Old 10-04-2010, 09:01 PM
kitcarbp's Avatar
Default HELP ! Stuck Clutch Disc or HTOB Air Trapped??
OK Guys, NEW SET -UP. I have set-up my McLeod HTOB with about 0.160 gap from PP fingers to bearing face when piston is fully seated (not extended) (McLeod quotes it needs to be .100-0.250) to allow for clutch disc face wear over time. Clutch and pressure plate was installed over 4 years ago on this new build without ever being tested and I wonder if disc is stuck to flywheel????. What I know: I can select a gear on the TKO 600 and start the engine and confirms clutch disc is engaged because wheels turn. I CANNOT depress the clutch pedal while engine is running and select a gear or grinding will result. I have noticed if I place a small amount of pressure on shifter handle into any gear (with or without depressing the clutch) it begins to rotate the drive shaft and rear wheels when up on stands. How do I tell the difference between a stuck clutch disc or a HTOB that needs to be bled some more ? (I can see the HTOB travel about 1/2") but Im not sure if thats enough. What say the experienced ones out there ?
1) Do I run the rear wheel speed up to 70 mph in 4th on jack stands and while clutch is depressed, stab the brakes hard to try to free the disc ?
2) I plan to try to bleed one more time but my pedal is firm and feels good and bearing is moving into pressure plate fingers Im just not sure if its enough.
Old 10-04-2010, 09:28 PM
DO NOT run the car to any speed on jack stands. You take an awful chance of it falling off of the jacks and running through something or actually hitting someone.
My guess is that you need more travel of your through out bearing. How you are going to do that I am not sure. You might need to change the clutch master cylinder to a different bore.
Terry
Old 10-05-2010, 10:11 PM
kitcarbp's Avatar
I ran the car in gear in the air to warm up trans and rear axle fluid to check for leaks and all is OK so far. I have heard others claim light oil like wd40 is OK to use to soak a stuck clutch disc a little to help break it free if its stuck because once you put heat into disc with use, the wd-40 will mostly evaporate and not harm the dual friction material. I am using 500 series Mcleod disc on SS Mcleod flywheel (Ford Racing). Who has tried this or other light weight lube to unstick the disc ? Never been here before, any others been here ? Thoughts appreciated
update: i Confirmed my disc is not stuck, it just appears I need more concentric slave movement.
Old 10-06-2010, 03:34 PM
lal Naja's Avatar
Cobra Make, Engine: Butler Cobra. 350 Chevy Engine, blueprinted, heads cc'd, ported, polished, manifolds matched, big valves, 1.6 roller rockers, TB Injected, mild cam, MSD crank trigger electronic ignition. TKO-600 transmission. XKE Jaguar rear. IFS by Fast Cars
Does your clutch pedal have any of the following options:
1: A travel stop? If it does you can adjust it for more travel.
2: Additional holes in the pedal for push-rod mounting. If so, move the rod away from pedal pivot to get more travel into the master-cylinder.
Also try to reduce/eliminate any gap betwen the pedal pushrod and master-cylinder to maxamize the fluid displacement. With a little luck you may be able to have the slave-cylinder move that little extra to create the gap between clutch disk and pressure plate.
If you do not have the above choices you will have to increase the bore if the master-cylinder.
Good luck with it.
Arthur
Old 10-11-2010, 08:51 AM
kitcarbp's Avatar
Default Update
OK , After some experiments , I confirmed the clutch disc is free to turn and not stuck to flywheel. I also confirmed my Wilwood 3/4" Master cylinder is stroking 1.00 inch as it should according to McLeod. At 1 inch of master cyl. stroke my pedal bottoms out on the pedal stop as designed. and Mcleod claims HTOB piston travel is max 0.890 when using a 3/4" master with 1.00 inch stroke.
I also confirmed from the Mcleod clutch instructions the PP fingers should be depressed about 0.375" to disengage clutch disc. EDIT: WRONG INFO: .375 is when it begins to lift off pressure plate, it needs close to a full 0.500" for complete release !!!!! I am now thinking there is still air in the HTOB system that is not allowing the full .375" movement, I can't easily reach into bell to measure HTOB movement but it looks (via a mirror) HTOB piston moving closer to 0.250" but not sure till I try to measure it with a stiff piece of wire or some other gauge.
It appears that the air gap @ disc is just not enough to completely stop the trans input shaft from turning when trying to shift gears, so ive determined the HTOB its definitely not pushing the pressure plate fingers far enough yet. Mcleod quotes an air gap should be 0.050" between disc and flywheel. but I cant get into measure it easily. Will need to make a feeler gauge 2 feet long to get in there. I'll post an update when its solved.
