08-16-2010, 06:23 PM
Originally Posted by RestoCreations
I was just confused and did not put much thought into the tank. I actually was referring to the oil puke tank on the firewall, but simply did not realize that it was an oil puke tank. Is it a good idea to have one or just something else to look pretty in the engine compartment? Ive never heard of an engine having an oil puke tank.
The oil tank is typically not used anymore. It was where all the drivetrains oils vented to, but today, we use breathers on the engine on the valve covers, the trans has it's own and the Kirkham's provide the one for the rear, so I believe these days the guys who put them on probably do it for the original look and of course, you can make them functional too. I was going to put one on, but they were out of stock and then I did not feel like doing it later. But maybe one of these days.
In short, it's your call. If you want the look go for it.
10-04-2010, 02:53 PM
AL
Cobra Make, Engine: Kirkham 289 FIA, 363 Stroker
New suspension, differential, etc are in the works at Kirkham currently. I should have a functional roller in the near future.
Just thought i would share since the parts should be here in a few weeks. I should be able to turn my full attention to this car in about two weeks.
10-11-2010, 07:38 PM
AL
Old suspension is out. Im ready to start with a clean slate.
I figured out why the front wheels were on one side and the rear on the other-One rear tire was mounted on a front wheel and one front tire on a rear wheel.
Front
Rear
Can anyone tell me if this is the correct steering sector rod?
And, should this carpet area be exposed after the suspension is installed? The only reason i can think for it to be exposed is for access to the lower control arm stabilizer bolt. Is the carpet simply cut out and the area left open, or does something cover these areas?
All reject and proto-type suspension components are out
10-12-2010, 01:29 AM
UK
Hi,
The steering rod certainly isn't the same as mine, so I suspect it isn't correct. There should also be a rubber boot on the inner end.
The hole in the floor should be covered by a vacuum formed black plastic cover on the inside of the car, the same or very similar to the ones inside the trunk (shown below).
This is simply pop-riveted in place.
Paul
10-12-2010, 08:24 AM
AL
Thanks! David thought the steering sector was bad, so i guess i will put that on the list as well with the plastic covers. I appreciate the reply and the photos!
10-14-2010, 04:02 PM
AL
One small step forward. Not many things are more beautiful than the original style Smiths gauges. I will most likely swap the fuel and oil pressure gauges to give the dash a more balanced look.
10-18-2010, 08:53 PM
AL
Milestone
The wiring is finished! I spent about 12 hours on it total. If you need a nice harness that is about as straightforward as they come, i recommend Ron Francis wiring. I also recommend powerbraid wire wrap from painless wiring-great stuff!!! Ill post pictures soon.
10-18-2010, 09:56 PM
Your project is coming along very nicely. Hang onto those 'reject' parts, would make for a nice display along with some photos at a car show
10-19-2010, 07:42 AM
MD
This looks great!
One comment on the order of the gauges (if it matters to you). The correct order for the small gauges from left to right is: Oil temp, Oil Pressure, Water Temp, Amps, Fuel Pressure/Level. Just thought I'd mention it as it is obviously easier to change now if you want to.
www.partskeeper.com
10-19-2010, 07:56 AM
AL
Thanks for the gauge order!
-i was looking in a couple of books I had and at some pictures from the Mecum auction of an original car trying to figure out the correct order. It appeared that they varied from car to car, so i just picked the order that was most similar to the original car that i had pictures of and then swapped the fuel and oil pressure around last night due to the difference in the gauges.
10-19-2010, 12:03 PM
Full Blown Member
Restocreations,
Thanks for the updates. This build is quite unique and fun.
rodneym
10-20-2010, 05:33 PM
AL
Emblems
One more very small step while i am waiting on other parts to arrive.
I tried my best to locate the emblems in the exact location where the original Cobras had them installed. Im working with pictures of original cars from past Mecum auctions.
Traditionally i am more of a fan of very dark blue or guardsman, but this metallic blue is really starting to grow on me.
10-20-2010, 06:57 PM
Ca.
R.C...did Kirkham paint your car or did the studio paint it ???
and how close are you to haveing the "motovation" ready ???
10-20-2010, 07:06 PM
AL
I think the Kirkhams subbed the paint work out to someone, but i am not sure.
Motovation?
10-21-2010, 11:55 AM
UK
The clearance hole around the exhaust looks very tight. It is certainly MUCH tighter than mine and you might have issues with the exhausts contacting the bodywork with the torque reaction of the engine.
It's looking good though.
I assume the "Motovation" is the engine.
Paul
10-21-2010, 02:12 PM
Ca.
Yes....the engine...
10-21-2010, 02:26 PM
AL
I thought it was a little tight as well. I might need to enlarge it and then make polished aluminum plates to go around the pipes-ive seen one original cobra that had a plate like i am describing for heat protection. It looked good.
The car will receive an Aluminum shelby 427 FE block, Edelbrock heads, all forged 482 stroker kit, hydraulic roller cam, and either a turkey pan with a holley carb or webers with the 10 degree manifold. I will have to wait and see how much money is left once the car nears completion to see if the webers will be feasible or not.
10-22-2010, 09:44 PM
AL
New eyes were installed this evening. I purchased these from GB cars for 25.00 a piece as opposed to the 150.00 price per bucket on some of the vendor sites. I could have reused the buckets that came with the car, but the rings were damaged.
Fresh new wiring-done correctly i might add.
Hood prop from Cobra Restorers. Its nice not to be forced to prop it open with my head anymore while i work in the engine compartment.
Trunk prop rod-previously installed. It looks blue due to the reflection, but its actually gold cadmium plated. I bought this from finishline and when it arrived i realized that I did not need the brackets attached to the ends. I simply drilled the rivets out, removed the end brackets, and then attached directly to the mounting locations on the car.
And this nice fella came in today from summit. I will attach it to the firewall tomorrow and hook up the wires. In between watching college football.
10-26-2010, 08:13 PM
AL
The New Suspension came in today. I installed the front suspension and the differential this evening. The differential took a good bit of persuasion to get it past the frame rails and for it to properly seat in place.
I cleaned up frame and panels-no more blue overspray
The NEW suspension from Kirkham is pure artwork.
Check out the new safety feature-or i assume it is new.
Driver's side
Rear-before installation of the differential(still need to give the frame a few more wipe downs to remove the dust)
Differential in place
10-26-2010, 09:59 PM
resto ... nice work! Those pieces are beautiful and as would be expected, fit the car perfectly. You have been making great progress lately, any thoughts as to how soon you will be ready to install the motor and trans?
