Like Tree12Likes
Old 01-09-2014, 07:11 PM
Cobra Make, Engine: ERA - B2Motorsports Dart 331
Default Goodbye Kansas
Tilton 600
My car will be worth 30 cents when we are done. With any luck it will be inspiring to drive
Old 01-09-2014, 07:50 PM
Rick Parker's Avatar
Rick
Old 01-09-2014, 08:42 PM
Kansas => Toto, can't get home etc.
Hole in floor is not normal ERA FIA
Pedal assembly is not ERA Cobra - This is
A sad attempt at humor?
Old 01-09-2014, 08:50 PM
No going back ... got it
What exactly is the new set up?
Old 01-09-2014, 10:27 PM
Well we are going to fab a plate the size of the square hole we cut out. It will be welded to the top of the frame rail at the middle of the rail and along the bottom of the plate at the rail intersect and gusseted in three locations. The plate will have several holes threaded so we can unbolt the pedal assembly and move them forward and backward. The Tilton set up has a bell crank on the gas pedal. Am looking at moving that to the front of the foot box and devise a longitudinal linkage that can easily be shortened and lengthened as necessary to span between the pedal and the bell crank.
I am short and have small feet and cannot get the cockpit to fit me as I need. I want the seat back close to the roll bar so I can install a head support on the bar. Having the seat close to the rear bulkhead also helps with keeping the belts properly positioned. In order for this to work the pedals need to come forward to the 5 rivets (?) you can see on the floor board. I sat in it tonight with the pedal assembly pulled forward and it was the first time I immediately felt at home. It is still a bit of a crap shoot because the steering column is not installed, but my old seating position left me jammed against the wheel with still some struggle to reach the pedals. Heel and toe with the Tiltons is right there and the pedal faces are all adjustable right to left. I can really dial in a relaxed position.
I am some concerned about the Pedal ratio. Does anyone know the ERA ratio? The Tilton is adjustable from 5.25 to 5.75 and we have it set for 5.75.
Perhaps fab an alum cover that provides for some kind of adjustable heel stop.
Nice thing it is modular.
chr
Old 01-12-2014, 05:46 PM
8.750 from Pedal Pivot to Arm Pivot
1.750 from Arm Pivot CL to Cylinder Rod CL
8.750/1.750 = 5.0
Perfect
chr
Old 01-12-2014, 06:04 PM
Old 01-21-2014, 02:45 PM
I wanted to post the in "Need More Mirrors", but they just don't fit there.
They will fit here - I hope
Old 01-09-2014, 11:23 PM
Sounds very clever and looks like it will work and give you some adjustability for fine tuning, good work. It’s very important to feel comfortable, makes for a much more enjoyable and safer driving experience.
It’s interesting the work arounds one comes up with to make the car fit the driver. I have the opposite problem of being too tall for the car. One of the key reasons I went with ERA was their willingness and capability to modify the car to fit me.
Best of luck with your project!
Old 01-09-2014, 11:50 PM
It's interesting the taller guy's in the shop (6 footers) fit it fine. I am 5'6" - all of us in that range struggle.
Old 01-10-2014, 08:07 AM
DanEC's Avatar
The ERA has a lot of leg room. I'm 6'2" and have my seat set about 1-1/2 inches from the bulkhead and I'm having to move the pedals back as far as they will adjust to comfortably reach them. I want to sit back to have room to manuver by big feet in and out of the door and get away from the windshield. At 5'6" and wanting to sit back in the cockpit I can understand your issue. Good luck with the modifications.
Old 01-10-2014, 04:55 PM
Old 01-10-2014, 06:20 PM
I hope Heaven feels this good.
Old 01-10-2014, 07:36 PM
You may need a dead pedal to brace yourself when cornering at 1.3g...
Chas.
Old 01-10-2014, 09:30 PM
I will put the ERA one back in once we have the cockpit sorted.
1.3 - you think it will pull that?
chr
Old 01-11-2014, 07:19 AM
It better or I'll never read a thread from you again...
Bxx1 and Ralphy like this.
Chas.
Old 01-11-2014, 07:54 PM
1.3 = 458 Italia territory - pretty sure cg is too high, not nearly rigid enough, and are limited by suspension geometry. Still, it will be fun to run it on a pad and see what we get. I will be happy @ 1(+) and that should be achievable.
I will be really happy if I get it to rev limit in 4th, but that is a different problem.
I think your expectation is not reasonable.
chr
Old 01-12-2014, 08:21 PM
chr
It's called incentive-giving you something to strive for.
With G-7's on you have a shot at it after all that suspension surgery.
Remember, I called Brent's build of Lipton's 482 within 2 HP and yours very close too..
Chas.
Old 01-12-2014, 06:54 PM
You have some very substantial structure for the pedal assembly to bolt on to, nice work. Looks like you are well on the way to getting the pedal assembly just where you want it.
Old 01-12-2014, 07:34 PM
Thanks - maybe a bit over built, but it gives me confidence. The entire assembly including the steel plate is within a couple of pounds of the stock setup. The pedal assembly structure is cast aluminum so what is saved there is given back in a rigid mounting plate.
It would be disastrous to have something break while trying to bring the car down from high speed.
Display Modes