UPDATE
I just read that the Wilwood 3/4" master cly can stroke up to 1.10", I have mine set to 1.00" with my pedal stop since I am so paranoid to over-stroke the HTOB piston past its seal after all the horror stories I have read. Seems I need to ensure all air is out first and if needed get the extra 1/8" of master cyl travel.
Old 10-11-2010, 09:20 AM
Sounds like you are on the right track … for a gauge, try a strip of sheet metal and different thickness 'tips' that are firmly attached, made of wood or plastic scraps, as kind of a feeler gauge.
Old 10-12-2010, 09:04 AM
kitcarbp's Avatar
tkb I was thinking the same thing. I am trying to measure bearing travel through the bellhousing with what use to be the OEM clutch fork hole, I can only see this by using my mechanics mirror Mcleod also recomended (in the fine print of course) to drill a hole in the bottom of the OEM bell housing to allow easy disc air gap measurements during clutch set-up to ensure 0.050". I should have done this to make measuring easier in hind-site. Now its a little trial and error. Lesson learned.
Arthur, Since I am using a concentric slave, if I increase the master cyl bore beyond 3/4", yes I'll get more fluid displaced per stroke, but the concentric slave will over extend (beyond the design limit of 0.500" and leak. EDIT May 2011 : I was wrong, even a 13/16 bore will not over extend the htob piston with 0.160 initial gap to PP fingers. I did the math then measured it on the car. The pedal stop of course can control this. Mcleod claims the 3/4" master cyl is all thats needed to get the 0.500" travel from concentric slave. I need to prove to myself that I am already @ 0.500 concentric slave travel, ( be bleeding again and measuring the travel) which I haven't done yet, before I go to the next step. I figured I can make a gauge using rigid copper house wiring to check for 0.375" travel at bearing. What I need is a telescope gauge on a flexible handle. Hmmm necessity is the mother of all invention as they say.
Thanks all
Old 10-12-2010, 09:43 PM
lal Naja's Avatar
Good luck with getting it resolved.
I've recently installed a HTOB (Hydraulic Throw-Out Slave/bearing) on my TKO 600. And I made sure I "measured twice and cut once" to get everything setup correctly. I was not pleased with the conical shimming washers that came with the HTOB. So after taking all the measurements I machined a solid metal spacer and tossed the washers.
I also made sure that the bleed line pointed up so that all air would collect at the top and evacuate when bled. I drilled a hole in the top of the bellhousing for the bleed line and welded a steel shroud to hold the bleed line firm and vertical. Bleed valve in the top of the hose made bleeding a one man operation with 100% success.
Have fun,
Arthur
Old 10-25-2010, 12:51 PM
kitcarbp's Avatar
Default Update
So I made a crude GO NO-GO gauge from copper wire and I measured the total movement of my Mcleod HTOB and my crude wire "gauge" measured about 0.390" of HTOB movement for my total clutch pedal travel to the floor board. The Mcleod info i have, states 0.375" PP finger movement is required to release the disc. This make sense so far because, I also placed the car up on ramps while in gear with engine off and confirmed the clutch disc does in fact release upon pressing the clutch pedal down about 3/4 way, and the car rolls off the ramps. I still have just 1.0" of master cylinder travel compared to 1.10" possible. I also confirmed I would have to remove my pedal stop completely to get more than 1.0" stroke at the MC. May try this tonight to get 1.1 " at MC to see if I can get 0.420" or more total travel @ HTOB. It seems the PP is not fully releasing the disc and keeps spinning the input shaft.
I also attached my Mity-Vac brake bleeder hand pump to the HTOB bleed line and tried to pull any trapped air out of the assembly. After pulling more than 20 oz. of fluid through it with the Mity-Vac hand pump , I am still seeing air bubbles coming out of the bleed line! (reservoir was always kept 3/4 full, it never dropped too low during the bleed process)
I am still stumped, where is the air coming from ? I have yet to try the old fashion pump the pedal and bleed with a helper. Do I need to go back and open the Master Cly bleed screw on my Wilwood MC and re-bleed the MC ? My belief is that @ 0.390" its still not enough PP movement to completely stop the input shaft from turning. I can still move the HTOB bearing another 0.120" before I over extend it, 0.500" is max travel of the HTOB according to Mcleod.
