Old 03-21-2003, 04:06 PM
Blake Olson's Avatar
Location: Right in the middle of the beautiful Texas Hill Country - Boerne, Texas,
Send a message via Yahoo to Blake Olson
Default Can I open up the sidepipes?
Has anyone ever taken the "baffle'ing" out of their sidepipes and ran open pipes?!
just curious
Blake
"They're lining up on both sides of the ocean..
and nobody's willing to compromise
in the search for the smoking gun..."
"Charlie Don't Surf!"
Old 03-21-2003, 05:17 PM
Jeff Frigo's Avatar
Very loud, draws a ton of attention, very cool.
Jeff
Mark Donahue
Old 03-21-2003, 05:46 PM
excelguru's Avatar
(An All-Around Nice Guy)
Cobra Make, Engine: Unique Motorcars (sold)
Talking
Mine are practically open. I can use a flashlight and a small mirror at the outlet end and clearly see the four collector tubes at the other end. Makes for a wonderful sound. Mine came this way from Unique.
Keith
Keith
Former Unique owner.
Old 03-21-2003, 06:11 PM
Cobra Make, Engine: B+B 351w #112
I don't know what B+B uses for baffling in their side pipes. Mine seem to be getting louder the more I drive it. Jim
Old 03-21-2003, 06:39 PM
Brent Mills's Avatar
Administrator
Mine are pretty much straight pipes although I use a dynomax bullet track only muffler (find them at Summit). Not much in the way of baffle, as there's nothing restricting flow. Loud and sound great.
Old 03-21-2003, 07:10 PM
kountzecobra's Avatar
I can take the baffles out of my sidepipes very easily. Real loud and obnoxious. Just the way it should be!
David Shelton
Lone Star Gashole!
Old 03-21-2003, 07:43 PM
bmalone's Avatar
I think there are two issues here. One is the baffling--it can be removed/replaced, etc. The other issue is the size of your collectors. A lot of them are around 2", which is really the restriction--not so much the baffles.
I had my pipes done. This consisted of cutting them open and opening the collector to 3", then put racing mufflers in and wow, what a difference. Sound is acceptable at idle (barely) and quite loud under throttle. Made a lot more power.
I highly recommend this place:
JBA Racing
Bill Malone
Gashole
CSX4786
Old 03-21-2003, 07:49 PM
Slow Dawg's Avatar
Cobra Make, Engine: 2 Seat Roadster-by B&B, 460+ w/auto.
Blake, call Bryan and have Barry make you up a set of shorty's. Collector to turnout. No muffler in between.
Nonconformist. Can't handle a real job.
Old 03-24-2003, 07:44 AM
Ron,
I was just going to have the local welding shop open them up, remove whatever is in there, and re-weld them...
I started the motor with just the headers yesterday..man...drove down the driveway and back...lot's of "poppin", backfiring, etc...
is that normal??
blake
Old 03-24-2003, 09:10 AM
Cobra Make, Engine: SPF - 427 Stroker
is that normal??
blake
Blake - You do need a certain amount of backpressure otherwise you will have that backfiring and poping...And, you also get too much backpressure when you try and hollow out the pipes and make the exhaust run that far - it can actually cause you to drop hp...The "shorty" method Slow Dawg mentioned is usually the best solution - for the track...Doing it on the street might attract a little TOO much attention.
NEVER LIFT
Old 03-24-2003, 09:16 AM
Maybe I can have them take "some" out but leave some in!? Not even sure what's really in the pipes.
what's the "shorty" method?
blake
Old 03-24-2003, 09:50 AM
bmalone's Avatar
Blake, why not use racing mufflers inside the pipes? That and opening the collector to 3" gave me a signifigant improvement.
Bill Malone
Gashole
CSX4786
Old 03-24-2003, 10:43 AM
I made my own sidepipes. I bought a cheap pair of 4" glass packs, cut them open and removed the core. Then I made my own cores by taking a piece of 3-1/2" pipe and milling slots in it that are 3/16" wide x 2" long. The slots run length-wise, all the way around and the full length of the core. I wrapped the core with stainless steel wool, slid the outer shell over it and rewelded. The more slots you mill in the core the quieter the pipe will be.
Performance is the same as 3-1/2" straight pipes. They are loud but the high pitch ringing is eliminated.
I made these because my carbs are all calibrated for open headers.
The standard straight core glass pack uses up to a 3" louvered core (in the 4" OD models) and I can't run them with out recalibrating my carb.
Scott
Old 03-25-2003, 01:46 PM
I went to go "inspect" the inside of the pipes just a few minutes ago...basically there is an insert with cut outs surrounded by fiberglass??
I think i will just take the fiberglass out...
what effect will this have?
thanks
blake
Old 03-25-2003, 01:58 PM
Cobra Make, Engine: Unique 289FIA / SA 351W / a truly glorious machine
Not to bring down the "wrath of God" on me, but on the flip side of this discussion-- How would you quiet them down a bit.?????
Old 03-25-2003, 02:04 PM
I "blew out" the baffles in the Excal by simply downshifting WAY to early and hitting high rpm with the engine. Worked great, all though I wasn't TRYING to downshift early,,,,, That corner at the end of the straight comes up REAL fast and sometimes I got "nervous", lol.
Wouldn't recommend this method to anyone with an FE.........
Ernie
Old 03-25-2003, 02:05 PM
Cobra Make, Engine: Contemporary CCX33868 Sold. Just "playin' the boards now."
Blake,
My "mufflers" came from Butler Racing and were welded onto the short collector. The turnout is part of the muffler. If you want loud, they'll do it in spades. Calling them mufflers is almost a joke.
Butler put in a spiral wound core and nothing else. They were loud new, but never changed. With my compression, they had a nice bark at idle and would just about take your head off when the rpm's were up!
My engine was dynoed with them on the engine and it still made nearly 500hp.
Oh, btw, dogs don't like them at all! There is a high pitched resonance that they can hear and we can't.
Also, I never even had a cop look at me for the noise. Mostly they just grinned when they saw and heard the car.
Try the Butlers. I guarantee you'll like them.
Al
"If some is good, more is better.
And too much is just enough."
--Carroll Shelby
Old 03-25-2003, 02:14 PM
My question is,
do I need to remove the inner part of the pipe? it's a insert of sorts with nickle sized holes bent, to create turbulence I assume..or should I leave it in there and just remove the fibeglass surrounding it?!
blake
Old 03-27-2003, 05:49 PM
Cobra Make, Engine: B&B 408W, TKO 600, 9" 4-link Truetrac, 13" X 1 3/8" curved vane frt disks
scottj,
You put a 3.5" core inside a 4" pipe? Does that mean you only had 1/4" clearance to stuff the wool in? How may slots did you cut?
Old 03-27-2003, 07:45 PM
DaveR,
Yes, yes, 91. Correction: not a 1/4", closer to .190
You can't believe it fits can you?
I cut 13 slots around the circumference by 7 slots lengthwise over 24". I wrapped the core with a fine stainless steel wool from a 12" wide roll and wrapped that with wire to hold it tight. Then I took a tapered style piston ring compressor for a 4" bore and turned a step in it on the lathe so it could be tightened securely on the end of the 4" pipe. Then the core could be shoved in without snagging on the outer pipe.
If you don't mind the look of a 5" pipe they could be allot quieter and still perform like an open pipe. Although a 3-1/2" core will never be "quiet".
