Like Tree2Likes
Old 01-18-2013, 09:47 AM
427 Street's Avatar
Cobra Make, Engine: ERA #472, Previous owner of ERA #677 427, ERA 289 FIA-USRRC Street
Default Correct Oil Cooler Hoses and Fittings
The previous owner/builder of my car used silver braided hose with red and blue fittings on the oil/oil cooler lines and fuel line. I do not demand 100% originality but having the correct color scheme as the original cars would be nice. I am trying to mute some of the bling and hot rod parts.
Also, I would need a recommendation on where to purchase those replacement parts. I guess I could also call ERA. Thanks.
"Some things get meaner as they get older."
Old 01-18-2013, 09:54 AM
CHANMADD's Avatar
I too prefer the " less bling " look......
Old 01-18-2013, 10:19 AM
427 Street's Avatar
I was just reading Motor Trend Classic with the 1966 Ford GT Mark II on the cover. I counted over 30 red/blue anodized fittings with silver braid. Any reason why? That is a fully restored multi-million dollar car.
Old 01-18-2013, 10:40 AM
kevins2's Avatar
Having just picked up my ERA a few weeks ago, I can tell you that they only have the silver fittings. I requested these because I didn't want the red/blue fittings. Peter said they don't use those unless customers ask for them and don't stock them. So, Peter could provide the silver fittings if you can't find them elsewhere, although I'd think they'd be readily available at parts stores.
Kevin
Old 01-18-2013, 10:42 AM
Default It's an easy fix...
Forget originality, if they bug you, remove the coating -- it's a snap. I had the red/blue fittings on my remote oil filter fitting and, after a while, I changed my liking. Fifteen minutes after taking a Dremel tool steel brush attachment to it and, voilą. It would have taken me longer to have actually changed out the fittings themselves. Here are the before and after shots:
Old 01-18-2013, 01:49 PM
427 Street's Avatar
Kevin
So, are silver fittings the correct ones? I was wondering why ERA would only have the red and blue ones and why they are also on that GT40
Old 01-18-2013, 01:51 PM
427 Street's Avatar
Patrick, I like your quick fix. It is tough to see but did the wire wheel leave the fittings scratched up?
Old 01-18-2013, 02:41 PM
CHANMADD's Avatar
They did not even have those anodised parts in those days.....
Old 01-18-2013, 03:32 PM
No, it didn't. It's a really easy job and, what's more, you can "trial test" it before you actually do it. Go to your local auto parts store and buy a red or blue anodized fitting end, for about two bucks, then try your Dremel brush out on that one. That's what I did -- and I was surprised at how easy it was and the fact that I had not read about it before on the bazillion car forums that I follow.
Old 01-18-2013, 03:42 PM
Default And as luck would have it...
Here's an up-close shot I took while I was doing the job.
Old 01-18-2013, 04:12 PM
'Correct' hoses and fittings are -12 not -10 that come from ERA.
Also fabric-covered hose, not braid. And the cooler fittings are female, not the common male.
There's a lot more to 'correct' than fitting colors.
Chas.
Old 01-18-2013, 04:14 PM
kevins2's Avatar
Other way around. ERA does not have the red and blue fittings.
Old 01-18-2013, 04:24 PM
My -12 fittings with cloth covered hose. It's not a good close-up, though.
Mando likes this.
Old 01-18-2013, 04:52 PM
Show him the cooler 601.
BTW- i don't think I'd pull spring pressure on that butterfly shaft. Might bell the the bore in the throttle plate. I made a small aluminum bracket for the last stud boss on the throttle plate and used slightly longer springs.
Jes' sayin'...
Chas.
Old 01-18-2013, 05:04 PM
Uhhh, is that the black hose that has the line running up the back? That's my personal favorite.
Old 01-18-2013, 05:12 PM
No that's Earls StartLite with a red thread through it. That's an excellent hose BTW and very light with a 220 PSI (IIRC) rating. Originals had a heavy rubber-like impregnated fabric. Acton probably has it.
Chas.
Old 01-18-2013, 07:14 PM
Jes' sayin'...
That's an optical delusion! The rear of the springs are connected to a Holley bracket that's mounted to the carb base flange bolt. There is no contact between springs and butterfly shaft.
Old 01-18-2013, 07:21 PM
Originally Posted by 601HP View Post
That's an optical delusion. The rear of the springs are connected to a Holley bracket that's mounted to the carb base flange bolt.
Chas got confused. He was remembering Marlene Dietrich in the black hose with the line running up the back.
Old 01-18-2013, 07:30 PM
Us old guys like them hose stripes too. I'll turn 60 in a few weeks.
Old 01-18-2013, 07:45 PM
In our haste to answer your question Mr '427 Street', a big fact was overlooked.
Seeking originality on a street car with an oil cooler?? Why bother when a cooler is 'wrong' in the first place?
Chas.