What I have not confirmed yet is if the HTOB piston is moving proportionally
to the MC stroke of 1.0", if it does not, its got air in the lines (which the bubbles are confirming) Dah !.
I'll be back at it this week, any other tidbits appreciated.
Old 10-25-2010, 04:52 PM
Did you grease up the bleeder screw threads?
When using a vacuum bleeder you will usually suck air @ the threads making it appear you have air in the system.
Craig
Old 10-25-2010, 08:33 PM
lal Naja's Avatar
Try using a speed Bleeder (link below) it makes bleeding a one-man-operation. The threads have a compatable thread sealer on them and it has a one way pressure relief valve built-in to allow air and fluid to exit only.
I bled my HTOB in about five minutes with no help. I love it
http://www.speedwaymotors.com/Speed-Bleeders,942.html
Arthur
Old 10-25-2010, 09:18 PM
Craig
This is a good tip and an important place to look ... air at the threads ... but be sure to use the correct pipe dope or other substance that is compatible with the clutch system components and fluid.
Old 10-26-2010, 04:17 AM
We used to call it "Rubber Grease." It would come in teeny weeny little containers, and I vaguely remember them being red. You never see it in the auto parts store anymore -- ever. You'll probably have to pick it up off the internet and you would generally use it when rebuilding a master cylinder (clutch or brake).
EDIT -- Here you go, this is what I'm remembering. LUCAS Red Rubber Grease.
Last edited by patrickt; 10-26-2010 at 04:36 AM.. Reason: Found LUCAS Red Rubber Grease
Old 10-26-2010, 07:57 AM
xlr8or's Avatar
Are you sure the snout of the input shaft isn't bottomed out in the crankshaft?
Old 10-26-2010, 10:46 AM
kitcarbp's Avatar
Thanks you guys, after I posted , I thought, THE BLEEDER SCREW! MAKES SENSE.
No, I did not put sealant on it (did not even occur to me !!) and I bet thats exactly where its bringing the air in when I'm pulling vac through it.
xlr8or, I thought the same. When I set up the trans on the Bell Housing and engine , I did confirm I had enough clearance to the BOTTOM of the crank pilot hole, (even with my OEM motor plate ( I think its 0.070 thick)) but its a tapered hole (behind the pilot bearing) and I am beginning to wonder if I measured in the wrong spot and the input shaft nose is riding on the crank pilot hole radius area since I know its not bottomed out. The other possiblity is my concentric measurements were wrong , but the roller type pilot bearing I am using should be toasted by now if the input to crank concentricity is off, and I would have expected trouble assembling the trans to engine if concentricity is off, I measured total 0.010" off center concentricity which is at the upper limit but should be OK right ????. One way to check/diagnose input shaft to crank pilot clearance I guess is to loosen the bell housing bolts a tad and place "U" shaped shims between the bell and engine block at each bolt location to see if this solves the issue before I pull the drive train out to measure again. Of course than starter must be shimmed same amount and HTOB must travel a little further also. Input shaft dragging on the crank is the only logical thing left after I confirm I can get a little more than 0.400" HTOB piston movement.
Thanks for your input
Old 10-26-2010, 01:19 PM
roadrod2000's Avatar
Cobra Make, Engine: Unique 289 FIA HiPo 289 with Shelby dual quad intake
If you are useing the 1300 series HTOB the max movement from full compresion to full extention is .89 inch. With the 3/4" MC and 1.1" available stroke I don't think you can over extend the HTOB even after you add the .1-.3 inch clearance. Check my math and then losen that pedal stop
Old 10-27-2010, 07:13 AM
kitcarbp's Avatar
ROADROD, Your math is right. On my long D.C. area commute home last night (and after reading other Mcleod clutch users posts, it occured to me, that I dont have enough Mcleod 1300 series HTOB movement yet. Although Mcleod states "0.375" Pressure Plate finger travel required" I believe that is for "initial" disc release, not "full" disc release, thus that is why my disc is still dragging on PP and not fully released @ my measured 0.390" HTOB piston movement. I think I get it now.
I also found an email from Mcleod on their web-forum where they expect FULL disc release at 0.500" HTOB piston travel, thus, now I see is the source of my confusion. If I would have been a little smarter, and drilled a hole on the bottom of my OEM bell housing, I would have seen that I dont yet have the desired 0.050" air gap between PP and disc at 0.390" piston travel.
You are spot on about 3/4" master and the bolt on HTOB, I wont over extend it with 1.0 or even 1.1" of travel with my current clutch pedal geometry after looking at it upside down via my mirror under the car last night.
