| 1 |
| 8 |
| 15 |
| 22 |
| 29 |
05-16-2006, 08:52 PM
Registered User
mn
Fasterpatricks Custom Cobra
05-17-2006, 11:40 AM
Registered User
OH
Cobra Make, Engine: Undecided, 289
Very Nice!  I'm wondering what spindles you are using up front? I have looked through some of your older post, but didn't see anything mentioned.
Jay Little
05-17-2006, 03:47 PM
Registered User
fl
Cobra Make, Engine: scratch building
And the fun begins...tank after tank of argon...and a lot of reading and figuring.....Keep us posted with your progress..
Al
05-17-2006, 04:26 PM
PA
Cobra Make, Engine: CSX2498 has been in our family garage since '69....Scratch built aluminum bodied 427SC Cobra, 427FE, CSX3000 chassis specs, almost finished running go kart 6/24/09
have fun Pat.
keep posting photos & have fun, Karl
05-17-2006, 08:13 PM
Registered User
mn
Front end parts are mustang II repo units with 11" rotors and manual rack, All from speedway motors. Got the whole works spindels, rotors, brakes, ball joints, steering rack, tierod ends, and assorted hardware for just over $700. Not a bad deal. It's pretty much what they use for modified stock circle track cars. Pat
05-30-2006, 08:38 PM
Registered User
mn
I have a question, which would be better solid aluminum steering rack bushings or should I use delerin(Poly). I will be machining the myself and stock for both. Just a survey question. Pat
06-05-2006, 09:29 PM
Registered User
mn
Hey everyone,
Look what happened, while everyones out driving around I'm in the shop working. Just a few photos of what I've been up to  Pat.
06-05-2006, 11:21 PM
You have skills.
-Dean
06-09-2006, 07:09 AM
Registered User
Cobra Make, Engine: Scratch Build
Awesome, Patrick, now I really want to get moving. I love your table, and wish I saw it sooner. I am almost done with mine. It is made of 7 nine foot 6 inch I-beams. It is too much table for my single bay garage.
I will try to finish it this weekend and make my first cut on the 4 inch tubes.
Thanks for the inspiration.
Iggy
06-09-2006, 09:23 AM
Registered User
Patrick, this may only add weight, but do you think that it would help to drill out a hole in the front pumkin cross piece where the bolts go and weld in a section of pipe. The pipe would be flush top and bottom, also it would be welded top and bottom. So the cross piece would hold it steady, but never see compression. The bolts would just fit in the pipe. Just thinking that now you could tighten the pumpkin untill the bolts break without any stress on the parts.
I do see that the cross piece is so thick that this might be overkill.
Iggy
06-09-2006, 08:47 PM
Registered User
mn
Iggy,
I have done that many times in the past but with lighter stock. this crosmember is 3/16ths thick so yes it would be overkill. Was thinking about making the bottom hole large enough to tuck the bolt up inside the crossmember. That would make for a much cleaner look. Pat
06-25-2006, 10:51 PM
Registered User
mn
rear suspension drawings
Hey guys,
Well I'm back, took the family to see dead presidents carved in stone. Black hills camping vacation, long drive but worth it, good time. Been getting more parts together and lots of cad time.
PLease tell me what you think of this for rear suspension layout nothing is set in stone yet. Will work in shock mounts when the shocks arive so I can get them drawn in the computer.  Pat
06-26-2006, 10:10 PM
Registered User
Patrick
Since you are still in the design stage you might look at the rear cover from an 8.8 Explorer, I like the mounting much better. I can get them for anyone interested for about $35 to $40. I believe with a load your arms would bend at the curve. I'm going to adapt the Locost Roarty plans for the 8.8 IRS. I know it is a Lotus 7 type but the general Idea would be the same. http://locost7.info/files/suspension...RSAssembly.pdf
06-27-2006, 10:57 PM
Registered User
Cobra Make, Engine: scratch built aluminum chassis/bb
Hey Pat,just a quick observation on your great work. I usually wait untill last to permanently mount the rack, this saves lots of time when sorting out any bump-steer.
06-28-2006, 06:08 AM
Registered User
Pat it looks good. To Hesss'es point, you could diagonal the lower back arm (vs curve). The upper arm on many (Jag, FFR) is a single arm. The FFR uses an angled lower rear arm. The Heim joint hits at the same angle. Also the Lower rear mount is set 3 degrees lower than the front. I am told that both of these add anti-squat. I think that the angle binds the joints under power and tends to add anti-squat and toe-in (a desirable thing). I do not remember how the original was setup (I don't think it had the 3 degree down angle), but will look tonight. I also have a book somewhere that gives some guidance I’ll check this out. I also have seen where people use spherical bearings vs bushings as they may move more than the arms flexing.
Iggy
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
