Like Tree394Likes
LinkBack Thread Tools Rating: Thread Rating: 17 votes, 3.12 average. Display Modes
  #841 (permalink)
Old 08-31-2014, 02:25 PM
1985 CCX's Avatar
This std board works great, will drop off the templates after I am done when we work on the final alignment
Should be done under hood this week. Interior floors next weekend.
This part is fun as it brings closure to a long overdue project.
  #842 (permalink)
Old 08-31-2014, 06:12 PM
LMH's Avatar
LMH LMH is offline
Very cool template work on the inner fenders Jeff! Did original comp cars not have the rubber splash guards above the springs?
I figured they were the same as street cars.
Alba gu brąth
  #843 (permalink)
Old 09-01-2014, 06:22 PM
1985 CCX's Avatar
All these cars have been changed since day one. I assume you mean the rubber sheets that span the leaf?
All the comp cars I have been with had the rubber. For now I am good, will add it later. Want to get the driving started.
2136, 2290 and 2345 all have it.
Guessing they all did, however have seen two dragonsnakes void the rubber
Jeff
  #844 (permalink)
Old 09-01-2014, 06:26 PM
LMH's Avatar
LMH LMH is offline
Yeah, I hear you on that!! It's looking great!
Alba gu brąth
  #845 (permalink)
Old 09-01-2014, 08:28 PM
LMH's Avatar
LMH LMH is offline
This is the rubber splash guard I was referring to. You're right, it could be added later if you wanted though.
Alba gu brąth
  #846 (permalink)
Old 09-02-2014, 08:35 AM
1985 CCX's Avatar
Yes, easy add on for later date
  #847 (permalink)
Old 09-14-2014, 05:24 PM
1985 CCX's Avatar
Alloy is in...........................
Trying to get this wrapped up so I can drive before snow..........
  #848 (permalink)
Old 09-15-2014, 02:13 AM
*13*'s Avatar
Very nice! Putting a plate on the front is always psychological blow. How did you mount yours?
ERA FIA 2088
  #849 (permalink)
Old 09-15-2014, 06:09 AM
1985 CCX's Avatar
You mean the flat part in the cowl?
I did it up like 2136, I have front tubes that go under the cowl which provided mounting points on all corners.
Or you mean the license plate? Mounted with ally part, as OEM mounts were done.
289 cars mounted the plate straight to the body via a small alloy part. 427 used the spring loaded bumper position.
  #850 (permalink)
Old 09-15-2014, 07:11 AM
*13*'s Avatar
Got ya. I didn't do anything per originality with my license plate. Just a couple angle brackets from aly
ERA FIA 2088
  #851 (permalink)
Old 09-15-2014, 07:37 AM
1985 CCX's Avatar
These were simple cars and the bracket usually they face up, sometimes face down. Think correct is up...
  #852 (permalink)
Old 09-15-2014, 10:43 AM
Dan Case's Avatar
Original Shelby Owner
Flange up.
Dan Case
  #853 (permalink)
Old 09-15-2014, 07:18 PM
1985 CCX's Avatar
Scoops are going in............. thanks Dan.
I know, not evened out yet
TN Shelby Cobra likes this.
  #854 (permalink)
Old 09-16-2014, 04:26 AM
*13*'s Avatar
I couldn't mount my license plate there. It would have blocked the oil cooler. I mounted it from underneath. Scoops look good!
ERA FIA 2088
  #855 (permalink)
Old 09-16-2014, 01:28 PM
1985 CCX's Avatar
That's because the FIA cars did not use front plates......
  #856 (permalink)
Old 09-16-2014, 02:53 PM
*13*'s Avatar
I thought about not running a plate. Chances are I would get pulled over regularly. There were two bolts underneath for the cooler shroud so I just went ahead & fashioned some brackets. Plate is ugly on there but, what's a guy to do....
ERA FIA 2088
  #857 (permalink)
Old 09-16-2014, 02:56 PM
1985 CCX's Avatar
Pictures........
  #858 (permalink)
Old 09-16-2014, 03:23 PM
*13*'s Avatar
I see how you are...
ERA FIA 2088
  #859 (permalink)
Old 09-17-2014, 05:54 AM
55312's Avatar
Hyde
Ever since the Vermont Strong plates came out, you are not required to display your front plate. There is a catch though, you have to have it with you
Politicians !
Tim
  #860 (permalink)
Old 09-17-2014, 07:19 AM
*13*'s Avatar
It's on now & I don't have to worry about it bouncing around in the trunk.
ERA FIA 2088
