Like Tree1Likes
  • 1 Post By HSC-ZL1
Old 06-08-2015, 08:38 PM
Gun Doc's Avatar
Cobra Make, Engine: BDR#499 351W with Webers
SSoldier,
You most likely have a Wilwood slave; it’s located on the driver’s side aft of the bell housing. Mine started leaking early on and I replaced it with a custom mount and a slave from what I believe is a Mazda. No leaks since I did that about six years ago.
They are fairly easy to bleed with a helper to depress the clutch pedal. You can You Tube it!!
Gun Doc