I also realized the kit builder (West Coast) installed the clutch pedal stop after years of selling some cars with 7/8" Masters (For Tilton HTOB) that would in some cases over extend the HTOB (slip-on style) bearing if used on a Mcleod HTOB without a pedal stop. When they started supplying pedal stops on the kits, they also realized 3/4" masters are a better choice for pedal effort and preventing over-travel, they left the pedal stop in place (which I now realize was likely intended for using a 7/8" Master to protect from over-stroking the HTOB and leaking. I will now remove the pedal stop (that will give me another 1/4" of pedal travel and move that HTOB piston travel closer to 0.500" I think.
Thanks to all for your posts, its becoming more clear to me now. I love this Forum and could not do this project without all the help I have received.
I will report back in the next days.
Bill
Old 10-28-2010, 06:49 AM
kitcarbp's Avatar
Default More HTOB Bearing Travel, Progress !
Ok the update is after removing my clutch pedal stop completely, this gives me the 1.1" of travel now on the clutch Master cylinder (3/4" bore). The HTOB now moves about 0.450" after contacting the PP fingers. It was too late to fire up the car and scare the neighbors last night so I will test if the 0.450 is enough to completely release the clutch disc now.
Bill
Old 05-18-2011, 07:02 AM
kitcarbp's Avatar
Thumbs up Update
Ok ,since my last post on this topic I havent spent time at all on the car since last November. I'm back at it now and determined I was only getting partial clutch disc release with 0.480-.490" (crude measurement) of movement from my McLeod HTOB. This is with the 3/4" Master and 1.1" of stroke. I think I need no more than 0.100" of ADDITIONAL pressure plate movement to get full release of the disc (I can shift ok now but rear wheels still turn with clutch pedal all the way in, indicating disc is still dragging. The Mcleod states total HTOB movement from full compressed to full extention is 0.890". So with my 0.160" initial gap to PP fingers with piston fully compressed + the 0.480" of current piston movement, I have (0.160+0.480)- 0.890 or 0.250" left until I'm at the end of HTOB piston travel.
ANSWER: I confirmed today it takes 0.575" pressure plate finger compression to COMPLETELY disengage my clutch disc. Clutch pedal to the firewall (full travel) and input shaft fianally stops turning @ 0.575" of HTOB movement !!!!!. But this comes with a too large of a pedal tavel so the 13/16" bore M/C will remedy that situation.
So yesterday I ordered the next size up Master Cyl which is the 13/16" bore which I hope, with the little extra fluid volume will find the "sweet spot" for clutch pedal stoke, and of course, the complete release of the clutch disc. I'll report back after its installed. Pedal force should remain resonable as well.
I have a stupid question for those with these concentric HTOB's. Where do I find the published piston area for the McLeod's HTOB? Do i have to measure it myself ? I have a few extra's left from my intial set-up I can measure.
UPDATE: I could not find any published piston area sizes, So I measured a spare concentric piston for the bolt-on style Mcleod HTOB bearing used on the Tremec TKO. Its a donut shape and I came up with a slave piston surface area of exactly 2.0 square inches.
I also found this article that helps explain how to calculate your clutch set up requirements. Happy reading.
Clutch Calculations
Old 06-02-2011, 09:12 PM
kitcarbp's Avatar
Default My Final Set -up
OK, After installing the 13/16" master cylinder for the HTOB I found the sweet spot as far as adjustability for my set-up. While the pedal pressure has increased a bit from the 3/4" MC, its not too much for my young left leg. I may have a different view 10 years from now
I am able to have the clutch disc begin to engage with my pedal about 1 inch off of the pedal stop as its rising up from the floor board. The total HTOB travel I have is about 0.600 inches with the pedal fully depressed to the pedal stop. Shifting is smooth into all gears.
So the root cause here was not a stuck disc NOR air in the system (Im an expert in that task and can fill a new system and have it bled in about 10 minutes tops.) It was simply not enough HTOB travel using the 3/4" MC and my clutch pedal geometry as designed.
I also installed an aluminum coated heat protective sleeve (from DEI) along the complete length of the clutch fluid feed steel line to keep the heat from the headers from boiling the fluid in the clutch line. The next mod I'm doing is to form a basic heat shield that mounts to my master cylinder to keep the header heat from heating up the fluid in the MC. Well...... that sure was an education in custom hydraulic clutch set-ups, if I did this for a livin Id starve.. !!. but its set up right.
