SUPPORT OUR SPONSOR
Go Back   Club Cobra > Club Cobra Tech Areas > Transmission Talk
Old 03-28-2006, 06:55 AM
speed220mph's Avatar
Cobra Make, Engine: ERA 427SC w/427so, ERA GT #2002
Burgs: I know of a women who put her new Jaguar through the back of the garage when this happened . . . had the clutch pedal down and started the engine. The car was fitted with a three-paddle ceramic clutch disc. The disimilar metals between the facings and flywheel bonded, preventing clutch release.
If you're running a cerametalic, iron or any other metal-base disc facings such as a dual-friction disc, corrosion may have bonded your disc to the flywheel or pressure plate, too. However, if you've installed organic facings, check to see if there's any way you can look into the bellhousing while the clutch is operated. If not, you'll need to remove the transmission to check . . . maybe even the complete bellhousing and clutch assembly.
Tom
"If you can make black marks on a straight from the time you turn out of a corner until the braking point of the next turn, then you have enough HORSEPOWER." Mark Donohue
