Like Tree4Likes
  #41 (permalink)
Old 05-31-2016, 10:14 AM
My theory is to just keep torquing it down until either 1) your arm gets too tired to crank it anymore, or 2) something breaks. If it's the latter, just view it as an opportunity to upgrade to something better and chalk it up to whatever broke as probably needing to be replaced anyway.
Texasdoc likes this.
  #42 (permalink)
Old 05-31-2016, 08:01 PM
davids2toys's Avatar
Cobra Make, Engine: ERA, 428, 4 speed Toploader, Jag rear, Red with White stripes
Thanks Lippy, interesting reading for sure, still very confusing though!
Phil, I will probably be removing the carb to Torque these things properly. Sucks that I just put it on 1 week ago :>(
ERA#698 428, 4 speed Toploader, 3:31 Jag rear
  #43 (permalink)
Old 05-31-2016, 11:04 PM
Gaz64's Avatar
One of my mates did this a lot, so I bought him a short spanner set for his birthday one year.
  #44 (permalink)
Old 06-01-2016, 05:20 AM
In the states we call those "stubbies." I have a nice set of them and they are, for a fact, my "go to" wrenches on just about everything. I only break out the larger wrenches after I have bruised and exhausted my hand.
  #45 (permalink)
Old 06-01-2016, 05:42 AM
Cobra Make, Engine: ERA 714
David,
It's not a bad job. If you have the gaskets and pipe thread sealant for the fuel log to car connections, it's a pretty easy job. You should get it running and drive it to Columbus Ohio for the London show in a few weeks. There are just over 108 cars showing up.
Phil
  #46 (permalink)
Old 06-01-2016, 06:32 AM
DanEC's Avatar
Same here - I have a couple and usually grab one for tightening up valve cover and pan bolts and the such. I grab it around the center with my palm to further limit the amount of torque I can effectively apply through it. I can twist on it firmly and probably never apply more than 10 - 12 lb ft torque. Very easy to modulate force.
ERA 782 Running
  #47 (permalink)
Old 06-01-2016, 06:36 AM
Originally Posted by Large Arbor View Post
David,
Phil
What is not a bad job? My fuel log just picks up on two of manifold bolts on the pass side. Pipe sealant?
I hear that show is awesome and one day I would love to go!
  #48 (permalink)
Old 06-01-2016, 06:42 AM
Dan,
I have a whole set of those wrenches, they are about 3" long right? Just the opposite for me though. I only use then when I absolutely have to. 10-12 on a valve cover won't work for me at all. Because there is not much leverage here, I always am afraid because of how much force it feels that I am applying. I try and finish off everything thing with a torque wrench. I just cant help myself
  #49 (permalink)
Old 06-01-2016, 06:48 AM
For the life of me I cannot find a 3/8 drive, 12 point, 3/8 crows foot. Every other freakin size but 3/8. So frustrating!
He must have received the two 12 points bolts with the fuel log because all the other manifold bolts are 6 point.
Does any body think I could get away with a 1/4 drive crows foot? Could it take 25 ft lbs without breaking it or the 3/8 drive to 1/4 adapter I am going to have to use on my torque wrench to step down the drive. I think they shear pretty easily.
  #50 (permalink)
Old 06-01-2016, 07:34 AM
Shootnride's Avatar
Cobra Make, Engine: Superformance, 427SO
Snap on 3 8" Drive 3 8" Torque Adapter Socket Wrench FRDH121 Mint | eBay
Ted
  #51 (permalink)
Old 06-01-2016, 09:41 AM
Smile
David,
I only meant that the intake gasket was the easier thing to do from the last job I did on mine which was replace head gaskets. Mine looks like this with the fuel log in the same place. The key part is marking the location of the distributor with the #1 cylinder at TDC. That will save some time when it goes back together.
Phil
  #52 (permalink)
Old 06-01-2016, 09:58 AM
Oh, now I understand! Beautiful engine Phil. that is the exact setup I would like to have. I love the look of dual carbs. Unfortunately for me, it costs a lot, but fortunately, I also like the Turkey pan look that I have..... except it can be a PITA at times.
  #53 (permalink)
Old 06-01-2016, 10:04 AM
No Ted, I need the short version of what this is. I would call this a "dogbone".
I have found what I want in every size but 3/8. they also have a open version which they are calling "flare". I don't know if the open version can take 25 ft lbs though?
looks like this:
https://www.zoro.com/proto-crowfoot-...w&gclsrc=aw.ds
  #54 (permalink)
Old 06-01-2016, 10:08 AM
Here is my setup Phil
  #55 (permalink)
Old 06-01-2016, 10:32 AM
Bernica's Avatar
Senior CC Premier Member
Like this?
https://store.snapon.com/Flank-Drive...t-P631792.aspx
  #56 (permalink)
Old 06-01-2016, 10:54 AM
Yes, like that or the closed version. if you look at that, it starts at 5/8 not 3/8. I also don't want a whole set or spend that kind of money
  #57 (permalink)
Old 06-01-2016, 11:52 AM
Shootnride's Avatar
looks like this:
David,
Ya, I knew the item I posted wasn't a crows foot but thought it would do what you needed. Anyway, hope you find what you're looking for.
Ted
  #58 (permalink)
Old 06-01-2016, 12:08 PM
David,
Yours is very nice as well. The turkey pan looks clean enough to eat off of! Turkey on a turkey pan sounds good right now! (:
Phil
  #59 (permalink)
Old 06-01-2016, 05:37 PM
Originally Posted by Shootnride View Post
David,
Ted
Thanks Ted, appreciate it.
It wont even work with the carb off, it is to long and will hit the little runners adjacent to the bolt. If the fuel log was not there, I would have a lot more room to work...it would probably work because I could hit it from a different angle
  #60 (permalink)
Old 06-01-2016, 05:41 PM
Bernica's Avatar
If your have the abilities and resources, just make your own custom socket.
