Like Tree327Likes
Old 02-14-2016, 07:35 PM
Pills's Avatar
Cobra Make, Engine: RAM, 5.0L with ST10 4 spd
I have a complete set of speed hut gauges in my car. I Have had no issue with them so far. The night visibility is outstanding. I originally had the GPS speedo but have since changed it out for the cable version. The reason was I just felt that there was a lag in the speedo display during acceleration and deceleration. Programing I felt was easy, and the only issue I ever encountered was electrical noise on the tacho which was easily resolved. I love the fact that they don't require much depth behind the dash, which was my main reason for buying them. No regrets so far. Their fuel gauge even works with my one wire fuel sender from an SD rover, and I have been able to calibrate it to give me full sweep of the gauge. I reckon they are great value for what you get.
Jaydee likes this.
Old 04-17-2016, 12:16 AM
Modena's Avatar
Put the car up on stands today to give the wheels a good wash and inspect everything underneath after hooning around Winton at ShelbyFest.
Nothing about to fall off, however it looks like my passenger side engine mount has shat it's guts, there's dry brown residue and it looks to have come out of the engine mount. Guess I will go looking for some Nolathane ones or similar. Typically OE rubbish, can't take track work abuse...sheeesh
Ben in AU
Old 02-13-2016, 09:57 PM
Modena's Avatar
Thanks for the feedback fellas, wow I thought Speedhut were decent. I might look for another brand!
Ben in AU
Old 02-14-2016, 01:10 AM
Cobra Make, Engine: CR Cobra 3169
I have the GPS speedhut speedo. But so far I haven't driven it. I like all the different settings, it even has a compass direction. I did have trouble with the huge nut holding it place, and there is no key or slot to stop it spinning around. Nice coloring at night. And I don't need to worry about calibration, only tunnels.
JD
Old 02-14-2016, 04:50 AM
Cobra Make, Engine: absolute pace chassis #50 L98 & 6 speed auto
JD
Pretty sure they wont pass if your engineer finds out about it it would make life simple tho
a cobra is a passion anything else is just a car
i dont care what the question is .. The answer is more power!!!
Old 04-17-2016, 01:45 AM
gjkrv8's Avatar
Wow I am going to have to check mine. So far so good though after 5 ShelbyFests and 4 Nationals. Mine are OE too.cheers Gregg
Old 04-17-2016, 02:24 AM
Tenrocca's Avatar
Driving far too aggressively Ben. Need to slow down mate before you do your car some real mischief.
750hp, guye and gjkrv8 like this.
Old 04-22-2016, 08:27 PM
Modena's Avatar
Here is what is in your LS engine mounts, and that is not all the oil, about 100ml came out!
Ben in AU
Old 04-22-2016, 09:19 PM
gjkrv8's Avatar
was it both or just one side ben?
Old 04-22-2016, 10:48 PM
Modena's Avatar
just passenger side, very common on Commodores for them to fail apparently
Ben in AU
Old 04-23-2016, 01:14 AM
Cobra Make, Engine: Pace 427SC. LSA Supercharged with 6sp TR-6060 trans.
Geez, what a mess Ben.
Us Pace peeps have solid urethane/Nolathane mounts, so fortunately we won't have that issue.
www.paintwerks.com.au
Old 04-23-2016, 06:40 AM
guye's Avatar
Cobra Make, Engine: AP Pace427 (AP4033) GM L77 6.0L TR6060
Bet it doesn't smell as bad as diff oil though, Ben?
Gav likes this.
Guy
Cobra Progress guye-cobra.blogspot.com
Old 04-23-2016, 08:49 AM
Aussie Mike's Avatar
I had read they were oil filled for damping but hadn't seen one opened. Very interesting. I guess the passengers side of the motor is lifting under hard acceleration and trying to pull the chassis up with it. The mount has cried enough.
I might have to look at machining up some replacement ones for mine with urethane bushings.
Cobra72 likes this.
Mike Murphy
Melbourne Australia
Old 04-24-2016, 05:43 PM
LoBelly's Avatar
As if you need an excuse to machine something up.
I think you might need to do run of them...
...can think of at least 1 customer
LB
boxhead likes this.
Old 04-25-2016, 06:11 PM
ive changed hundreds of these mounts while working at a workshop good idea in theory but in practice epic failure
Old 04-26-2016, 03:10 PM
David Hodgson's Avatar
Magna's run a fluid rear mount 'cept its full of a thick opaque sticky fluid. Didn't make a mess - just dripped on the ground for a few weeks.
SLIPRY
Old 05-06-2016, 11:43 PM
Modena's Avatar
My clutch woes continue. The clutch is not releasing properly at high rpm, seems it’s a common issue with the LS7 clutch, to do with the self-adjusting pressure plate.
The last ditch effort was to put in a 1” master cylinder, up from 7/8”, but to no avail. The pedal changed behaviour of course but the underlying problem remains.
Now that I have read everything there is to read on this LS7 clutch, I take it they are a very heavy unit and it's robbing throttle response, so maybe it's a good thing that it will be going in the bin.
Therefore the engine/trans is coming out and a monster stage II clutch will be going in.
I need to take the exhaust off anyway to get the headers re-coated, and I want to anodize the aluminium heat shields rather than the current paint, might do a few other little things while the donk is out also, so it's not the end of the world.
Ben in AU
Old 05-07-2016, 12:20 AM
Tenrocca's Avatar
Consider a textralia too Ben. Best after sales service of any company Ive ever encountered. Fixed my clutch FOC after I buggered it by running the wrong pilot bearing - coincidently that was a similar symptom to what your seeing.
Old 05-07-2016, 12:31 AM
Modena's Avatar
Pilot bearing was suggested to me thanks Andrew. However it is the right one, there's only two sizes and it would be very hard to get wrong. I installed the bearing myself so I'm confident it is correct. How did you get it wrong?
Ben in AU
Old 05-07-2016, 01:40 AM
Modena
The LS7 clutch as fitted in the Z06 Corvette is normally very light.
The only time I have had trouble with clutch slipping - say between high rpm gear changes - is when the clutch is depressed too far. The centrifugal forces of the diaphragm or fingers spinning at over 6000 rpm means that the diaphragm or fingers take a lot longer to clamp up on the clutch disc.
I have experienced this ........either with clutch plate too thick, or too much travel on the slave cylinder. Standard LS7 clutch set up properly, should be good for 700hp. I would re-check dimensional specs........they can be critical. Muz
Rate This Thread:
