reasons, I didn't like it then, I don't like it now. It also resulted in a large rubber-sealed hole in the footbox for the pushrod.
Old 07-21-2009, 06:24 AM
Bob
thanks for your response. Its not really that bad. I guess i'll just keep things as they are. I don't want to get into a lot of re-engineering. I just thought if it could be done easily i would go for it.
Thanks
PS the car is running stronger than ever. After i replace the rusted the distributor and i now have distributor that advances
it feels like i have all this new found power.
LLoyd
LLoyd
Old 07-21-2009, 10:05 AM
Do you want to experiment?
ECI brake pressure multiplier
You'll need one for the front, one for the rear.
Old 07-21-2009, 11:37 AM
Looks very interesting just put it inline and bleed. It says something about more pedal travel but they don't say how much. A long pedal stroke might be a little unnerving
I'm very interested in it
might be the winter project $320 investment not bad
Have you heard of anyone using it yet???
I'll try to research this
Thanks
LLoyd
LLoyd
Old 07-21-2009, 01:19 PM
Bob do you know the bore diameter of the existing m/c on my car. When i talk to the engineers i'm sure they will ask that question
Lloyd
LLoyd
Old 07-21-2009, 03:42 PM
The front is 3/4", rear 5/8".
Old 07-21-2009, 03:44 PM
thanks Bob
i'll keep you posted, so far google searches are not turning up anyone with experience with an actual install. I think its cheap enough to just give it a try
LLoyd
LLoyd
Old 07-21-2009, 06:58 PM
Bob
i just realized they are in Vernon i may take a ride over and see it in person. Hopefully the will have some kind of test display. I'll take the gt40 over there and let them see first hand what i will be dealing with
LLoyd
LLoyd
Old 08-16-2009, 05:35 PM
Cobra Make, Engine: ERA Cobra 20 427 ERA GT 2075 SVT Cobra 2003 Shelby GT 500 2007
Bob
LLoyd
I am going to talk to Bob about that adapter for my very old ERA Cobra. All I can tell you that the Power Brakes works great on the GT specially with the large brakes. Someday Bob will play with the electric rack.
Old 02-27-2010, 03:01 PM
mmlee's Avatar
Cobra Make, Engine: Lone Star Classics, 351W, T5
Lyold GT40... any updates on the ECI Brake Pressure Multiplier.... It does look promising. I was wondering if you had a chance to try them.
Thanks
Mark
Old 02-28-2010, 06:55 AM
talk to the engineers, they said wouldn't work. best scenario is small volume calibers work best. His feeling would be too much pedal travel to accomplish what i was looking for. So it looks like working out with left leg muscles
Lloyd
LLoyd
Old 02-28-2010, 11:57 AM
mmlee's Avatar
Lloyd,
Thanks for the update. Too bad it's not what we thought. Yeah I guess I'll have to go to option "B" and go with the big brake upgrade and go work on those leg muscles.
Thanks again,
Mark
