Like Tree394Likes
LinkBack Thread Tools Rating: Thread Rating: 17 votes, 3.12 average. Display Modes
  #1121 (permalink)
Old 06-17-2015, 03:28 PM
1985 CCX's Avatar
Default 289 gusset suspension upgrades
Update:
Well the A-arm work has gone well. The sleeves were machined as well as the adjusting receiver so castor can be set at about 0.4 degree. Should suffice well for the majority of street use. Will post a few pics once we get parts mated back together.... Thanks to Jeff Tamplin a friend for machining SS adjusting nuts.
Also added 289 third gusset bracket to the A-arm connection points on the frame. This is the way the race cars did it and with heim-joints probably great insurance for track use and the occasion performance romp.
This way the connecting bolt passes through the std attachment point and also on the other side of the Heim-joint. Spreading the load if you will on the frame........ :cool
Sourced outside welding assistance, I did the remainder of reassembly work ........... Yup yours truly.
  #1122 (permalink)
Old 06-17-2015, 04:05 PM
*13*'s Avatar
Always fun to watch the result of your obsessive disorder.
ERA FIA 2088
  #1123 (permalink)
Old 06-17-2015, 08:13 PM
mickmate's Avatar
The original 289 control arms have solid inner bushings that put their mounting bolt in single shear. When you change spherical or heim jointed control arm bushings for adjustment that moves the pivot points away from the single shear to a cantilever, all that on a sheet metal mount. By adding the plates we have now put the mounting bolts in double shear which is a huge improvement in strength and safety. I've ridden in this quick little beast and it sure needs it.
mickmate
http://www.actoncustom.com/
  #1124 (permalink)
Old 07-05-2015, 05:01 PM
1985 CCX's Avatar
Out cruising with my wife at dusk
The Weber car is so different than std carb car.
The little buggy handles great and really is enjoyable to run.
  #1125 (permalink)
Old 07-05-2015, 05:03 PM
*13*'s Avatar
That sound between gears is pretty tough to beat!
ERA FIA 2088
  #1126 (permalink)
Old 07-05-2015, 05:09 PM
1985 CCX's Avatar
http://youtu.be/1dPrjiTfW6c
Little video.
  #1127 (permalink)
Old 07-05-2015, 05:11 PM
*13*'s Avatar
Sounds quite familiar.
ERA FIA 2088
  #1128 (permalink)
Old 07-06-2015, 05:30 AM
*13*'s Avatar
Just cause' you can never get enough of that small block weber sound...
https://instagram.com/p/4ywE6KEz0-/
120mm likes this.
ERA FIA 2088
  #1129 (permalink)
Old 07-06-2015, 08:49 AM
1985 CCX's Avatar
Hyde
You on a dirt road? Yikes....
  #1130 (permalink)
Old 07-06-2015, 08:52 AM
*13*'s Avatar
5 miles of dirt get me home, yes. Vermont...
ERA FIA 2088
  #1131 (permalink)
Old 07-07-2015, 02:49 PM
1985 CCX's Avatar
Christmas in July from my friend in KS
New spare wheel for trunk or extension cords in garage.
CompClassics likes this.
  #1132 (permalink)
Old 07-07-2015, 02:51 PM
1985 CCX's Avatar
In addition to this treat.
With three other matching parts.
  #1133 (permalink)
Old 07-07-2015, 02:58 PM
*13*'s Avatar
Nice wheel!
ERA FIA 2088
  #1134 (permalink)
Old 07-07-2015, 04:16 PM
1985 CCX's Avatar
Comparably speaking it is super heavy.
  #1135 (permalink)
Old 07-11-2015, 02:46 PM
1985 CCX's Avatar
Out enjoying summer.
Charging issues were due to bad battery. Seems sorted not replacing Autolite yet until fully trusting after some miles are totaled.
Buggy looks good with CCX Joe.
  #1136 (permalink)
Old 07-11-2015, 02:53 PM
1985 CCX's Avatar
Peter Klutt will now be making my glove box door for this car.
Sent off the lockset and pattern.
Thanks to Legendary for this peice. Will post picture once arrived.
Will no doubt be awesome.
  #1137 (permalink)
Old 07-14-2015, 03:02 PM
1985 CCX's Avatar
Default Racewhere
Getting a coolant tube via RACEWHERE sent out for the buggy.
Will help avoid a sudden burst in the line.....
Thanks John
  #1138 (permalink)
Old 07-14-2015, 06:36 PM
1985 CCX's Avatar
Taking a vote .........
Add a pocket over gas cap?
Don't add pocket over cap?
  #1139 (permalink)
Old 07-14-2015, 07:34 PM
xb-60's Avatar
Coincidentally, I was wondering about this just recently.
I would go with a hole in the tonneau. What do you achieve by adding a cover over the gas cap? All that probably does is create a hefty stitched joint that could rub the paint. On the other hand, that might add nicely to the patina....
Glen
  #1140 (permalink)
Old 07-14-2015, 08:24 PM
LMH's Avatar
LMH LMH is offline
Yeah, just stitch an edge to the hole and leave it open. That's my opinion anyway.
Alba gu brąth
