9Likes
06-21-2019, 10:27 AM
PORMGB,
I think they quit letting people use the engine date for registration. I used the body year which made more sense to me anyway.
06-21-2019, 01:29 PM
Banned
Cobra Make, Engine: Rowan Replicars, 352 4V
Originally Posted by vntgspd
I specifically sourced and used PCV hose so he didn't say anything. I would suggest replacing the braided lines with rubber PCV hose so you don't waste your time in the event your inspector is diligent. You can probably just slip the hose over the AN fitting for your braided line and clamp it down. It's a visual test, not a performance test.
Bring ALL of your documents, and you should be good. If you were missing anything, they would have noted it at DMV or CHP. But, my inspector wanted to review the docs for their file as well.
Awesome. I have some Mishimoto MMHOSE with PCV stamped on them, and I have an original Ford PCV hose that goes from the valve cover to the air filter. I can always put the braided hose back after.
06-21-2019, 04:49 PM
Banned
Originally Posted by Ron61
PORMGB,
This I what I read from the DMV. I can prove the year of the motor (1959), but either way, I think I will be ok. If I use the body, I will go with 1965 as the year.
4. How is the model-year of a specially constructed vehicle determined?
If the owner chooses to have vehicle's model-year based on the engine model-year, the Referee will compare the vehicle's engine to engines of the era that the engine most closely resembles. Similarly, if the consumer chooses to have the vehicle's model-year based on the vehicle body, the Referee will compare the vehicle to vehicles of the era that the vehicle most closely resembles.
If the engine or vehicle body does not sufficiently resemble a previously manufactured engine or vehicle body, the Referee will assign the 1960 model-year to the specially constructed vehicle.
https://www.bar.ca.gov/Consumer/Refe..._Vehicles.html
06-27-2019, 04:55 PM
Banned
Got my SB100 earlier today, and it was a pretty painless process.
Since I knew the referee for a Porsche 944 LS6 swap, I spend more time discussing GM engine swaps and their PCM's, than my Cobra Build.
The referee did not care about engine numbers but asked what year production car the motor came from, and he checked for a closed PCV system. The referee also went with the body style to determine the year. I gave him all my paperwork, including pictures, and he called the Sacramento DMV. Forty minutes later, he emerged with my sticker and placed it on my firewall, and I was off home.
06-28-2019, 09:44 AM
Cobra Make, Engine: ERA #347
Congrats! It's a great feeling isn't it!
06-28-2019, 06:18 PM
Banned
Yep, after building the car since 2015, it feels really feels good
07-16-2019, 05:29 PM
Banned
All done and was in the DMV all of 20 min. I was bracing myself for the battle of my life, but to my surprise, I had a young lady who was very knowledgable of the process.
One word of warning. Don't start the process until you are ready to register the car, and the CHP+Brake & Light if needed are out the way. I started the registration process 18 months ago and paid for a years registration, and because the car took much longer to complete, the DMV tacked on a load of fees. I was quite fortunate that the DMV took one look at the registration history, and canceled all the costs and credited my registration fee paid 18 months ago to my current year's registration.
07-16-2019, 11:02 PM
As proud as you are of your SB100 you might want to consider graying out your plate number because everyone who visits the site here may not all be good guys. Just saying ...
Ed
07-17-2019, 08:18 AM
Banned
Ed
Good idea!!
07-17-2019, 04:57 PM
Cobra Make, Engine: ERA #629, BBM Side Oiler Block, 482ci, Richmond 5 speed
Just curious about what you think might happen. My license plate number is visible every time I pull it out of the garage. How could that be exploited?
07-17-2019, 05:19 PM
Stitching together online pieces of a digital fingerprint for identity theft. We already have a lot of digital information strewn about, sometimes unavoidably, sometime not. This is just a matter of not making it any easier for bad guys.
When you drive down the road or park at Home Depot the only thing visible Is your plate. Online there are more pieces of your digital fingerprint than you might expect. This is just one more piece that doesn't need to be broadcast.
Ed
07-17-2019, 06:59 PM
Thank you... Chris... why all the paranoia over the Lic plate? we can all see every ones plate in the parking lot... ? is some one here a scoundrel?
12-07-2019, 10:09 AM
NJ
Annual Inspection
I live in NJ and am curious at to what kind of annual inspection you have to go through with the car in California.
12-08-2019, 04:36 PM
Once you complete the registration using the SB100 process, there are no further inspections or smog checks. Just pay the annual fees and DMV sends us new tags.
02-16-2020, 03:29 AM
Finally Registered!
Well after nearly a year I got my SB100 sticker and license plates. Took many calls to Sacramento to reverse the decision of the BAR referee who just made up SB100 requirements that don’t exist. Whew!
02-16-2020, 09:50 PM
ACHiPo - What happened?! Looking back, you posted that you went to the BAR referee back in May of 2019. What did he say was wrong with your car?
With my used ERA Cobra brought in from out of state, my first BAR referee was a real knucklehead who over-analyzed my paperwork. Apparently, the initial order to ERA from the guy who built the car indicated that ERA would be setting the car up for a 289. But the original builder ended up putting a 351W in it, so this state bureaucrat wanted to ding me for that for some unknown reason. I, too, called Sacramento a few times, and ended up getting approval and (purposefully!) going to another, different BAR referee who put the SB100 sticker on my car. For me, the bad experience was at Golden West College, and the good experience was down in Escondido.
PorMGB - sounds like you had it really easy, compared to many. Where was your BAR referee?
02-17-2020, 01:17 AM
The BAR referee(s) declared my car a turnkey, even though I had all my paperwork in order. It took intervention from Sacramento to get them to reconsider and pass the car. Seems the BAR referees are making up the rules on their own.
07-22-2020, 09:31 PM
Cobra Make, Engine: BDR build #983, FRM 392
Here is my story so far:
1) Purchased my BDR Cobra #983 this past May from the original owner who had the car built by Vintage Motorsports back in 2011
2) Car has been titled and registered in Illinois for it's entire life
3) Brought into California end of May
4) Applied for registration and transfer of title at my local AAA office at end of May
5) Once my local DMV office opened after months of being closed for Covid-19, I submitted my paperwork (application for title or registration AND statement of construction) to the agent and had the car verified at the DMV office
6) DMV agent filled out the "Application for Assigned VIN Plate" and told me to schedule an appointment with the local CHP field office
7) Two weeks later, I had my CHP inspection and the officer completed his portion of the "Application for Assigned VIN Plate", basically verifying the VIN plate on the car and the engine serial number.
8) Next is to go back to DMV to return the completed VIN plate form...and then see what happens from there. Still wondering as to when does the Cert of Sequence gets issued?
Funny thing, I asked the CHP officer about the SB100 certification and the upcoming BAR referee inspection. He had no idea what I was talking about.
Uh boy...I'll keep you posted.
07-22-2020, 09:36 PM
4) Applied for registration and transfer of title at my local AAA office at end of May and paid the registration fee and applicable taxes
5) Once my local DMV office opened after months of being closed for Covid-19, I submitted my paperwork (application for title or registration AND statement of construction) to the agent and had the car verified at the DMV office. I do have all of the invoices for the body, chassis, motor and tranny, along with a copy of the MOS.
8) Next is to go back to DMV to return the completed VIN plate form...and then see what happens from there. Still wondering as to when does the Cert of Sequence get issued? And then the BAR referee appointment.
Uh boy...I'll keep you posted.[/quote]
07-22-2020, 09:37 PM
Haha...
Not sure how I 'dittoed' myself in the last post.
